Question about Bosch Washing Machines
How do i get rid of the e-13 error on my Bosch Washer?
I cleaned and removed drain pump and discharge hose. Didn't work. Installed new drain pump. Didn't work. Any other suggestions or do i go with my gut and ditch this washer and buy another? Not a Bosch.
  • Renee
    Renee Nov 21, 2014
    Hi jerry howard, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    How old is your machine?
    Scholar:
  • 91 Answers
Yep, Bosch are bad and common to fault at a very young age, ECU in these machines are far from satisfactory and would steer clear of Bosch at all costs
Posted on Nov 27, 2014
Washer won't drain, E:13 code flashing
From user manual:
Indicator light "rinse" is lit and display is flashing "E:13" with no water remaining in the drum.
For some reason drain pump is blocked.
Clean the water drainage pipe and/or drain hose.
Dado
Oct 12, 2015 | Bosch Vision 300 Series DLX WFVC4400UC 27"...
My Bosch Vision 300/500 DLX series washer machine washer stopped in mid cycle, with error code 13. What to do
The code means that the water is taking to long to pump out
unsrew the pump filter at the bottom front right
have some towel ready to soak up the water
clean and replace filter
most times this fixes the fault
if it doesn't then check for a blocked drain hose or faulty pressure switch
Jul 22, 2015 | Bosch Washing Machines
How do i fix the E-13 error on my washing machine?
Hi Jerry,
I had a similar problem my LG would sometimes wash and other times I received a code(forgot the code it's been awhile)it wouldn't drain, I changed the pump etc.. I had the repairman at the house three times finally PC Richards replaced the washing machine. However after a week the same code came up. I and checked the voltage at the outlet and it read good. So, I checked the voltage while machine was running and I had 89V. I had a bad circuit breaker changed breaker problem solved! I hope this helps.
Wayne
Nov 22, 2014 | Bosch Washing Machines
Hi, My Bosch Logixx 8 is showing error F18 which I think means the filter is blocked. we have lost the manual so how do you get the filter out. Do we need to drain the machine first? Is there an online...
F18 is either the pump discharge is clogged or the machine is oversudsing. If it is oversudsing, make sure that you are using an HE detergent and use less detergent. (Make sure to note the minimum detergent line
To clean out the pump discharge, have a bucket ready for when you release the hose. First, set the cycle selector to Off and unplug the washer. Open the service door and remove it. Next loosen the screws and remove the protective foil. Remove the emptying hose from the holder and take off the cap. Drain the water from the hose. Replace the cap. Then carefully remove the pump cap and drain the rest of the water from the pump. Clean out any foreign objects from the area (housing, threads of the pump cap, etc). Make sure that the impeller can turn. Then replace the pump cap and tighten the screws (the handle should be vertical). Replace the emptying hose and the foil protector. Replace the service door and plug back in. Then fill the dispenser II with 1 liter of water and then start the Drain cycle. Let this water flow through to the pump.
The manual is available from Bosch. Go to http://www.bosch-home.com/us/WAS24460UC.html?source=search and click on Additional Documents . Then click on User Manual. This will redirect you to the correct page. Select your specific model and the language and click on the manual with the IU designation. The pictures to go with the clogged pump are on page 9 of the PDF.
The filters that can get blocked are in the water inlets. To clear those, turn off the water to the washer. Select a cycle and press Start/Pause. Wait 40 seconds then set the selector to Off. Unplug the washer. Then remove the inlet hoses. Clean and replace the filters at both sides of the hose. You will need pliers to remove the filters from the washing machine side. Then reconnect the hoses and check for leaks.
I hope this helps.
Jul 09, 2011 | Bosch Logixx WAS2446 Front Load Washer
Error code E:13 on my 500 plus series washer
The E13 error code on your Bosch washer refer to a drainage problem or the pump time might have been exceeded
Either it might be due to a clogged pump, improper detergent being used, ( must use "HE" detergent ) hence suds not allowing a proper drain cycle. You should clean water drainage pipe and/or drain hose. Turn selector to off and restart 'drain, program or, on 500 plus machines, the 'refresh' program. It also says this is caused by using too much detergent. Bosch recommends using half of what the manufacturer recommends when using HE detergents. They don't recommend regular detergents. First run the short wash or refresh cycle without detergent and hopefully your lines will clear.
Thank you !!
May 25, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Drain is not taling the discharged water away
check your hose by running a coathanger through it and, don't forget to check the vacuum breaker hose also
if you just installed a new garbage disposal did you remove the plug in the outlet of the new GD before you conected the hose to the DW? look into the GD when the DW is draining and look for the discharge stream
Apr 22, 2009 | Dishwashers
Error Code 03 Revisited
The resolution for the dreaded "error code 03" with a Bosch WFK 2401 is to replace the drain pump. It's around $50 at repairclinic.com (item #144489 - the only part you should need) and they had it in stock at Tribbles in Upper Marlboro, MD (awesome parts company!).
I'm a home owner who saw similar syptoms as everyone else; the issue was interrmitant, I could observe the impeller spinning when dry draining, but when trying to drain wet, a little might come out if any. I even removed the back panel, disconnected the hoses and cleaned everything out (which I suggest doing when replacing the pump), but the problem persisted.
*disclaimer - I am by no means professional repair man. Proceed at your own risk!*
I finally swapped out the pump and it works fine. Remember to unplug the unit, disconnect all hoses, remove the detergent tray, remove the four screws from the front panel around the drain trap. Gently lay the unit on its front being sure not to put pressure on the dials and to have a towel under it. A little bit of water will come out.
Pinch to disconnect the electrical relay to the pump. Disconnect the hoses at their spring clamps, remove the pump and replace it with the new one (I kept the hose from the discharge port to the drain output connected to make things a little easier. Reconnect the new pump the same way - you really can't get it wrong it you do it this way (thanks go to Bosch for their modular engineering techniques - I can't imagine it would be this simple with any other manufacturer).
Gently stand the unit back up and connect the pump to the front panel again using the four mounting screws. You can position the pump my positiioning your finger inside the pump and up the discharge port.
Be sure everything is tight, reconnect all hoses, plug the unit back in and observe for any water leaks (the back panel should still be off to facilitate this; be sure to keep clear of the belts back there.
When finished, replace the back panel and viola - I was done in an hour.
Note: when inspecting the old pump, I can see exposed O-ring near the discharge port - where the was a lot of wear. I think when water got in there and perhaps leaked into the motor area, the unit shut down the pump to prevent electric shock - thus it worked when dry but not when wet.
Dec 14, 2008 | Bosch WFK 2401
E13 error code with my Bosch 500 plus series washer (front loader)
I had an E-13 error code on my Bosch 500 series washer.  The drain pump  impeller was plugged.  Access the drain impeller at the bottom front right corner.  Just put a pen in the hole and turn the cover.  Then you need to manually drain the washer.  I used a shop vac by just turning the cap until it started to leak and vacuum the water as it comes out, this takes quite a while.  When you get it drained you can take the cap completely off.  When I did I found a wipe in the impeller.  I took it out and put it back together and the washer worked just as before.  Good Luck!!
Jun 01, 2008 | Washing Machines
Code E13
For a Bosch washing machine, Error 13 is pumping time exceeded. So, in general, the issue is pump related. Things to check would be if the pump is blocked (it can be cleaned out if you can get the service door in the front panel off), check the wiring connections to the pump, and check the drain hose to make sure it is not blocked.
Feb 14, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Calpso washer
I had a similar problem twice and botht time the culprit was a loose bra wire that had found it's way down to the discharge area prior to the drain outlet. It was interfering with the check valve ball and causing the error message. I removed one of the hoses and reached in with a needle nose pliers tos snatch the loose wire. I hope this helps. Tom
Sep 15, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
70 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
