Question about Mitsubishi 2012 Outlander SE 2WD
Does the mitsubishi outlander have a fuse for the towbar
  • Randal Lovelace Nov 25, 2014
    Hi Antony Lanser, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Make/Model of the attached Towbar?
2004 mitsubishi outlander no communication with snap-on (modis) scan tool
check your lighter fuse if its blown that's it.
phone charger outlet not working ?
Oct 25, 2015 | 2004 Mitsubishi Outlander
Mitsubishi outlander 2009 ac outlets stopped working. Where do I look to check the fuses?
Most fuse boxes are under the steering wheel by your left foot, at the ends of the dash, in the glove box, or under the hood. Better yet, you can download the manual for your vehicle right from Mitsubishi and know for sure. Just go to the link below and setup an account.
http://www.mitsubishicars.com/MMNA/jsp/owners-site/manuals.do
Please remember to rate my solution.
Jul 03, 2011 | Mitsubishi Outlander 09 2009
My accessory sockets (cigarette lighter) are not working on my 03 mitsubishi outlander, I checked the fuse box and they are all okay. Any suggestions?
It's fuse # 25 a 15 amp. There is a relay in this circuit and the ignition switch must be on or accessory. By the way, sometimes what you are trying to plug in just doesn't make good contact.
Dec 19, 2009 | 2003 Mitsubishi Outlander
My outlander 2003 mitsubishi accessory socket is not working what can i do
check the fuses, also check fuses in engine compartment, 99% of the time its just a fuse, good luck.
The cigarette lighter is not working but fuse is
Hello, try plugging something else into your cigaret lighter and see if it worgs EG: mobli phone charger. If it works it means that you need to replace your cigaret lighter. I hope this helps.
Nov 07, 2009 | 2004 Mitsubishi Outlander
My mitsubishi outlander 2007 does not turn on... can you help me?
have you checked all the fuses inside and out, it kind of sounds like a bad ground or dirty battery terminals
I’m happy to assist further over the phone at https://www.6ya.com/expert/john_2c7bb9c157d0baa8
Jun 26, 2009 | 2007 Mitsubishi Outlander XLS
2004 mitsubishi outlander cooling fans not operating
you must ring mitsubishi as the problem is the cooling fan controller and this is product recall and will be replaced for free
May 30, 2009 | 2004 Mitsubishi Outlander
TAKE A PEEK UNDER THE HOOD IN THE FUSE PANEL FOR THE FUSE AND RELAY FOR THE COOLING FAN. IF THE FUSE IS BLOWN THEN REPLACE IT. IF YOU SUSPECT THE RELAY TO BE BAD THEN TEST IT BY SWAPPING THE FAN RELAY WITH ANOTHER ONE WITH THE SAME PINS ON THE BOTTOM. MAKE SURE IT IS THE SAME SIZE AS WELL. HOPE THIS HELPS.. PLEASE KEEP ME POSTED. THANKS FOR AN HONEST RATING AND FOR USING FIX-YA. GOOD LUCK
May 16, 2009 | 2004 Mitsubishi Outlander
Mitsubishi 2012 Outlander SE 2WD Logo
41 people viewed this question
Top Mitsubishi Computers & Internet Experts
Shaukat Bhutto
Level 1 Expert
Alun Cox
Are you a Mitsubishi Computer and Internet Expert? Answer questions, earn points and help others
