Question about Cell Phones
How do I remove an overlay #1: 720×480, 160 dpi on my phone
Nothing at all for the moment
How do I take overlay off my screen it says overlay#1 1280×720 DPI.
It looks like you are using an alternate keyboard. Delete or disable that keyboard to see if your problem continues.
Apr 19, 2015 | Apple iPhone Smartphone
How do I replace the oven control overlay
Is it a range or a bulit in oven? Unplug or turn off power to your range/oven. If it's a range, take off the back of the range or at least the control panel area. Remove the 4 screws that hold the control panel in place. You may or may not have to remove the wires that go the the oven control, but if you do, take a picture of them with your digital camera or smart phone. Now, carefully lift up a corner of the overlay using your finger nail(s). Lift it just enough to put the round shaft of a phillips screwdriver between the overlay and the controller. Now start twisting the screwdriver so it feeds itself between the overlay and controller. This will allow it to separate the 2 parts smoothly so the paint won't separate from the overlay.
Aug 10, 2014 | Kenmore Kitchen Ranges
Can I get a 300 dpi still shot using the Canon S5 IS?
DPI is short for Dots Per Inch and it actually refers to printer dots per inch. These days, when used in photo software, it means PPI, which are pixels per inch. DPI and PPI are two different things, yet often DPI is used when PPI is meant, so read its usage in context.
Dpi (actually ppi) is only important in case of printing. When you open a picture in Photoshop a dpi-number is mentioned. Don't pay attention to it. It doesn't tell you anything, you can change it in any number you want, it doesn't change anything of the picture. But beware: you have to uncheck the resample-box! Resampling means calculating a new amount of pixels. The moment resampling is off, you can change the dpi-number, the according printing-measure is given. It also works the other way around: change the printing-measure, the dpi-number of the picture will be shown.
Jul 30, 2014 | Canon Cameras
Ledttering to small.dont know how to change to larger setting.
First, right click on your desktop and click on Personalize. Alternatively, you can go to Control Panel -> Appearance and Personalization -> Personalization. In the Personalization window, go to the left pane and click on Adjust font size (DPI). If UAC is turned on you will need to make an additional confirmation so that the DPI Scaling window will launch. You can choose the default scale of 96 DPI or a larger one of 120 DPI, which makes the text more readable. If these two options are not enough you can click on the Custom DPI button and choose another size (DPI)
I hope this has helped
Jul 30, 2011 | Computers & Internet
Sir hw can set my dpi setting i can change dis due to this reason my font size wii be long nd if i was triyin to bring default then its is nt possiple by me so give me solution how can set as default my...
Hi skyabhi_cold, to change the {DPI Settings}.
Right click on a 'empty area of the "Desktop" screen.
paul7of9_183.jpg Select the "Personalize" shortcut when the window open!"
Next, in the [right column] "Tasks" area.
Click on the "Adjust font size (DPI)."
Now, click on the Default scale {Radio Button}.
_987.jpg "You can also make "Adjustments to Customize the {DPI}."
_989.jpg "Drag the "Ruler" for (Pecentage size = 100% < 75%...}.
Click on the "Apply, and OK buttons; when finished!"
!Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
Mar 16, 2011 | Computers & Internet
Update Logos & signatures
Someone may have installed the logos and signatures through an overlay. You can update that using the same way they installed it - using the driver, through the Overlays tab.
Jul 26, 2010 | Lexmark T632 Laser Printer
Frigidaire FEF369CGSA ramge- replace clock overlay/control labels
Hi Dagmail543
You can only access the old unit by removing it from the back of the panel.Some screws and clips (base at the two sides) The clock is usually secured with screws. - remove old unit replace with new - no peel or scrape usually necessary
Regards
Aug 25, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Teamspeak Won't Work with Vista
Look at TeamSpeak overlay with PlayClaw. The main task of PlayClaw is to record game video but it have ability to show Teamspeak & Ventrilo overlays. Works fine with Vista/W7, but only one restriction - voip client must be 32 native (not 64) app. Windows may be in any bits: 32 or 64
Nov 21, 2008 | Computers & Internet
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
