Question about Garden
Chain brake won't fit over clutch.? - Garden
  • 56 Answers
On the back of the brake, there should be an adjustment screw. loosen it a bit and the brake should slide on. hope this helps.
Posted on Nov 21, 2014
2 Suggested Answers
  • 376 Answers
SOURCE: how do you reset the chain brake?
You have to pull it back as if it were still on the saw until it clicks. I may be hard, but that is what you have to do.
Posted on Jun 15, 2009
Cover won't go on.round metal strip won't fit on round spindle that turns chain.E-235.Do I need the break bar?It doesn't line up either. DB
Sounds like the chain brake was set when you took the cover off. You need to disengage the chain brake (release it) so the round spindle will fit inside. Look for the two parts (one on cover, one on saw) that match up at the base of the chain brake. You won't be able to fit the whole cover on, but if you can line up where the metal triangular gear engages the chain brake, you can give it a snap to disengage it. What I have done in the past is to line up the two parts and push down on the top of the cover where they meet so as much of the gear is in the chain brake release as possible ( I put a knee on it ) and then give a snap to release it. Be careful though, because the cover part is plastic and you don't want to strip that part of the chain brake assembly. Good luck.
Sep 04, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Need to put a new chain on a Husqvara 235 14 inch chain saw?
Check that the chain brake is in disengaged position by
moving the front hand guard towards the front handle.
Remove the bar nuts and remove the clutch cover (chain
brake). Take off the transportation ring.
Fit the bar over the bar bolts. Place the bar in its rearmost
position. Place the chain over the drive sprocket locate it in
the groove on the bar. Begin on the top edge of the bar.
Make sure that the edges of the cutting links are facing
forward on the top edge of the bar.
Fit the clutch cover (chain brake) and locate the chain
adjuster pin in the cut-out in the bar. Check that the drive
links of the chain fit correctly on the drive sprocket and that
the chain is in the groove on the bar. Tighten the bar nuts
finger-tight.
Tension the chain by turning the chain tensioning screw
clockwise using the combination spanner. The chain
should be tensioned until it does not sag from the
underside of the bar.
The chain is correctly tensioned when it does not sag from
the underside of the bar, but can still be turned easily by
hand. Hold up the bar tip and tighten the bar nuts with the
When fitting a new chain, the chain tension has to be
checked frequently until the chain is run-in. Check the
chain tension regularly. A correctly tensioned chain
ensures good cutting performance and long life.
Jun 27, 2011 | Husqvarna Garden
Chain won't move but when i take chain off yhe clutch will
The chain brake is activated, pull the hand guard fully back to the top handle until you hear the click of the brake loading
Jun 09, 2011 | Husqvarna ChainSaw 18 in Bar 32 HP Model...
Husqvarna 346 xp. Changed brake band and spring, how do i reassemble with chain brake "off" so will fit back over clutch?
Re assemble the brake in the actuated mode, remove the clutch and sprocket from the saw, now fit the brake back to the saw and use the hand guard to load the brake, now re fit the clutch and sprocket
Apr 14, 2011 | Husqvarna Garden
How do I get the brake band ,located inside the chain cover, assembled back onto the chain saw. clutch assembly. The band brake diameter seems too small to fit around the clutch housing.
You need to load the brake, clamp it in a vice, be carefull not to damage the cover, if the hand gaurd is connected to the brake pull it fully back until the locks off, this may take a fair amount of force as it is compressing a large spring, if the hand guard is on the machine, remove it and use this as a tool to load the brake, the only other way is to remoce the clutch and sprocket, now refit the brake onto the saw, now pull the hand guard fully back to load the brake.
Apr 11, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How doe the band on my chain break attach to my chainsaw mine is broken and i do not know how to install it. or how to get the clutch off so i can replace it
It can be a little tricky!
If you are referring to chain break band
Tools you will need:
1/2 Socket (to remove bar nuts)
T25(torq) or you can use a Flathead screw driver but is a little harder.
Remove 2 bar nuts,Clutch cover,bar,chain, 2 screws on black bar handle right behind clutch cover(this is needed because there is a hidden screw there for the chain break) You will need a new chain brake (my guess is that it is part # 530071893 aprox $15) but you will want to verify that with your model number.
You should see the chain break assembly, 3 - T25 screws are visible after the clutch cover is removed(note sometimes you have to clean saw dust to make screw head visible) the other T25 screw is hidden under the black bar handle. Once you remove all 4 screws on the chain brake you will be able to pull it off.
Installing the new one is the tricky part because if it is set(or break is on) you will have a hard time putting it on.One of the easiest ways is to focus on it near the muffler you will see that a metal 3 pronged gear fits into the plastic part of the chain break handle.and if the band is too tight to fit over the clutch drum you will have to carefully reset it by applying pressure onto the area that has the 3 pronged gear and chain break handle make sure that the handle is pushed forward all the way while you apply pressure then slowly pull chain break handle back till you hear a "snap" this resets the chain brake spring and the band should now fit over the clutch drum.Now, proceed with putting back together 4 chain brake assembly screws,2 handle screws,and bar,chain,clutch cover,and 2 bar nuts.
Please note it is important that you apply quite a bit of pressure onto chain break area where metal (3 pronged) gear fits into handle while resetting or when you reset it the metal part can cut into and damage the plastic piece in the chain break handle.
You can see a breakdown here: http://www.searspartsdirect.com/partsdirect/part-model/Poulan-Parts/Chainsaw-Parts/Model-P4018WT/1324/1503220/P0506041/00002?blt=06&prst=0&shdMod=P4018WT
Hope this helps!
Feb 20, 2011 | Poulan 18" Wild Thing Chainsaw
Trying to fit bar and chain on a new 445.can not replace clutch cover after following instructions closely.it seems brake is on. WOULD REALLY APPRECIATE HELP. THANKS.
You'll definitely have to unlock the chain brake to get the cover back on. You should be able to unlock it by pushing the chain brake handle forward, toward the bar and chain when mounted on the saw.
Oct 20, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
On my saw when I changed the chain out, the cover will not go back on over the clutch correctly.. The cover has a ring in it that is supposed to go over the clutch but does not fit correctly, What am I...
You should have released the chain brake before taking things apart--it will be necessary to move the brake coupling in the cover with a wide blade, square shanked screwdriver and a wrench that fits the square shank of the screwdriver. It should make a 'snap' noise when fully released and the brake ring will have expanded to fit over the clutch hub. Hope this helps!
Oct 18, 2010 | Husqvarna Chain Saw 20" Bar
Chain brake is jammed, chain will not move when cranked
Take the side cover off of the clutch area and watch while you try to move the brake. Something may be broken or out of place. If the brake band which is fitted around the clutch drum is damaged, it may be causing non-release.
May 13, 2010 | Homelite ZR10926 16 Chain Saw
Clutch cover will not go back on
Ensure it isn't tripped before removal is the best advise I can give. It is difficult to reset with the cover removed, Dolfoff explains it well. GL
Lou
Reset Chain Brake
Please follow this link, cursor down to “Best Solution”, while there click the “Was this helpful? [Yes}” button.
http://www.fixya.com/support/t3102817-re_install_side_cover_after_chain HTH
Lou
If no vice a "C" - clamp to a work surface might work.
Oct 10, 2009 | Husqvarna Chain Saw 20" Bar
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
