Question about aFe 2008 Ford F-250 - 6.4L Powerstroke - Air Filters
I am rebuilding a 6.4 powerstroke and i can only turn the motor about 60°. Could the rocker arms be too tight?
Making sure the came was in the whole way.
  • 138 Answers
Es loosen all rocker arms very loose and try to spin if it still does not spin and you may have the timing off
Posted on Nov 21, 2014
Fan wont turn
I have taken one apart. reassembled and the fan would not turn, although there was power to the motor and it wanted to turn.
Sorry this is long...only this is about taking the motor itself apart..and I have yet to find a replacement motor.
1. Tried a little WD 40...(only on iron motor Housing!) nothing.
2. Took apart inside of motor. some rust inside..
3. carefully rubbed clean with WD 40..
4. leaned off WD 40 with contact cleaner...
5. Then worked little bearing loose on back side.
-Kind of turned upon reassembly..
6. Found some silicone High temp lubricant and took motor inside part again.
7. a very thin coat of lubricant inside rotor.
-Re assembled yet again..began to turn at high speed, kept running..24 hrs..
- It .finally turned at silent mode. and continues to work
This may be ar beyond what you want to do, however if all else fails...what else can you do? buy another one?
Tips:
1. mark rotor holders with housing. (do not reverse.)
2. make sure you remove all lint, dust, etc inside.
3. the rotor bearing I had to work by hand again and again repeatedly syringing a little WD 40 at a time to until it turned easily.
Jun 04, 2012 | Oreck XL Professional Air Purifier
How to clean ozone plates
Unplug the machine.
1) Remove the back screen, then pull out the plates.
2)Soak them in a 1 to 1 solution of PLAIN ammonia and warm water for about 5 minutes.
3)Scrub with a toothbrush or soft veggie brush.
4)Rinse well.
5)Blow dry. Do NOT use any cloth or paper of any kind. Avoid touching the screen with fingers.
6)You can also clean the contact points with a cotton-tipped swab and alcohol.
6)Reinsert plates, making sure that they enter in the "groove" or track, both top and bottom. Make sure the contact fingers press firmly on both sides in the screen area.
Jan 19, 2011 | Alpine Air XL-15 Air Purifier
Will not turn on Have checked switch under filter Have checked continuity of the fuse plates are making contact Ecoquest Breeze AQ
Have you checked the fuse? It is located in back of the Breeze in the fuse holder next to where the plug connects to the purifier. It uses a 1.0 Amp slow blow for 110 volt models and 0.5 Amp slow blow for 220 volt models.
Oct 28, 2009 | Ecoquest Breeze AT Living Air Purifier
Our Eco-Quest Breeze no longer works. I cleaned
I've seen several like that and found the wire connections corroded off. Easy to fix if that's the case. Make sure the unit is UNplugged before taking it apart.
Sep 03, 2009 | Air Purifiers
Rainbow Rainmate making a screeching noise!
just take it to ur local dealer they will replace it or fix it.
Feb 12, 2009 | Rainbow Rainmate Air Purifier
My Venta Airwasher LW44 motor won't start
Test the motor to see if it works. Make sure the motor is removed from the rest of the unit. To find out how to remove the unit please hit the "Go Back button and select the "How to remove the motor button"...
  1. Plug the unit in to a working outlet.
  2. Push the #1 speed button on top of the motor.
  3. You now need to engage the saftey switch to start the motor.
  4. Protruding from the motor are two plastic about 3-4 inch guiding arms.
  5. Look inside the end of both of these two guiding arms. One of the arms are hollow and the other one has a white safety switch in the arm.
  6. Use a pencil or small item to push in on the safety switch.
  7. If the fan sarts to rotate the motor is still working.
  8. If the fan does not rotate then the life of the motor has probably ended and a new motor is needed. ( insert motor part link)
For additional support email abdistrsupport@gmail.com
Nov 16, 2008 | Venta - Airwasher LW44 Air Purifier
Oreck XL air purifier motor failure
My Orek was making such a bad noise that my wife was going to sell it at a garage sale, I'm glad she didn't. It takes about 20 minutes to fix. All you need is a phillips screw driver, can of compressed air (or air compressor) and a can of silicone spray.
Pull out the filters and turn the unit upside down. Using a phillips screw driver unscrew the 9 screws holding the bottom to the top. remove the bottom. Use care as to not damage the fan. The fan will stay attached to the motor , pull on it and use a good cleaner like 409, Simple Green or a similar product. Wash clean and dry. Next get out your air compressor and clean everywhere, see the silver bearing holders on the side of the motor? Get out your can of silicone spray and give a good squirt on both bearing (close to the shaft. also spin the motor with your hands. See the large thing attached to the shaft? Those are the windings. See the metal housing the winding spin close to? Spray the silicon in there, a good amount. Make sure you didn't get any silicone on the end of the motor shaft where the fan sits on. If you did get some nail polish remover or acetone and wipe clean a few times. Then reassemble.
My Orek was horribly noisy, now it's quiet. My wife says is beeter than new.....
Nov 12, 2008 | Oreck (AIRCOM1WOI) Air Purifier
After cleaning and replacing filters, won't turn on
I have had the same problem. The way I fix mine (it only runs for a couple days staight) is to switch the two filters (or maybe you just need to remove completely?) making sure they are in tight. Replace the cover and it should work!
Sep 06, 2008 | Honeywell HHT-145 Air Purifier
Water Filter Leaks
Since you weren't very specific where it leaks or when it started (like after a filter change) it could be tough to troubleshoot this leak.
If it is leaking at the faucet connection try tightening up where it screws onto the faucet. Depending on your strength (or lack of) you may need to use pliers to get a tight connection. Don't go crazy tight or it will crack the plastic fitting. If it still leaks remove the unit from the faucet and check the rubber washer inside where it screws onto the faucet. Make sure it's still there and is centered inside the cup and seated properly. Then reattach the unit to the faucet and tighten it well.
If it's leaking from the main body try removing the filter and reinstalling it making sure you have seated the filter properly and screwed on the cover correctly, and all the way. When it is tight the water outlet will be exactly at the bottom of the unit. Sometimes it's tricky getting it tight enough especially with wet hands.
Finally, if the leak is coming from the filter on/off selector this could be tough to fix. I would try firmly pushing and pulling the selector knob in and out several times while in both the on and off positions. This may re-seat the leaking seal. I wouldn't be too hopeful about this fix though. You may need to replace the unit if this part is leaking.
Nov 18, 2007 | PUR (FM-9500) Air Purifier
aFe 2008 Ford F-250 - 6.4L Powerstroke - Air Filters Logo
48 people viewed this question
Top aFe Air Purifiers Experts
Dan Webster
Dan Webster
Pcm2048
Are you an aFe Air Purifier Expert? Answer questions, earn points and help others
