My kenmore he2t gave me an error code f24, which is the temp sensor. When I got to the temp sensor the problem was clear, the wire that goes into the part that plugs into the sensor is broken off. I can't splice it because I can't get to the inside of the plastic part that the wires go into. Do I need to replace this part? How? What is it called, and how do I safely detach it?
    Problem Solver:
  • 10 Answers
Go to http://www.partselect.com/ and enter the model and serial number for your machine. yo can see a diagram of your machine and but a part if needed. They may also have a video of how to repair.
Posted on Nov 26, 2014
3 Suggested Answers
Krazytech
  • 725 Answers
SOURCE: kenmore he2t error code 21
F21 is a long drain...it is taking too long to drain..you have a something slowing down the drain.. you can remove the bottom panel and clean out coin trap... if there is nothing then you may have another problem... but this is the most common problem..
Posted on Sep 23, 2009
jsrock516
  • 5911 Answers
SOURCE: I have a Kenmore HE2T error code F24
The "F24" error code is a heat sensor error code. The following link explains the error code in detail and the steps to correct it:
http://www.fixya.com/support/r1976126-f24_error_code_whirlpool_duet_kenmore
In many cases, the connector plug on the NTC sensor wiggles loose and causes the error code. Check the NTC connection first to make sure it is tight and making good contact. This may save you a service call and/or replacement parts. Make sure you UNPLUG the washer before servicing anything inside the unit.
A replacement NTC module (if required) can be purchased at searspartsdirect.com for about $10. Refer to the parts illustrations under the "Tub and Basket Parts" heading.
If you have any questions, please let me know. I hope this helps you.
NOTE: Each washer comes with a technical data sheet located inside the cabinet. You will need to remove the lower toe panel directly below the door to access it. If it is not located directly behind the panel, it will be affixed to one of the interior cabinet walls. The tech sheet includes all troubleshooting tips, wiring diagrams and fault codes with explanations.
Posted on Dec 09, 2009
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
Kenmore he2t F25 error. Trying to ohm test the MCU. Are you supposed to stick the leads of the multimeter into the holes of the white connector where the wires go in, or to the wires themselves? They're...
Hello!
Most likely, error F 25 means that the aquasensor, the turbidity sensor of water, has failed.
Possible reasons of this error:
1) Perhaps there was a clog in the system of draining the water. Dirty water does not merge and because of this the sensor shows muddy water. It is necessary to clean the drain filter;
2) Lime or scale on the turbidity sensor. Always use high-quality washing powders or add descaling agent
3) Dirty water got into the plumbing. Drain all the water and run the wash program in hot water. The washing machine should be empty.
May 15, 2017 | Kenmore HE2t 3.7 cu. ft. Front Load...
Tested water temp with an ohm meter and connection
The "F24" error code is an indication of a water temperature sensor error. The temperature sensor is located at the rear bottom of the tub. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 09, 2012 | Kenmore HE2 Plus Front Load Washer
I have Whirlpool model WFW9200SQA and I am getting error code F24. I found instructions here regarding some resistance measurements I can make to troubleshoot, but I would like a little more clarification.
The F24 error code as you have gathered on here refers to the temperature sensor is out of range and must be checked.To access the temp. sensor ya need to remove the lower panel below the door and check the temp. sensor by removing the wire plug to it and measure the sensor to be between 8.8K &9.2K (8.800-9,200 omhs) at room temp.
Good luck,i hope this help ya to fix your washer,
GENE
Sep 22, 2011 | Whirlpool WFW9200S Front Load Washer
Error code f24
Hi
F24 is a water temperature sensor error. You have to unplug the washer and check the water temperature sensor and its connections, if that is fine then check the resistance of the heating element and the part that is bad should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 31, 2011 | Kenmore HE2 Plus Front Load Washer
I have a model #110.47561601, Kenmore HE2t Front load washer Type 832. I am getting a code of F-24, when I try to start the cylce. What is the problem that prompts a F-24?
Hello
F-24 is a water temp snsor error.Try running the machine in spin and drain.Once empty unplug machine for 3 min.Then try load of wash again.This time use cold water until error clears.
Aug 27, 2011 | Kenmore HE2 Plus Front Load Washer
Dec 09, 2009 | Kenmore HE2 Plus Front Load Washer
My kenmore he frnt load washer has an error code of (f24). tried the manual solution no luck. can you help me?
On this model of HE washer, the F24 code indicates that the water temperature sensor is out of range (23 degrees to 217 degrees F). This usually indicates a bad thermistor (temperature sensor - Key 24 in the image below). A bad wiring connection or a failed control board could also cause this problem.
Good luck
Oct 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code f24
F24 indicates a water temperature sensor error. If during the wash cycle in the water-heating step, the water temperature sensor (NTC) value is out of range the F24 error code will display.
Possible causes:
  • Too cold of water or hot water is turned off
  • Temperature sensor failure or loose connection
  • Control board failure
Dec 18, 2008 | Kenmore Washing Machines
Washing Machines Logo
Top Washing Machines Experts
