Samsung crt tv . Set is in stendby no power-on pless help me
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Posted on Nov 21, 2014
2 Suggested Answers
gopakumarg43
  • 74136 Answers
SOURCE: no power Samsung flatscreen CRT 21 inch TV
Check its fuse. Check the rectifier diodes. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Posted on Jan 18, 2014
Lights when system is on stendby mode. how to switch in systen power-on
This depends on the motherboard, but most will return to full power by default, when you press the "start button".
Check the manual for the BIOS settings that determine what action will trigger the "Wakeup", and set the BIOS for what you prefer.
Sep 29, 2015 | Computers & Internet
I am repear to LG crt tv FLATRON 21S42KS but foultS are VARTICAL SIFTING PLESS HELP SIR.
Sounds like main system chroma IC fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 30, 2015 | LG Televison & Video
Green power standby light
It sounds that the main digital board has been damaged. Contact any service technician.
Jul 11, 2013 | Toshiba 19HV10E 19 REGZA Multi System LED...
Model Sony KV-G21q2S Problem-STR 6707 has been changed. After an hour the went down. The fuse and STR 6707 are working. But no picture no sound. When plug in it gives "boo" sound for few...
This is the SMPS Power suply drive and the IC fails ONLY if there is fault in the circuit. You need to check on the SMPS section
check this link below for tips:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Next you need to check if the LINE output transformer has failed. If so this will have a higher current drain and so switch off the SMPS unit. check for the EHT drivers, capacitors in the HT circuit.
Jun 25, 2011 | Sony FD Trinitron WEGA KV-20FS120 20" TV
My Samsung 20" CRT model # TX-P2036 has power
May be you should press the channel button on the set itself or there is a problem with the eeprom of the set circuit.
Jun 15, 2011 | Samsung TXP2036 20" TV
Lost pin for samsung TV LE19R8
Hello
If you did forget the PIN of Samsung LE19R8, do the following.
Press the remote control button in the following sequence, which resets the PIN to [0-0-0-0]:
POWER(Off), MUTE,8,2,4, POWER(On).
This process will set your PIN to initial settings, and you have to set it to new passcode. OK.
Apr 13, 2011 | Samsung TXK2754 27" TV
32" Samsung TV, No Power or Sound, power LED on, flashes 3 times
Most likely the set has lost vertical sweep or the feedback from that circuit. This will shut the set down to prevent a horizontal line from burning the face of the CRT. This will have to be looked at by a technician.
Sep 11, 2009 | Samsung LN32A330 32 in. LCD TV
SAMSUNG STANDARD TV SET
maybe you have a blown fuse,try to have a look first inside,if you have a blown fuse then replace it with the same rating,if it blows again replace your power regulator
Jun 30, 2008 | Samsung TXJ2554 TV
SAMSUNG 32 IN LCD LE32R73BDX (MASTER RESET)
* With the TV in standby, press the {INFO} {MENU} {MUTE} {POWER} buttons on the remote.
* The TV will turn On with the Service Menu displayed.
go to reset
* Press the {POWER} button to exit the Service Menu.
Feb 22, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
LOT no.
AKAI CT2985 I NEED LOT NUMBER PLESS TELL ME
Oct 06, 2007 | Televison & Video
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
