Question about Building Materials
Lay underfloor heating with laminate flooring
5 Suggested Answers
Therinnaiguy
  • 1420 Answers
SOURCE: siemens underfloor heating sdosent work
check your circuit breakers to see if the floor is getting power to it. Consult your operation guide to see if there is an internal fuse.
Posted on May 30, 2008
SOURCE: Shark Floor Cleaner streaking on pergo laminate floor
Start with a clean pad. A dirty pad wil spread the wet residue around and strek the pergo. After steaming use a clean microfiber dust mop to buff the pergo. It will dry and shine yur laminate.
Posted on Jan 14, 2009
Sea Breeze
  • 4654 Answers
SOURCE: My amana frige leaks at the bottom, it is a bottom
In your shuffling of the refrigerator you may have knocked the condensate drain away from the pain near the compressor that evaporates the water back into the air inside your home. Or you may have the refrigerator leaning in a way that the water pools up near the condensate drain pipe beginning in the rear of the freezer and has frozen over and causing the water to drain over the condensate collector pan behind the rear wall of the freezer. I have more, Sea Breeze
Posted on Oct 16, 2009
  • 13 Answers
SOURCE: how to lay laminate flooring
start against your longest wall. clip three rows together and slide lightly against the wall. put shims of wood in the gaps between the wall and new floor to make it solid. continue adding planks from there.
Posted on Jun 11, 2010
NOt t all happy with my 1year old style selections laminate floor. It creaks with every step. Has hooked up
contact the floor layer who did the job and check on the work and material warranty
Sep 16, 2017 | Building Materials
My radiant floor heating suddenly stopped working. Wall thermostat is functioning normally. GFCI test is working fine. What can I check next?
Monica, There might be a break in the wire mat, you or a electrician will have to check with a digi multi meter.
Links below show how.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to test underfloor heating with multi meter
How do test the resistance of my electric underfloor heating system
http://www.suntouch.com/support/troubleshooting
Testing underfloor heating
Mar 02, 2016 | Heating & Cooling
Is Pergo the same as laminate?
Pergo is the name of a specific manufacturer of laminate flooring
make sure you follow all the instructions in the package when installing a laminate floor. They all have slightly different methods for success.
Jun 29, 2014 | Dream Home - Ispiri 12mm Americas Mission...
Underfloor heating not working
Along with warming up the entire area, people also look to warm up the floor, which can otherwise be harshly cold. Underfloor heating sdystem is the most consistent form as it evenly warms up the complete open space. Infrared Heater Room Heater IR Heater Magneto
Jan 26, 2014 | Heating & Cooling
Home comfort protection plan
Direct Energy knows that maintaining your Texas home is essential to your family's well-being. You can't afford to put off protection until disaster strikes, so we've created protection for your home's electrical, plumbing, and heating and air conditioning systems.
Our home protection plans deliver security by combining preventive and repair services for your home's most fundamental systems, including:
Electrical wiring
Plumbing lines
Priority scheduling with us for all appointments
Surge protection
Heating and cooling systems
Our home protection plans remove the anxiety of unanticipated costs, while our certified technicians are ready to assist you with respectful, professional service and high-quality equipment. Because we view the money you spend on home service improvement as an investment in your home and your comfort, we're committed to helping you make it worthwhile. You can choose from our plans for Heating and Cooling systems, Electrical wiring, and Plumbing lines. Direct Energy's Repair & Maintenance Essentials Plan provides annual features to catch small service issues before they become critical, $500 insurance for every repair job*, emergency customer support any time you need it, service visits with no charges and no deductibles, and so much more.
if you want protect your roof leaks so you can apply EPDM Coatings :
Watch Corporate Video
Jan 20, 2014 | Audio Players & Recorders
What are the advantages of laminate flooring over hardwood flooring?
First, you can get the exact visual design that you wanted and it will cost you considerably less. Second, laminate flooring can be installed above and below the grade unlike hardwood flooring. Moreover, the laminate flooring is installed without using any nails or glue which make it much easier to it yourself. Furthermore, laminate flooring is extremely durable, easy to maintain and can be replaced easily.
Feb 06, 2013 | Building Materials
I have just installed underfloor heating with 4 zones. I also have the existing radiator system. The radiator system is currently programmed to come on and off twice a day but has no room thermostat. We...
You say you have3 rooms on the underfloor system that will probably require different temps. You said you have 1 zone valve for the under floor system. You can not control all the rooms with different thermostats and only 1 zone valve. You need more information and professional help here. I can give you more advice too...
Jun 22, 2009 | Honeywell Programmable Thermostat Heater
Siemens underfloor heating sdosent work I set the program or put it on continuous and the tiled floor dosent get any hotter
May 30, 2008 | Heating & Cooling
Building Materials Logo
76 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
