Xerox m118 has fault u6_3000 - Office Equipment & Supplies
    Sergeant:
    Champion:
  • 246 Answers
Try to reinstall the printer dirver
Posted on Nov 27, 2014
2 Suggested Answers
fotobean
  • 103 Answers
SOURCE: Our xerox M118 showing an
Hello, Your Xerox has two cartridges - one is the drum cartridge and the other is a toner cartridge. Please check the following I've researched from your user guide:
Replacing the Drum Cartridge
The drum cartridge is a customer replaceable unit. After approximately 55,000 copies/
prints, the machine will display a warning message before the drum reaches the end of
life. Order a replacement cartridge now to insure continuous operation.
Country Part Number for the drum cartridge replacement
All countries 13R589
Removing the Old Drum Cartridge
1. Pull the front cover towards you to open it.
2. Open Tray 5 (bypass tray) if necessary, and then open Cover A while lifting up
the release lever.
3. Lift up the colored lever, and slide the drum cartridge out until you can lift the
handle on top of the cartridge.
4. Hold the handle and remove the cartridge from the machine.
NOTE: When replacing the drum cartridge, make sure that the new cartridge is the
correct one specified for the machine.
Recycling the Drum Cartridge
The drum cartridge is designed to be re-manufactured. To recycle used drum
cartridges, return them to Xerox in the original packaging. Return labels are included
with each new cartridge.
Inserting the New Drum Cartridge
1. Remove the new drum cartridge from the box.
2. Undo the sealing tape and carefully pull out in the direction of the arrow to
remove the black protective sheet from the cartridge.
3. Place the cartridge in position and, using the handle, slide it into the
machine until it clicks.
4. Pull out the cartridge tape completely without breaking it.
5. Push the cartridge again so that it is correctly placed.
6. Close Cover A until it latches and then close Tray 5 (bypass tray).
7. Close the front cover.
Hope this helps. Good luck.
Posted on Dec 11, 2008
How to reset xerox m118 drum
Hi, I have a solution to your problem click on the link below which will direct you to a step-by-step guide to fix your problem!
Xerox Workcentre 123 128 Reset Drum Life Free
Aug 26, 2014 | Xerox WorkCentre M118 Black and White...
NOT PRINTING IN WINDOWS 7
update your driver download the compatible driver for window 7
http://www.support.xerox.com/support/workcentre-m118-m118i/downloads/enus.html?operatingSystem=win7
Apr 19, 2011 | Xerox WorkCenter M118 All-In-One Laser...
I need Xerox workcentre M18 Drivers
Xerox WorkCentre M118 Drivers
The required drivers can be downloaded from the above link from Xerox Official Support. Select the operating system you have on your PC and download / instal the files.
Hope it helps! Good Luck!
CreativeTECH
Apr 09, 2011 | Xerox WorkCentre M118 Printer
Cómo cambiar el fusor de la xerox m118 y
I need a card red to be used in the Xerox M118 with connection RJ45, wich I can get, model or any specificacion
Jan 20, 2011 | Xerox WorkCentre M118 Laser Printer
Xerox workcentre M118 is having problem in pulling the paper to the fused roll.. what could be the problem?
Most likely one of the rollers in the paper path between the developer and the fuser is slipping. You are going to have to get a Xerox tech to take a look at it.
Sep 10, 2009 | Xerox WorkCentre M118 Black and White...
CHANGE A m118 TONER
hey follow the instructions on the toner box,pliz follow them,if u fail get back here.
Sep 18, 2008 | Xerox WorkCentre M118 Black and White...
23 people viewed this question
k24674
