How do I fix the error code C2553
Not done any major things just restarted and removed & replace toners
4 Suggested Answers
  • 118 Answers
SOURCE: error code E000001-0003 canon clc2620n
it is a fusing/fixing error try this on the control panel press * with head 2&8 together *with head >copier>function>clear>err>ok turned off/on the machine hope this help
Posted on Oct 03, 2009
darkpain
  • 316 Answers
SOURCE: get code 004 332 restart printer. have removed the
Hello,reseat and clean the four toner cartridges, verify the orange plastic covers have been removed, and verify the cartridges are fully locked into place, .This is the procedure:
1. Press the Menu button and press the down arrow until Replace Toner appears, and then press the "ENTER" button.
2. Press the down arrow to choose the appropriate color toner cartridge and press the "ENTER" button.
Note:If the Menu button is inaccessible, begin replacing the toner cartridges with step number 3.
3. Open the front cover.
4. Lift the handle of the appropriate colored toner cartridge and remove the toner cartridge.
5. Gently rock the toner cartridge from side to side.
Note:Rock the toner cartridge over newspaper as there may be some toner leakage.
6. Gently wipe the exterior of the toner cartridge with a dry cloth.
7. Verify the mag roller has been removed.
Note:Grasp the orange strap, peel the tape away from you, and then, with the tape free, pull the blue strap toward you.
8. To reinstall the toner cartridge, align the arrows on the cartridge with the corresponding arrows on the printer, guide the cartridge in until it snaps into place, and then push down the right lever to lock the cartridge in place.
Note:Ensure each cartridge lever is fully pressed down into the locked postion.
9. Close the front cover.
10. Repeat steps 1 through 8 until all toner cartridges have been reseated.
Good luck
Posted on Feb 05, 2010
  • 906 Answers
SOURCE: I HAVE SAMSUNG SCX 4300
Good day Sir,
All you have to do is to replace the toner cartridge with a new one and make sure the cartridge is genuine to prevent toner errors.
thank you.
Posted on Aug 05, 2010
How can I solve error code c255A
From another site
Details Subject:
C-255A (C255A), C-255B (C255B), C-2559 (C2559) or C-255C (C255C) at power up.
Description:
C-255x code at power up.
Solution:
CAUSE: The K (black) IU (C-255C) has failed. The M (Magenta) IU (C-255A), Y (Yellow) IU (C-255B) or C (Cyan) IU (C-2559) is not fully seated or has failed.
SOLUTION: Replace the K (black) IU (Item #A0DE02F for the bizhub C203/C253 and Item #A0DE03F for the bizhub C353). Reseat the color IU and if the problem persists, replace it. Item # Color IU Model
A0DE0CF Magenta bizhub C203/C253
A0DE0DF Magenta bizhub C353
A0DE06F Yellow bizhub C203/C253
A0DE07F Yellow bizhub C353
A0DE0HF Cyan bizhub C203/C253
A0DE0JF Cyan bizhub C353
SPECIAL NOTE: Solution contribution by Tom Kelly, Workgroup/SSD
Options:
None Specified Details Subject:
After toner installation, C255x code within a few hundred prints.
Description:
C2551, C2553, C2555 or C2557 codes.
Solution:
CAUSE: Toner is not supplied due to abnormal position of coupling.
Normal condition The coupling is blocked by bracket
May 03, 2014 | Konica Minolta bizhub C250 All-In-One...
ADD TONER ERROR
Good day, if your error is toner then make sure the small white gears on the back of the toner cartridge is turning, if they are not then replace toner bottle, if they are turning ask a technician to test the toner motor. If your machine displays error C6400 then enter service mode by pressing 10871087, now press 163 and OK, now restart your machine, if the code is still there then you should replace your fuser/fixing unit.
Apr 03, 2014 | Kyocera TASKalfa 180 Copier
I have konica minolta bc 250 its giving error c2553 pl help me
hello it is a image unit problem.
You got your toner/developer ratio out
Magenta will be low as we know.
Then while still in service mode run TCR supply
Re-check ratio % you should be OK
Change magenta image unit
Feb 28, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Error code E000001-0003 canon clc2620n
Oct 01, 2009 | Canon Office Equipment & Supplies
I have a Sharp AR-507. Error F2-00. How to fix?
It could also be the sponge roller in the toner hopper. The old ones started to deteriorate after a while so sharp modified them.
May 08, 2009 | Sharp AR-507 Copier
Error code 000019-0000
Hi Jeff the Error code for tha model is for the waste toner bottle. The waste toner bottle is located on the left side of the copier toward the rear of the copier. It is to the left of the fixing unit door / where you pull a jam from the fixing unit. It is held in by one screw. Remove the cover and you will see the waste toner bottle. Remove it and you may think it is not that full. The problem is that the neck of the bottle gets waste toner on it and it blocks the sensor. I would empty out the bottle in to a garbage bag and tie the bag up, as to not make a mess. Then make sure the neck of the bottle is spotless of toner then reinstall and turn the copier Off then back On and remove the paper jams and you are done.
Jul 12, 2008 | Canon imageRUNNER C3220 Color Copier
Service code 591
toner supply motor lock. The toner recycle coil in the back of copier is clogged up.Major pain to fix but can be done
Apr 26, 2008 | Ricoh Aficio 1013 Copier
Doc 12 Error Code
You Have to Clean a litle square reflexive patch that is located on the IBT Belt.
Just remove the waste developer botle, turn the orange handle CCW, remove the 2 external screws of the IBT Assy and pull out the Transport drawer and IBT drawer. clean the patch reinstall and thats it.
Feb 14, 2008 | Xerox DocuColor 12 Color Copier
Minolta Magicolor Fatal Error
Remove each of your cartridges one at a time and see if you can spin the toner rollers by pushing on the little white plastic gears with your finger. They will be tight but you should be able to spin the roller by moving the little gears around.
My printer started giving the Fatal Error Code 17H and I did all the removal of the four color cartridges and re-seating each of them to no avail. After removing each cartridge and checking to see if I could rotate the toner roller I found that the yellow cartridge was extremely tight. I took the cartridge outside and used a can of compressed air to blow all the toner off the roller and tapped the cartridge on all corners and shook it back and forth several time. Finally I was able to get the toner roller so that it would rotate when pushing the little white gears like the other three cartridges.
After replacing the cartridge in the printer it worked with no more error codes. Hopefully this will fix the problem until I can order a new yellow cartridge.
Keith
Jan 07, 2008 | Konica Minolta magicolor 2300DL Laser...
42 people viewed this question
k24674
jasbo
jasbo
