Question about Radio Communications
What would the possible bluetooth codes be for a Proton PRH-D7000UB bluetooth radio,been struggling since I lost my manual
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 32 Answers
If you haven't change the passcode already set, it will be either 0000, 1234 or 2580.
it might be also a pairing bottom you should press on it too.
this is a standard steps (there is no manual found by the way)
Posted on Nov 21, 2014
Struggling to depress pistons on rear brakes. Hoave used G-clamp, Made a special tool with nut and bolt. Still struggling.
The pistons in the caliper should retract without much effort. A "C" clamp is usually all you need to do it. I suspect you have a seized caliper or possibly a kinked or crushed brake line (preventing the brake fluid from returning to the master cylinder when the piston is depressed) feeding that caliper - but isn't very likely.
Aug 16, 2016 | 2004 Proton Gen-2
Replacing rear brake pads on Proton Gen 2 car. Struggling to get pistons back into sleeve
You'll need a brake piston wind-back tool, Sykes Pikvant make them, can be bought from most automotive parts stores
Aug 16, 2016 | Proton Cars & Trucks
Have a 2000 proton satria manual 4g15 engine it will only get to 30km. is it the ignition coil making this happen or something else??
it is more than likely in limp mode
run the fault codes to check for a possible failure of engine or transmission components or sensors
May 07, 2016 | Proton Cars & Trucks
How do find the code for my ford radio m176389 ? I'm really struggling
Only way to find a lost code , you must contact your local ford dealer, then they have to ask Ford HQ , where the Ford was made .
Mar 14, 2015 | Ford Cars & Trucks
Car Radio/CD player -Clarion R.D.S./EON- numbers on back PW546174 - I need a manual please
Hi
Go online to MANUALSONLINE.COM put the brand name in its place and the the code.
kolbbrun
May 14, 2012 | Goodmans CD car radio GCE358MPT CD Player
I have a Proton 300 table radio - the big one, not the clock radio. One day, the tuning knob did not change the frequency. I thought the radio was a digitally tuned radio. I opened it up and found a...
I have a Proton car but I have never heard of a Proton radio.
As a matter of general interest, the flywheel tuning system was used on early radios before the superheterodyne system brought us agc lines and such sophistications. Selecting another station was a noisy business and flywheel tuning allowed the dial to be traversed quickly with a flick of the wrist. Those flywheels were heavy and mounted in ball bearings...
The trouble with trying to obtain spare parts for radios is mostly you can't. The manufacturer uses mostly bought-in standard electronic and hardware components and makes as little as possible, apart from the cabinet, the circuit boards and a few other bits and pieces and then will assemble what is generally regarded as a consumable item. The manufacturer's interest fades quickly when the warranty expires. Whatever (few) parts remain will be priced not to sell in order to build in obsolescence.
It is mostly expected that minor repairs will be handled by local repairers using standard parts until it becomes uneconomic or obsolete.
It might be possible to locate another plastic "flywheel" but searching would be a mammoth task. The number might not be a part number, might have been made by anyone and Proton is such a popular brand, model, type a search would not be easy.
The best alternative is to repair the original, adapt something else to do the same job or have a replacement made or devise another method of doing the same job.
Good Luck!
Apr 15, 2017 | Audio Players & Recorders
My Proton 320 radio has stopped working, although the clock function still works. Is this a simple fix? Where could I find a manual?
Unfortunately, Proton discontinued these a very long time ago. There is not very much information available about them. The cause for the radio malfunction could be a number of things. One possibility is the switches. There is a foam gasket around the switches that degrades over time. If pieces of it get stuck inside the on switch, or lock the off switch, it would prevent the radio from working. You could try taking it apart and use a can of compressed air to clean out the switches. I had a problem with the radio turning on all by itself and the compressed air cleaning solved it.
Oct 23, 2010 | Proton R5A Clock Radio
Lost my 'off' ' button on my Proton 320 clock radio!
No need to worry, you can buy adjustable knobs and at radioshack and ebay. However if the button broke off you need to go in and replace it.
Sep 29, 2010 | Proton R5A Clock Radio
Radio Communications Logo
48 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
