Question about Emporio Armani Mens AR5950 Brown Chronograph Dial Watch
How do I reset emporio armani ar5950 chronograph to zero after replacing the battery.?
  • Emporio Armani Master
  • 18,391 Answers
Pull crown out to second position ,then press bottom button till it goes to zero then push crown back in job done,,if you want to do both dials press and hold bottom button so they rotate faster to zero then press one press at a time...
Posted on Nov 21, 2014
2 Suggested Answers
SOURCE: I have an Emporio Armani
pull te midle buttom out then press reset it il reset on 0 then the button midle bach in
Posted on Mar 03, 2011
Battery size for emporio armani ceramic ladies watch
  • To determine battery type: open back
  • Locate battery holder and identify type. Note battery mounting
  • Place opened watch in plastic bag to keep it dust-free while you obtain a replacement battery
  • Remove watch from plastic bag and install new battery
  • Check operation
  • Install back
Finally, reset watch as necessary
Aug 28, 2016 | Emporio Armani Watches
HOW TO RESET STOP WATCH TO ZERO
What you need to do is to pull the crown to step 2 (full out) and then push the start button. Then the second hand will start moving one tick a time all through the dial. Keep pushing it until you reach to zero.then push crown back in, That's it.
Feb 18, 2014 | Giorgio Armani Emporio Armani Sport Ar0532...
Stopwatch second hand not reseting to zero ar 0532
PULL THE CROWN OUT TO SECOND POSITION THEN PRESS THE START BUTTON TILL IT GETS TO ZERO THEN PUSH CROWN BACK IN
Sep 13, 2013 | Giorgio Armani Emporio Armani Sport Ar0532...
How to set up the chronograph needle
acabo de adquirir un reloj armani AR0431 segui las instrucciones ajuste fecha y hora, pero no trabaja..que pasa a caso no bienen de fabrica con la bateria instalada? o cual podria ser el problema?
Sep 11, 2012 | Giorgio Armani Emporio Armani AR0584 AA...
How to manually wind an Emporio Armani watch - AR0566?
You cannot wid up this watch, it is has a quartz (battery operated) movement!
Go to http://www.emporiowatches.co.uk/catalog/pages/emporio-armani-watches/0566.php to see a full description of this watch.
Aug 02, 2011 | Giorgio Armani Emporio Armani AR0566 Watch...
CHRONOGRAPH AND CENTER STOP SECOND DONT WORK PROPERLY
This may be due to a poor battery connection, a low battery, a dry movement, or debris in the movement. I strongly recommend taking it to a local Certified Master Horologist for assessment and repair. Estimates are usually free.
Jan 12, 2011 | Giorgio Armani Emporio Armani AR0584 AA...
How do i reset to zero the chrongraph hour hand in Emporio Armani AR 0671
mcdevito75 here, Just a guess, but here goes, press to make the chrono to work, now press to make it stop, now press that same button to have chrono return to zero. Hope this helps.
Jul 18, 2010 | Giorgio Armani Emporio Armani Ar0562...
Emporio Armani AR0534, How do you reset the Chronograph function of this watch?
If it is not working you may need to "AC" the watch. This generally needs to be done when the battery is replaced. This will reset the circuit board and allow the watch to work correctly. There maybe instructions on the inside of the back lid to do this but i always recommend having a watch maker/technician doing it because of the delicate nature of the circuit board.
If the sweep arm is not resetting to the 0 position then you can set by....
pull the crown out to the first or second set position then press and hold down the start button until the sweep arm is in the position you want.
Sep 11, 2009 | Giorgio Armani Emporio Armani Classic...
Emporio Armani Mens AR5950 Brown Chronograph Dial Watch Logo
308 people viewed this question
Top Emporio Armani Watches Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you an Emporio Armani Watch Expert? Answer questions, earn points and help others
