Question about Samsung Televison & Video
I have a Samsung plasma tv model HPS5053X/XAA. The picture turns to multicolored vertical lines then goes out. A few minutes later it comes back on then repeats the problem. If I'm right, it's the logic board. Is replacing that board a simple disconnect/reconnect job or is there soldering and/or splicing involved? Thanks.
    Top Expert:
  • Samsung Master
  • 74,136 Answers
Check all the COF [Chip On Film] connections for any loose contact with its sockets. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Posted on Nov 21, 2014
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
I have evenly spaced, rows of two vertical green and red lines from top to bottom of my vizio plasma P50HDTV10A
Somehow when switching between the tv and the dvd my wife encountered the pink and green, thin, parallel, vertical lines on the screen. The picture was visible with the lines. I turned the tv off and on but the problem persisted. Unplugged tv for about two minutes and after plugging it back in and turning it on the vertical lines very gone and the picture was back to normal.
Jan 12, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
My samsung tv model hps5053x/xaa is not finding my laptop via hdmi. i have been using it this way and then all of a sudden it isnt recognizing it now. what do i do what is the issue?
have a samsung plasma model HPS5053X/XAA i have it for less" -- because it falls within my area of expertise. I just need a few more details about your situation and I will get to work!
Jan 05, 2011 | Samsung HP-S5053 Television
Freezes turns white then turns off then back on
IF YOUR IMAGE IS ALL WHITE YOUR LOGIC BOARD IS DEFECT BUT IM SAD TO SAY DO NOT REPLACE THE LOGIC IT WILL ONLY TEMPORARLY SOLVE THE PROBLEM THE PANEL IS OVERLOADING THE LOGIC BOARD PANEL IS BAD
Apr 24, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
My Sharp tv has vertical multicolored lines that
my new lc60le820un sharp is doing the same thing after two weeks. i called sharp they want to fix it. i want a new tv. after a few minutes of this i hung up and and called hh greg to replace it with a sony. thanks hh greg the sony is fine
Nov 26, 2009 | Sylvania 32 in. Diagonal LCD HDTV
Exact same problem on 47" Regza: multicolored vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 23, 2017 | Toshiba REGZA 47HL167 TV
Samsung 42" Plasma -Black vertical line when turned on.
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner of that model samsung), I'd need a map & tools to know what's going on. Your best bet in this situation is to contact Samsung and let them recommend an authorized service center in your area. Sorry I can't be of more help, but this is a rather serious problem.
May 25, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Vertical colored lines no picture.
if the tv is less than a year old , call 1-800-SAMSUNG for warranty repair, the lcd panel is bad
Dec 17, 2007 | Samsung LNT3242H Television
Dark vertical lines on tv screen
If under warranty then of course use that.
This is a display problem. One solution someone knowledgeable in electronics can try.
This problem can be caused by a bad connection fitting of the flat cables on LCD controller board. Dis-connect the flat cables from the LCD controller(T-CON) and carefully reconnect them. Try the unit before reassembling the back cover. You may have to disconnect/reconnect several times to show improvements if this is the problem.
Sep 25, 2007 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Televison & Video Logo
69 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
