Question about British Telecom Stratus 1500 Cordless Phone
I've had my BT Stratus 1500 (trio) for approx 18 months and two of the three have stopped charging? Not sure whether it needs the batteries replacing or the charging docks
Where do I get a user manual for a bet stratus 1500 sect phone
Do you mean the BT Stratus 1500 cordless phone? If so, the manual is available from the product support page: http://bt.custhelp.com/app/answers/detail/a_id/12318/~/bt-stratus-1500 . The direct link to the manual is https://btbusiness.custhelp.com/ci/fattach/get/223691/1232386725/redirect/1/filename/BT_Stratus_1500_User_Guide.pdf .
I hope this helps.
(There are no BET model landline phones that I am aware of.)
Mar 25, 2017 | Lands Phones
Trio stealth tablet will not go past logo
This may be unrelated, but if you let the tablet go to sleep it will drain the battery. I found this out with my Stealth Pro about three months ago, I imagine it is more of an Android issue. It would not startup or go past the opening logo until I had charged it enough. This may also be the case if the battery is damaged or will not take a charge, in theory.
Aug 21, 2014 | Mach Speed Trio Stealth Pro Trio Stealth...
How to trace caller numbers on my BT telephone?
Dial *69 and that should give you the last caller, some phone company's will charge you for this service...
Feb 14, 2014 | BT Hudson Plus 1500 Trio Dect Cordless...
OBD2 CODE READER P0562
fully charge battery and make sure everything switched off i.e rear window demist etc and take it for a run to get it up to tempature then park up rev engine at fast idle approx 2750 rpm for 180 seconds then take foot off throttle and allow to idle for 30 seconds this will clear your catalyst and get it up to the 600 degrees needed for it to operate properly this should remove the engine warning light
Apr 21, 2013 | Mazda RX8 Cars & Trucks
1 of my trio BT 1500 keeps beeping I have fitted new batteries
Try it in another charger as it sounds like it's not charging, solutions, clean battery terminals in phone, clean terminals on charger, swap chargers
Mar 28, 2013 | BT Hudson Plus 1500 Trio Dect Cordless...
Hi I've had my HP laptop from Telus for approx six
Dead battery? If it's six months old return it A.S.A.P.
Jan 18, 2013 | Computers & Internet
I've got a Dell Studio 1735 that started to tell me the battery was on the way out after 18 months (maybe a bit more). One day the battery stopped charging and when it ran down completely it...
There is a short circuit on your motherboard. This is why the power adapter switched off (thermal cutout) and resets after you remove the adapter from the wall power outlet.
You need a new motherboard.
Aug 19, 2011 | Dell STUDIO 1735 Motherboard - H274K
I need a user manual for BT STUDIO 1500 TRIO DIGITAL CORDLESS TELEPHONE.
Welcome to Fixya.
Please find the user's manual by following the link below :
BT Studio Manual
Thanks for using Fixya.
Jul 09, 2011 | Cell Phones
Battery not charging!
If the battery is 2 years old, then buy a replacement battery, see if it charges. Portable batteries are good for roughly 300 to 500 recharge/discharge cycles before they begin to fail roughly 18 months. Dell warrants the Battery for 1 year, so there is no warranty on the battery. If a replacement battery doesn't charge, then the motherboard will need to be replaced. If under warranty, Dell will fix it, if not, motherboards are $100-150 on Ebay.
May 21, 2009 | Dell Vostro 1500 Notebook
British Telecom Stratus 1500 Cordless Phone Logo
24 people viewed this question
Top British Telecom Lands Phones Experts
honeybun1986
Are you a British Telecom Lands Phone Expert? Answer questions, earn points and help others
