What is a mining of shine E000805-0000 on xerox machin canon ir 2830
    New Friend:
  • 34 Answers
I don't have the service manual for this model but on many canon copy machine E805 is a fixing fan error.
Posted on Nov 25, 2014
SOURCE: canon ir 3300 xerox machine display board not working
dispaly and pad is not working who to open it tell me the codes
Posted on May 26, 2009
redzventures
  • 149 Answers
SOURCE: I have an IR-3300 Model xerox machine. It was
The two problems may not be related. Adding toner should not under most circumstances cause copies to become light, unless the toner you are using is of a poor quality - I hope it is a Canon cartridge or quality generic. It sounds as though your fixing film or drum unit may need replacing, or perhaps you need to perform a install procedure. As the 'install - toner - start' option is free, try it first:
First press the head key and then the number '2' and '8' keys at the same time then press the head key again. This will take you into service mode - select 'copier' then 'install' then 'toner' then 'start'. This will run throught a cycle that takes a little while, I think about 599 seconds (sorry for been so accurate but unhelpful but that's what I remember from the display - never converted into minutes but you're welcome to).
But if you are having blurry or even dirty or light copies it may be the fixing film. When the copies are printed, immediately check if you can rub off the toner at all by rubbing the print with your fingers - if so this indicates that the fixing unit is not hot enough or there is not enough pressure - check that the fuser is in properly and that the jam release lever is not engaged.
Lastly, it could be your drum unit that is faulty or worn. Totest this you will need to try and stop the machine in the middle of printing before it reaches the fuser - open the front cover and latch down the transport bed with the green handle - remove the paper gently so as not to disturb the ink in any way and observe the image quality - if it is displaying the exact same symptoms then it is not your fuser and is probably the drum unit or dodgy toner - most likely the drum. However, if the image is fine, then it most definetely is your fuser film (and or perhaps the cleaning roller that cleans the film).
Good luck
Posted on Jul 31, 2009
canontech
  • 1219 Answers
SOURCE: copy darkness problem canon image runner 2830
Did you try to clean beneath the copy glass?
On digital machines, when the copy glass or optics are dirty, copy becomes verry light.
How many copies do you have? pres 123 button.
It also could be that you need to change the toner station, by the book it goes 300000 copies.
But I bet on dirty copy glass and dirty scanner assy.Clean the glass with glass cleaner and polish it with dry cloth.
Posted on Jul 25, 2010
Testimonial: "so thanks"
SOURCE: how to set ip address
I need fax facility of my canon ir2830 network machine. pl let me know how to setup for fax in my canon ir2830
Posted on Jan 30, 2011
SOURCE: I HAVE A CANON IR
my xerox problem E000064-0000
Posted on Mar 15, 2011
Error code 0001-0002 canon 2830
Error code 0001 0002 ane par kya kare
Oct 09, 2014 | Canon Ir 2830 Digital Copier
Error codes ir2830 E00020-000
sir mere machine ka page counter reset karna h
Nov 04, 2013 | Canon Ir 2830 Digital Copier
Canon ir 2830 coding out to E000007-0000 - what can correct this can I do it myself
CANON IR 2830 ERROR CODE e0007-0000 SIR PLEASE SOLUTION MY ERROR CODE
MOB.9636327398
EMAIL-M.KCOMPUTER31@GMAIL.COM
Mar 14, 2011 | Office Equipment & Supplies
How to set ip address in canon ir 2830 i want network scan in this machine and send me complete information about net work scan
Dec 31, 2010 | Canon imageRUNNER 400S Copier
Canon ir 2830 error code e 490
SIR CONON IR 2830 COMPUTER SE ATTACH HO SAKATI HE
Sep 03, 2010 | Canon IMAGERUNNER 3530 Copier
Not getting dry prints using canon 3300 xerox machine
1) is it canon ir 3300 machine?
2) if it is what does it mean NOT DRY completely?
#) My ques is that you need to eplace fixing film
Jan 30, 2010 | Canon imageRUNNER 2270 Copier
Canon ir 3300 xerox machine display board not working
Feb 13, 2009 | Canon Office Equipment & Supplies
70 people viewed this question
k24674
