Question about Iota Engineering Iota I-320 Emergency Ballast 1-2 Lamps 1400/700 Lumens
Hook-up 277volt neutral wire to i-320 ballast
Hooked it up to brown and white quick disconnect coming out from normal ballast.
Hardwire fridigaire electrolux gallery series stove top. Hooked black and red from branch to black and red from stove top. Neutral side hooked green and white from from stovetop to neutral side. Ho
Should be correct. Maybe it power supply problems.
Have you verify that the line you connected are receiving power on both hot legs ( Red and Black) and that neutral White wire) is actually connected to ground? Use a voltage meter and ohm meter to to do your tests.
Nov 16, 2014 | Kitchen Ranges
I needed to replace the pull switch, but in doing so the capacitor was disconnected and I do not know where the wires go. It's a five wire, 2 gray,1 green, 1 red, one brown. It's marked 10mfd/5mfd/250vac....
1 - gray
2 - brown
3 - green
L - should be black
The other gray should be connected by wire nut to the other grey to reversing switch.
Also, you should have two wires, white & black w/ white stripe, at bottom of fan to hook up light if needed.
Oct 08, 2013 | Hunter Dryers
The wires on the timer of my cooker have been disconnected now my son can not remember which way they go back on there are two pins on the timer N7 and L8 and four wires one orange and spare pin one blue...
Sounds like the orange and blue wires are attached to the spare pins. If so that leaves the brown and the white. The L in the L8 probably stands for line. Line is active and the brown wire is always the active. The N in the N7 would normally mean neutral. Neutral is normally blue but if there is only one wire left that must be where the white goes.
Feb 08, 2011 | Stoves 600SiDOm Gas Kitchen Range
My 4ft fluorescent fixture has whiye and black wires that have been connected, hot and nuetral but it also has a red (brown) wire ? where does this go.
They make dimmable ballasts.
The Lutron dimming ballast shows an orange wire, not a brown >> but other manufacturers might call for different color.
I am guessing here, but ballast should work with Black Hot and White Neutral
I want you to answer back and say if the ballast works with just white and black, Thank you.
Here is a 3-way dimmer to control florescent ballast
Oct 18, 2010 | Lithonia Lighting Lithonia Ps300...
Need to hook this up to a lutron eco-t528-277-2 ballast which only has a hot,dimmed hot and neutral
If I understand correctly, you have Leviton florescent dimmer
And you want to connect dimmer to Lutron ECO-series ballast
This is the ballast with 3 wires: Hot dimmed, Neutral and Hot
Is this your dimmer???? Has Black, White, Red, Yellow-red, & Orange
Here's how to do it:
Dimmer yellow-red is not used except for 3-way switch >> cap it off with wire nut
Dimmer orange wire connects to ballast Dimmed Hot
Dimmer red wire connects to ballast Hot
Dimmer white wire connects to ballast Neutral
Those are your wires going to ballast. As you can see, you need 3 wires going to florescent fixture
Next, let's focus on Dimmer:
Dimmer green wire goes to bare ground wire
Dimmer black wire connects to Hot from breaker box (we'll test for that next)
Finally the Dimmer white wire connects to ballast Neutral as discussed above BUT is also has to connect to Neutral from breaker box
This means the Dimmer white wire is connected to 2 wires >> one wire goes to florescent fixture and the other wire comes from breaker box
So which wires come from breaker box??
It should be a black and white wire.
Let's test to find Hot and Neutral that come from breaker box.
Mark your wires.
Disconnect all the wires and separate from each other
Turn on power
Use ordinary tester
Tape tester leads to wood sticks so hands stay away from electricity
Power is on
Test each wire to bare copper wire
When tester lights up, that is Hot from breaker box ... this wire connects to Dimmer black wire
Now, test the hot wire to each of the other wires
When tester lights up, that is Neutral wire ... this wire connects to Dimmer white wire, and also connects to Ballast neutral.
Connect one wire at a time, and it will work.
Oct 04, 2010 | Leviton Decora Light Dimmer Switch
Black, white, red, wires on motor and the connect
White is always neutral so I am going to say hook it to brown, unless you have another white wire.
Black on a motor is usually high speed, so hook it to black
Red is usually low speed to hook it to yellow. If you do not get
high speed then hook black to yellow and red to black
Jul 16, 2010 | Heating & Cooling
WIRING DIAGRAM
The light box in your ceiling should have two or three wires. Black and White, or Red, Black and White.
If you have two wires (one switch to control everything):
Black is power - hook this to the fan's power wire (and the fan's light wire if applicable)
White is neutral - hook this to the fan's neutral wire.
If you have three wires (two separate switches):
Red is power for the light - hook this to the fan's light wire if applicable
Black is for the fan - hook this to the fan's motor
Sep 18, 2009 | Panasonic FV-08VQL4 Fan
Fan light kit will not function
Have you taken a VOM (Volt-Ohm Meter) and checked to see that the "two wires" of which you speak actually have 110-120VAC on them?
I bet they don't and I bet they don't because "up top" (where the connections in from the ceiling box, the BLUE wire (might be brown on some fans) is not hooked up. Unless you have separate switches at the wall, the blue and black wires coming out of the fan must be combined and hooked to the BLACK wire coming out of the ceiling box. White (neutral) goes to white, and green goes to ground.
Good luck, and always OBSERVE practicable safety precautions.
Mar 06, 2009 | Hunter 23827 Classic Original White 42"...
Trane Weathertron XE1000 Thermostat Wiring
Check to see if you have the system switch accidently on em. heat. The way you have it wired is correct except for the having brown on e. disconnect brown wire and cut ofbare end just in case they have the wire hooked up for constant run on roof.
Feb 08, 2009 | Heating & Cooling
Iota Engineering Iota I-320 Emergency Ballast 1-2 Lamps 1400/700 Lumens Logo
50 people viewed this question
Top Iota Engineering Electronics - Others Experts
Are you an Iota Engineering Electronics - Other Expert? Answer questions, earn points and help others
