Question about Tivoli Audio Players & Recorders
Why does my Tivoli Model Satellite radio have a working display, but no sound from either satellite or AM/FM radio?
The display says "no signal". I have plugged/unplugged, had new signal sent to radio. I have no sound at all, not even static. Turning it to AM or FM makes no difference. The power button does nothing at all and pushing buttons never changes the display.
proton77
  • 1183 Answers
SOURCE: FM output
The problem could be bad earthing as told by my fellow technicians.
You can put an additional signal bosster antenna. As when you put you finger it amplifies the radio signal. If you have amplifier installed for your speakers . Try switching off the amp and try connectiing the speakers directly.
Following is the Link for the antennas
http://tinyurl.com/5rcznp
Thanks
Proton
Posted on Aug 29, 2008
SOURCE: Cannot Get Antenna To Pick-Up Signal
how do i connect my xm roady sa10035 to my car cd player?
Posted on Feb 02, 2009
SOURCE: 2005 ford expedition w/rear entertainment center.
I heard we might need a new terk adapter
Posted on Apr 20, 2009
rmhurd605
SOURCE: No FM Frequency option
I had the same problem with all three of my Roady XTs. I posted a video with directions for solving the problem on YouTube:
http://www.youtube.com/watch?v=BGMWf0aUTjw
Basically, you just need to have the antenna unplugged when you power up, and push menu right away, then select. Not sure why, but it worked on all of my Roady XTs. On the oldest one I had to push menu more than once. Good luck!
Posted on Apr 28, 2009
noobcybort
  • 199 Answers
SOURCE: No sound from Sirius Sportster SP-R2R satellite radio
Hello there !
I suggest you fix it don't through it yet ,I want you to change this chip .
sound IC( Amplifier ) it could be damaged or something is loose inside .
good luck
Posted on Dec 08, 2009
Dodge 2005 diesel truck has a Pioneer DEH 96200BT radio. The AM/FM radio part works but the sirius says "no device
Did it ever work? Sounds like you have an interface problem. Make sure the radio is connected to a Sirius XM satellite. If your device is not connected to a satellite, your device will display an error message such as "Searching for Signal."
Jul 05, 2011 | Car Audio & Video
Hello, I purchased a Tivoli Model One few months ago and I noticed that after tuning a radio station (strong signal, amber light on), the signal will fade out in ten minutes or so and I need to tune it...
hi,
it looks like its got a hookup for an external antenna on the back, hook a wire to it or better yet hook it up to a pair of rabbit ears, look at the back and make sure your hooking it up to the right connector am/fm
rabbit ears at walmart
..jm
Tivoli Audio Frequently Asked Questions Tivoli Audio
8260f424-51e7-404b-8aad-55d32a5ee6ab_1.c6ade34e7d92de1dbfde961d78f8c87b-2mys2t2nr3la4vnxyourkcko-2-0.jpeg
Jul 13, 2017 | Tivoli Kloss Model One AM/FM Radio
2009 dodge ram , fm,am,cd,all work fine on radio. but when I hit satelite radio it shows channel 184 and there is nothing.
Is there audio on 184? It sounds like it just needs to be activated. Call Sirius with the SID #, and they can send a signal. Sirius' # is 888-539-7474
Jun 04, 2011 | Sirius Satellite Radio Sirius Starbase...
I have a 2007 Ford Edge that the satellite radio has quite working. The station and what is playing shows on the display, but no sound. I can change stations on the satellite radio and same thing, no...
Contact the satellite radio company and ask them to perform an update to the radio.
This exact issue happened to 4 of our vehicles within a 60-day period and having them perform an update resolved the issue in every case.
Nov 03, 2017 | Car Audio & Video
I bought my Tivoli Model One two months ago in Bogor, West Java, Indonesia. The sound quality on FM band is superb even if it's on mono mode., but I found the the signal reception on FM is unstable. I...
Many such problems are caused by bad aerial connections, aerial cable problems and the aerial itself. Make certain all of these are good before checking out the electronics.
Apr 07, 2017 | Tivoli Kloss Model One AM/FM Radio
Tivoli model Satellite will not turn on. Had intermittant power issues. Moved the radio and it will no longer power on
The power control problem is easy to fix.
It can as simple as a fuse (I'm sure you check it already) or a switch that is piggy back on the volume control.
Radio Shack has a similar one HERE
Disconnect the AC outlet and open the main Tivoli unit.
Look at the back side of the volume switch and you will see a power switch piggy back onto the volume control.
You can bypass it or get the correct value Potentiometer + SPST switch.
Use an ohm meter to meter the both end of the potentiometer and if it's 10,000 ohm or 10k then just go to Radio Shack and ask for
10K-Ohm Audio Control Potentiometer with SPST Switch Model: 271-215 | Catalog #: 271-215
It's a direct replacement.
If the ohm read is other then 10K then you will need to order it for an electronic supply house.
Tivoli makes great radio.....if you want to sell it I want the first dip.
Jul 30, 2010 | Tivoli Henry Kloss Model Two FM/AM Radio
Tivoli Model One Radio Humming only, no reception
The fuse would cause a total absence of power. Your problem is likely a blown filter capacitor in the power supply. Unless you have electrical/electronic skills, the radio will require professional repair.
Oct 10, 2009 | Tivoli Kloss Model One AM/FM Radio
Reciever powers up and recieves signal (station and song titles are displayed) but doesn't transmit to car radio either through the assigned fm station or the aux cord.
IF you have a cord plugged into the audio jack, if will TURN OFF your FM transmitter. You have to leave it unplugged for the FM transmitter to work. Go to MENU and make sure your FM station is set and that the FM OUTput signal is turned up. Write back if you need more help.
Thanks,
John
Aug 19, 2009 | Delphi Roady2 SA10085 XM Radio Receiver...
If your roadyxt came in a red box then you need to hook up the XM SureConnect to your vehicles antenna. The instructions that come with it are simple and straight forward. Your FM transmitter will not work unless you hook up the sureconnect
Aug 25, 2006 | Delphi Roady XT XM Radio Receiver
Open Questions:
97 people viewed this question
Top Tivoli Audio Players & Recorders Experts
Frank Russell
Frank Russell
Are you a Tivoli Audio Player and Recorder Expert? Answer questions, earn points and help others
