Question about Building Materials
Garage door partially opens and closes.
Everything else works. I inspected all the hardware and it appears to be okay and it's operation other than this problem.
    Problem Solver:
  • 13 Answers
Check to see if the child safety light are on on the side of garage
Posted on Nov 21, 2014
How to get my garage door to open all the way?
Three blinking lights & door won't close by Candi
(Winston-Salem, NC)
Garage door will not open and close with remotes. Three blinking lights occur when we try to close door. What does this mean? It is a Linear unit.
I will assume you mean that your garage door will open with your remote but will not close. It should close if you press and hold the wall control button until the door is fully closed.
If that is the case, the 3 blinking lights indicate that your garage door's infrared safety beams are not properly aligned.
1) Check that the operator has power. The green lights on the sender and receiver should be lit.
2) If the receiver's green light is on, but the red light is off, the receiver has power but is not detecting the infrared beam from the sender. The red light might flash when the beam is partially detected. This can be caused by
mis-alignment or something blocking the beam.
Adjust the safety beam sender and receiver while watching the receiver's red light (stay out of the beam while aligning it). When the red light stays on, the beam is aligned and your garage door should operate normally.
http://www.linearcorp.com/pdf/manuals/LCO75.pdf
NOTE: If the receiver's red light remains off, check for:
1) Dirt on the receiver's lens,
2) Sunlight shining into the receiver's lens,
3) A short in the safety beam wiring (from staples or at the operator terminals).
Jun 15, 2014 | liftmaster Garage Door 1/2 Hp
The light on the Garage door blinks but doesn't stay on.
(Winston-Salem, NC)
Dec 02, 2013 | liftmaster Garage Door 1/2 Hp
Garage door light blinks but doesn't stay on
(Winston-Salem, NC)
The door only opens partially and then stops
IF THE DOOR WORKS WELL MANUALLY.
ADJUST THE UP SENSITIVITY ABOUT 1/8 TURN AND TRY AGAIN.
HOPE THIS HELPS
Jun 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door keypad will close garage door but will not open it any suggestions?
If your hand remotes work okay and a new battery doesn't help the keypad it is time for a new one. Sounds like a weak battery though.
Apr 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 HP garage opener opens only 6 inches
Remove the cover and check the drive gear. It is white nylon and is just in front of the motor. It may be stripped. Take a close look at those door springs. They can sometime appear to be okay when one is broken.
Oct 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Auto sliding door wont completely open or close from the home possition. The door opens half way and the door closes half way.
The wire harness/track assembly below the door needs replaced. It is a fairly simple operation that can be done in your driveway or garage. If you have any questions on how to replace feel free to ask.
May 01, 2009 | 2005 Chrysler Town & Country
Garage door only works partly
some thing blocking sensor or laser is not in proper alinement
Feb 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't stay closed
Check the down limit:
 If the light bulb(s) on your operator are on the front and/or back, the limit adjustment screw is on the left side of the operator (looking from the back of the operator and facing  the garage door).. If the lights are on the sides of the operator then the limit adjustment screw is on the left side (looking from the back of the operator and facing  the garage door)
Jan 03, 2009 | Electrical Supplies
Building Materials Logo
Top Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
