My sound only works when headphones are in?? - Computers & Internet
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 32 Answers
First of All, check if you have installed the speaker's drivers
you can make a driver's test on your computer here:
Easily explore your PC
If that OK, check if the volume is more than 0
If all that already done, you might think if the speakers are working properly or not.
Posted on Nov 21, 2014
No sound without headphones sound with headphones
your device speaker or head phone socket is defective.
Aug 04, 2014 | Computers & Internet
When I plugin my headphones The sound dosn't go to the headphones.
First, try plugging in different headphones. If those work, then your headphones are broken and you need to replace them.
If those don't work, then please check to make sure you're not plugging them into the microphone jack - you'll see two identical plugs, usually the headphone one is marked with a pair of headphones.
If you're plugging known working headphones into the correct port, then your computer must logically be the broken thing.
Dec 20, 2013 | Motorola Mobility S9 Headphones
Headphone jack does not work
The headphone jack on the computer connects to the sound card, a hardware device that controls audio input and output on the PC. The card contains a digital-to-analog converter that converts analog audio into digital signals and visa-versa. The performance of the headphone jack, therefore, depends on how well the sound card functions; if the card doesn't work, then the headphones connected to the PC won't output sound. Reconfiguring the audio settings will often fix problems with audio output on the headphone jack, but if the former fails to resolve the issue, replacing the sound card in its entirety is sometimes the only means of repair.
Click "Start." Enter "sound" into the search box. Select "Sound" from beneath Control Panel. Double-click "Headphones." If no "Headphones" option is available, double-click "Speakers." Click "Properties" on the General tab. Check the Device Status field for errors. Look up the message on Microsoft Support for more assistance, if applicable. Close the window if the Device Status field reads "This Device Is Working Properly." Go to the "Levels" tab. Click the speaker button to unmute the volume if the icon contains a red circle-backslash symbol. Drag the top slider to the right to increase the headphone volume. Go to the "Enhancements" tab. Check "Disable all Sound Effects." Go to Applications, and then clear "Allow Applications to Take Exclusive Control of This Device." Click "OK" to close Headphones Properties or Speakers Properties. Test the audio. If the headphones fail to output sound, unplug the headphones from the computer. Reconnect the headphones to the PC. Headphone jacks are color-coded lime green on most PCs. Look for the headphones symbol if the jacks are not color-coded. Plug the headphones into the line-out port on the back of the computer if the headphone jack on the front of the PC fails to work, or visa-versa. Test the headphones. If headphones still won't emit sound, the sound card most likely requires replacement. b> Replacing the Sound Card b> Shut down the computer. Remove the power cord from the back of the PC. Disconnect the keyboard, mouse, monitor and all other peripheral devices. Loosen the screws found on the back of the case, then slide the cover panel off of the case. Touch the chassis to protect the hardware from electrostatic discharge, or ESD. Set the computer on its side. Locate the sound card found on the opposite of the audio jacks and loosen the screw that secures the card to the computer. If no expansion card is located opposite the jacks, the computer uses an integrated sound card which can't be removed. Remove the new audio card from its protective packaging. Line up the card with an available expansion slot on the motherboard, then push the card down into the slot to install the new audio jacks. Screw the card to the computer case. Reassemble the computer. Turn on the PC. Boot in to Windows and insert the CD that came with the new expansion card. Follow the onscreen instructions to install the sound card software to the computer. Plug the headphones into the new line-out jack. Hope this helps.
Jan 21, 2013 | Acer Aspire Computers & Internet
Acer aspire one sound not working
Fix the headphone jack to contact headphone pin. Fix the speaker contact in headphone jack to get sound to speaker when headphone is not plugged in.
May 23, 2012 | Acer Aspire One Netbook
Sennheiser RS126 headphones/base stopped working
Broken audio cable entering the transmitter or audio jack plug.
Power supply plug loose / faulty power supply.
Nov 10, 2017 | Sennheiser RS 120 Consumer Headphones
i had the same prob. just try blowing into the headphone jack or unplugging and plugging back in the headphones into the headphone jack a couple of times. there must be some sort of problem with the headphone jack that makes the phone think that the headphones are still in or something.
Jun 24, 2009 | Samsung Eternity Cell Phone
Headphones will not work but speakers will.
Plug the headphones directly into the speaker port on the sound card, check for a mute button on the headphones. try another set of headphones to double check wether the first set is working.
regards..
Apr 05, 2009 | Dell Dimension 4600C PC Desktop
Sound still appear at speaker even when headphone was installed
Hello Again,
When you Plug in HeadPhones into the Laptop the Sound Playing should automatically Bi-Pass the Speakers and go Straight to the Headphones
-Unless there is a Faulty Input for the Speaker/ Headphone, Try Pushing in the Headphones More to see if the Speakers Turn Off
Hope this Works --P3NGYJ03
Jan 23, 2009 | Audio Players & Recorders
NO SOUND WITH HEADPHONES
Update driver, gotohttp://www.via.com.tw/en/support/drivers.jsp select OS and choose Audio then VIA HD Audio Codec 1708b. If this does not work, click mute and un-mute ontaskbar when there is no sound. I have had the same problem (sometimes) when using certain headphones,and pausing video, then playing video,sometimes the headphones have no sound, but if I unplugged headphones, the speakers work.I plug headphones back in, no sound. So i press the mute button twice.
Jul 23, 2008 | Everex StepNote NC1500 Notebook
Why our head phones on Computer are not working
Is there a switch to turn on the headphone port? Is there a control on the headphones to adjust the volume (on a volume level on the side of the laptop)? Also, when the headphones are plugged into the laptop, go into your sound settings and turn up the master volume (and wave volume if it is low.. If that works, make sure to turn it back down when disconnecting the headphones).
Also, do the headphones work in another device (stereo, etc..)?
Mar 26, 2008 | Toshiba Satellite P105-S6104 Notebook
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
