Question about Measuring Tools & Sensors
Set the valves on a model 445577 1187 b1 briggs and Stratton engine
Ohv intek
mowerman1857
  • 389 Answers
SOURCE: Briggs and Stratton 22hp v twin OHV smoking badly
First thing to do is pull your dipstick and check for broken or missing O-ring also as you pull it, look to make certain that it was seated properly and all the way locked. If either condition exists, you will be leaking into the crankcase which will cause your symptoms
Posted on Sep 14, 2009
  • 583 Answers
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Posted on Oct 25, 2009
  • 5 Answers
SOURCE: Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1: LOOKING FOR A DEW CROSS REF OIL FILTERS TO REPL. C...
motorcraft fl-400 can buy at walmart
Posted on May 23, 2010
  • 59 Answers
SOURCE: Bent push rods both cylinders,engine # 445677-0827-B1
You can find a manual, free of charge at www. briggs & stratton.com. click on manuals and put in your model and type and its free to d/l. You can then print it out if so desired.
Posted on Sep 23, 2010
SOURCE: Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1: will only start with choke on and after warm (chok...
If it has a plastic intake manifold there is your culprit. The flanges warp and produce vacuum leaks and all three.
Posted on Nov 06, 2010
What are the valve clearence settings for intake and exhaust on 20hp b/s #461707
.004"-.006" on intake and exhaust valves cold engine. I would set them at .005" .
Feb 16, 2017 | Briggs & Stratton Briggs Stratton Intek V...
How to replace ohv cam on 17.5 briggs model 31c707-1346-b2
I SET THE INTAKE VALVE AT .005 AND THE EXHAUST VALVE AT .003 AND THE EXHAUST VALVE MOVES ONLY HALF THE DISTANCE OF THE INTAKE. IT IDLES OK BUT GIVE IT SOME GAS AND IT BACKFIRES THROUGH THE CARBURATER AND SHUTS DOWN.
Oct 20, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Replacing ohv cam on 17.5 briggs model 31c707-1346-b2
if you dont know take it to a proffessional if you make the slightest mistake you can bend valves or even worse break a piston
Need valve clearance for 24 ohv engine,4457770168e1
You should be able to get the settings from the Briggs & Stratton Website
Aug 24, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Jul 25, 2009 | Briggs & Stratton Briggs Stratton Intek V...
15.5 intek pushrods whitch one is for the intake vavle ?
Intake is aluminum, exhaust is steel. Set valves 1/4" past top dead center on compression stroke (both valves closed), intake (bottom) .003-.005, exhaust .005-.007
Jul 08, 2009 | Briggs & Stratton Briggs Stratton Intek V...
B/S 23 H.P. OHV Hard to turn over.
THE VALVE NEED TO BE SET TO 3 TO 5 THOUSANTHS
Apr 25, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Measuring Tools & Sensors Logo
70 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
