Question about Uniden DECT15803 3 handsets and Chargers - DECT 6.0, Caller ID, Direct
My phones are going blank on screen after I dial out or while dialing.
Sometimes it says Line on hold on the handsets also. After picking up the handsets, it also goes blank on screen after dialing out or while dialing.
    Problem Solver:
  • 19 Answers
While the screen goes blank, does it drop the call? Are the handsets fully charged, or are they on the charging dock whenever they are not in use?
The batteries may need to be replaced. Bad batteries can in some cases cause the phone features to not fully work. They are located in the back, bottom of the handset.
Posted on Nov 21, 2014
No dial tone but dial tone on hands free
The battery in the handset may be faulty/flat. If it does not charge up then replace the battery.
Feb 06, 2012 | Lands Phones
How do i call
Hello Tedelen,
Be sure to meet all the requirements of the phone to make calls and to be fully operational. These requirements can be found here (Requires Adobe Acrobat Reader).
To make a phone call follow these instructions:
Making calls with the Handset
1. Pick up the handset and the phone automatically selects the priority line. If the priority line is occupied, it selects an open line.
OR
Pick up the handset and press a LINE button to select a line.
2. Wait for a dial tone, then dial a phone number.
3. Hang up the handset when finished.
Making Calls with the Speakerphone
1. Press the SPEAKER button and the phone automatically selects the priority line. If the priority line is occupied, it selects an open line.
OR
Press a LINE button to select a line.
2. Wait for a dial tone then dial a phone number.
3. Press SPEAKER button when finished.
If you are having problems refer to the given link to the User Guide.
-bsalamakha
Jul 05, 2011 | RCA 25415RE3 Phone
I was storing some extension numbers and spead dial numbers and I must have done something wrong as anytime I pick up handset to make a call a 'reorder tone' message comes up on the display- this is before...
So don't pick up the handset :-)
There are some line preference and pickup dial programs that just happen to sit in PROGRAM 1x. My guess is that you have assigned an empty or invalid pickup dial code to the phone.
Try this first. Press PROGRAM and dial 12 ENTER. Is the Hot Line mode ON? If it is, press SEL and ENTER. Wow. That was easy :-)
Didn't work? Let's go for Preferred Line Outgoing next. Dial PROGRAM 19 and 3 ENTER. That makes the intercom prime (0 is none, 1 is idle line 2 (xx) is a specific line).
If you tried both of these, and still no joy, then it's time to reset the phone. The problem with that is you have to dial the code IMMEDIATELY as you're picking up the handset. Good luck with that. The reset code is 79# or 790.
Carl
Jan 25, 2011 | Panasonic KX-T7630 Corded Phone
I have the panasonic handset phone. I have three lines. When I pick up the phone it goes automatically to line 3. If I have a call holding on line 1 from the desk phone how do I get to line 1 on the...
A lot depends on what sytsem the 7896 is plugged into. If it happens to be a TA series, you'll go into station programming mode (menu 99) and dial 11. The change this makes is that you will have to dial "9" to get an outside line, or 53x to pick up lines 1,2,3 etc. To get back to idle line preference, dial 12, but a cordless phone should never be set to ILP because you can't call internally or page.
Carl
Sep 21, 2010 | Panasonic KX-TD7896 Cordless Phone
No dial tone in Clarity C4230 setup
if you can get dial tone with another phone, look into manual for any instructions, usually a toll free number for help. ( BEST ) otherwise take phone back for exchange. may be problem in the board.
Apr 16, 2009 | Clarity C4230 Cordless Phone
Pick up receiver and get a dial tone for outgoing w/o pressing 9
I beleive you are referring to a phone which is part of a PBX system or Key-system (sounds more like a Panasonic PBX system). If so, this is a system program that has gone "bonkers". You may need to re-program the automatic outside line dial tone on the system for the specific phone you are referring to.
Jan 28, 2009 | Panasonic KX-T7030 Corded Phone
Program speed dial buttons
To program a speed dial for an outside line: Pick up the handset, press #00, press the button to be programmed, press *21, then enter the number to be dialed (including any dial out number and areacode).
To program a speaad dial for in internal extension: Pick up the handset, press #00, press the button to be programmed, press *22, then enter the ext to be dialed.
(Once you hit #00, you can also follow the screen prompts).
Jan 21, 2009 | Avaya 4412D Corded Phone
Dialing out
Usually picking up the handset and dialing " 9 " will get you another dialtone and then you dial the number you want. If you receive a busy signal it could mean your system requires another number to dial out or your phone is restricted from dialing out. When you pick up your handset or press the INTERCOM key you should get a triangle shapped light which means you can proceed with dialing your access code for making a call ( 8 or 9 ). Hope this helps, let me know ...Mike
Aug 17, 2008 | Nortel T7316E 2-Line Corded Phone
Dial Tone - Number Dialed does not go through
The problem is possibly the keypad on the phone. Try another phone , preferrably a standard corded phone. If you still cannot break the dial tone, then the problem is with the telephone line (phone company)
Mar 28, 2008 | Lands Phones
Problem when dialing phone
Yes, I have had nothing but trouble with my V-Tech ia5823.
Slow to dial, dropping out going calls and now the base light is flashing at a rapid pace and will not charge the handset.
I want to return it to Wal-Mart but have misplaced the recepit.
I will never buy another V-Tech..Uniden is the way to go!
Jun 02, 2007 | Vtech ia5823 Cordless Phone
Uniden DECT15803 3 handsets and Chargers - DECT 6.0, Caller ID, Direct Logo
297 people viewed this question
Top Uniden Computers & Internet Experts
castletech
castletech
Brett Duxbury
Brett Duxbury
Are you an Uniden Computer and Internet Expert? Answer questions, earn points and help others
