Question about HP Computers & Internet
My Computer will not boot with Toshiba hard drive Cancio 3TB model# HDWC130XK3J1 plugged in.
I have a Toshiba hard drive Cancio 3TB model# HDWC130XK3J1 And a HP Pavilion model#a6803w my computer will not boot with this drive connected to it. It works fine on my other computer but not this one. I have flash the BIOS and still nothing.
    Top Expert:
  • HP Master
  • 22,161 Answers
Probably too large for the firmware on the motherboard. try partitioning the drive.
Posted on Nov 21, 2014
  • Jimmy Whisenhunt
    Jimmy Whisenhunt Nov 21, 2014
    Tryed partitioning it in 1/2 did not work. When it boots up it hangs on the start screen and locks my keyboard up too.
rickyostrom
  • 270 Answers
SOURCE: thinkpad 390x 2626, won't boot from cd drive
Try pressing F12 at startup, you should get a boot option.
Posted on Nov 19, 2008
Geekman
  • 32281 Answers
SOURCE: HP Pavilion zv6000 won't power up after getting zapped
It sounds like you have a piece of junk, the hard drive mighr be OK , if it is you can put it into a USB hard drive adapter case and use it as an external USB hard drive.
Posted on May 06, 2009
  • 2567 Answers
SOURCE: I have an HP Pavilion dv4. The wireless
Sounds that the wireless adapter daughter board is either loose or failing. First, we need to make sure it is making good contact with the laptop's motherboard. In order to do this, we have to do the following:
1. Turn off the laptop & remove the battery.
2. Look at the compartments in the bottom of the laptop. You should be able to see 2 or 3 areas with small rectangular plates covering them. These plates usually have one or 2 screws holding them in place.
3. Check which one of those plates is the one which covers the wireless adapter daughter board. When you find it unscrew its screws & remove it.
4. Below the plate, there will be a small daughter board screwed to the laptop's motherboard, with 2 thin wires attached to it (usually one black wire & the other is a white wire). Gently, remove both wires using a small flat screw driver to pull them out gently. Don't forget to note down which wire connects to which connection point.
5. Unscrew the wireless adapter daughter board & remove it from its slot.
6. Clean both the slot & the daughter board's terminal connectors using a dry electric contact cleaner. You can purchase it at an electronics store.
7. Leave the slot & the daughter board for a while to dry.
8. Re-place the daughter board back in the slot & screw it to the motherboard.
9. Reconnect the 2 wires.
10. Screw back the covering plate.
11. Put back the battery & turn on the laptop. Check if the problem was fixed.
If this did not fix the problem, you will need to repeat the steps to remove the wireless adapter daughter board & replace it with a new one.
Posted on Oct 26, 2010
Testimonial: "Turns out it was a bad connection with the wireless card. Thanks. "
technolust
  • 340 Answers
SOURCE: need to update bios toshiba satellite c660,using ubuntu live dvd, will not boot hard drive, all normal recovery options used up
Hi There,
There are currently no easy ways to update a bios through linux at all - including live cd's. Your best bet is to make a bios update USB stick (or floppy depending on the age of the computer)
Here's a link to those instructions:
http://www.biosflash.com/e/bios-boot-usb-stick.htm
Alternatively, speaking from my own experience with a similar situation, you can take the hard drive out, use it in place of the usb stick, boot from it, update your bios, and go from there.
Posted on Jun 06, 2012
Testimonial: "Matt, exactly what I have been searching for, I am well advanced in years so will take me a while to configure this, I found the update OK but was a problem choosing the utility. WELL DONE & MANY THANKS Jim"
External hard drive transfer rate very slow
Windows 7 has something set wrong if you are showing 2.6GB usable. Windows 7 will recognize 3GB regardless of whether it is 32 bit or 64 bit.
Oct 02, 2014 | Toshiba Canvio Desk HDWC130XK3J1 3 TB...
Windows will not start with a Toshiba external hard drive plugged into USB
Computer starts normally in windows with a windows that is installed on a hard disk on that copmuter. In other words - windows is installed on an internal hard disk of a computer A. If you get it out and put in a computer B it wont work.
To have the things work:
1. First should set in BIOS boot up options first boot device CD/DVD, second OTHER/USB/EXTERNAL, third HDD
2. Should boot up from a CD and install windows on an external hard disk (in your case your 3TB Toshiba external HD)
3. Set in BIOS boot up options first boot device OTHER/USB/EXTERNAL, second internal hard disk e.g. HDD0, HDD1
Apr 04, 2014 | Toshiba Canvio Computers & Internet
Is there a manual available to download for the Toshiba Stor.E Canvio 3TB desktop external hard drive.
What? Did you lose the box and/or the manual? Try googling it, binging it, yahooing it, etc. but you might check ebay for manuals
Feb 05, 2014 | Toshiba 3TB Canvio Desk Desktop External...
Toshiba 3tb Canvio has no power.
Heard something rattling inside huh?....might wanna have ur hard drive closer opened carefully sounds like something is damaged inside if it's not getting power
Jan 09, 2014 | Toshiba 3tb Canvio Desktop External Hd
Will the toshiba canvio desktop 3tb hard drive work with the LG 47LM6700 tv?
Depends on the format your hard drives in (personally I'd just use a PC with an HDMI cable) and whether your TV supports USB file reading.
Nov 30, 2013 | Toshiba 3tb Canvio Desktop External Hd
Should i unplug (usb cable) canvio desk without shutdown computer
You can, but if it's writing to the disk when you disconnect, it could cause errors.
The safer thing to do is... look in the bottom right hand corner of your monitor. Click on the icon that is a USB plug with a green checkmark on it. Then click eject drive. The computer will pop up a window that says it is safe to remove hardware. Then you can unplug the drive.
Nov 26, 2013 | Toshiba 3TB Canvio Desk Desktop External...
Bios not recognize new hard drive dell ide
The problem is with your BIOS settings. You need to make sure the drives are set to AHCI in the BIOS.
Sep 21, 2013 | Dell XPS Computers & Internet
Computer won't recognize external usb hard drive
Format drive NTFS sounds like its corrupt, use mini partition wizard...
may also need 3TB Unlocker from manufacturer of Hdd
Dec 27, 2012 | Toshiba HDWC130XK3J1 Hard Drive - Canvio 3...
Computers & Internet Logo
41 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
