Question about Sony Office Equipment & Supplies
How to reset to factory default settings on projector sony VPL-DX126
On the projector VPL-DX126 I changed defaulth password for setup on the Web Control Window of the Projector. How to reset to factory settings (user name: root, password: none) beacuse i lost password that I set
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 32 Answers
Here's the user manual of the prjector:
https://docs.sony.com/release/VPL-DX126_DX146_DW126.pdf
i've readed it and i guess you should push the reset bottom in the remote.
Posted on Nov 21, 2014
Testimonial: "First thank you for your response! I read that manual and it sad that if I forget my pass for web app to contact sony With reset on the remote you can only reset few things like projection of picture not things like I need I contacted Sony already i I have option to send my projector to UK :D or to put my projector on the internet for remote access from them"
I waynt to remove password projector
According to the manual listed below you can :
(1) Enter the OSD menu.
(2) To execute "Reset" function.
This resets all the user settings to default.
Press "Play" to change the "Administrator Password".
The factory default of "Administrator Password" is "1234".
Service Manual link
Download manual
Mar 12, 2015 | Acer P3250 Multimedia Projector
I need to reset the lamp life timer on my projector, but it requires a password. We never set a password. Is there any way around this?
From the manual: " User name and password are not set in the factory " . Don't enter anything.
Manual for the projector here:
http://www.projector-manual.com/manuals/eiki/EIKI_EIP-4500_DLP.pdf
Jul 22, 2014 | Eiki EIP-4500 DLP Projector Multimedia...
I have a Sony VPL-CX61 Multimedia Projector. I just changed the lamp and I cannot get the "please replace lamp" message to go off.
When you use a projector it automatically keeps a timer of how long the lamp has been used for. The message that comes up on screen saying "please replace the lamp" comes up not because it's some how sensing that the lamp is getting old, but because the lamp hours gets to a certain number (usually up around 1500 hours). Because of this when you replace the lamp you need to reset the lamp hours counter, or the projector doesn't even know you've changed it. Every projector does it this way, and they all do it a different way, I googled the model you gave us and found this set of instructions on how to do it, so give it a go.
Reset the lamp counter hours of operation for the projector SONY VPL-CX61
Using the remote commander while the unit is powered up, press "ENTER", "ENTER", "LEFT"
and "ENTER" in sequence. A prompt will appear on the screen asking if you wish to enter the factory mode.
Press the "UP" key on the remote and the unit is now in service mode. This sequence will add two new groups
to the customer setup menu. Press the "MENU" button to view.
Whenever the lamp is replaced, the lamp timer should be reset. With the unit in the "factory" mode, press
"RESET", "LEFT", "RIGHT" and "ENTER" on the remote commander. Verify the lamp hours have been reset to
zero in the service menu.
Hope this worked for you,
Mar 23, 2011 | Sony VPL-CX61 LCD Projector
My projector sony vpl cs6 projects yellow
reset the settings to factory default and change your cable. if that doesn't help, the polarizer filter on the blue lcd panel is fried due to excessive dust and heat. the optical engine will need to be replaced.
Dec 07, 2009 | Sony VPL CS6 Multimedia Projector
How to disable power on password on Sony VPL-ES2 LCD projector?
Hi there! I'm assuming you're able to enter the password so that the unit comes up...Go into the menu selection called "Initial Settings". Choose the option called "Security Lock" and pick the "off" menu item. Exit out of the menu and power down the projector. Re-start the projector and it should have no password activation. If you need the user manual, let me know...Hope I assisted you successfully!--Rick
Sep 09, 2009 | Sony VPL-ES2 LCD Projector
Sony vpl-hs20 cineza projector- reset lamp counter
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS3.
1st thing to check - is the cover properly/completely closed - this can stop the projector from working.
Connect the power and set the projector to standby mode.
Press these buttons on the remote control in this order, for less than 5 seconds each.
Reset - Left Arrow - Right Arrow - Enter
This is required, to reset the lamp timer.
Also, something I found interesting from the internet - lamp life isn't when the bulb dies, but when a bulb has lost 10% of its brightness - so you might well be able to reset the timer and get much more use from the bulb - the image just wont be as bright.
Jul 19, 2009 | Sony VPL-HS20 Multimedia Projector
How to reset lamp on sony lcd projector xga vpl-px20
After replacing lamp, connect projector AC power cord and turn the projector in standby mode.
Press following keys on control panel for less then 5 seconds each..
RESET, <==, ==>, ENTER.
That will reset lamp timer in projector.
Thanks.
Jun 01, 2009 | Sony Office Equipment & Supplies
Lamp time resetting
HI
Not sure if its in the handbook but you can download a copy from here
http://safemanuals.com/user-guide-instructions-owner-manual/SONY/VPL-CS5-_E
Feb 21, 2009 | Sony VPL CS5 Multimedia Projector
Sony
Turn on projector and Press following button on remote in following order for less then 5 seconds..
Above procedure is written in user manual page-49
If you need user manual of VPL-HS50, click Sony Support.
Feb 11, 2009 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Sony projector - replacement lamp counter
  • Set the projector in standby mode.
  • Press the following buttons on remote control in following order for less then five seconds each...
  • RESET,
  • ENTER
Lamp timer is reset now.
This is also mentioned in user manual page 50
Thank you.
Dec 12, 2008 | Sony LMP-H130 Projector Lamp Projector...
635 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
