Question about RCA Televison & Video
Afor are the codes RCA Digital Tuner Codes
Model number is dtahcc91
    Top Expert:
  • RCA Master
  • 74,473 Answers
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Posted on Nov 21, 2014
pgh_pa_guy
  • 2992 Answers
SOURCE: rca tv model 32v432t
This set is not digital tuning and you would need a converter for off-the-air reception. You can get full specs and manual downloads from RCA's site:
http://tv.rca.com/en-us/productdownloads.html?MN=32V432T
Posted on Dec 18, 2008
SOURCE: Sony FD Trinitron WEGA TV Model Number KD27FS170 digital tuner problem
I have the same TV and was unable to get the digital channels until today. I think you need to connect your antenna on the back of the TV to the ATSC jack. If you have had it connected to the VHF/UHF jack, it won't detect the digital signals. Once you have the antenna connected to the ATSC jack just Auto Program your TV and you'll find all the digital channels in your area. Good luck!
Posted on Dec 31, 2008
  • 4234 Answers
SOURCE: Determining if TV has a digital tuner
A converter box is only required if you are using an external antenna (rabbit ears or rooftop). If you are connected to cable or satelite, no converter is needed. Please do not confuse a digital tuner (select channels using numbers) from a digital broadcast. The current broadcast system uses an analog signal. The changeover is to convert that signal to a digital one which will take less frequency space for the same channel. This frees up space for additional channels.
Hope this helps,
Dan
Posted on Jan 13, 2009
SOURCE: i HAVE A 2004 RCA
Model has one NTSC RF and two NTSC composite inputs. It's compatible with analog Over The Air and non-scrambled analog cable broadcasts. After the US analog cutoff (currently scheduled for June 12) it WILL require a digital to analog converter to receive ATSC digital TV transmisions.
Posted on Mar 31, 2009
  • 4234 Answers
SOURCE: digital or analog tuner
Your set has a NTSC tuner for the over air broadcasts. You will need a converter box if you wish to use an antenna. If you have cable or satellite, you are fine.
Dan
Posted on Sep 01, 2009
I have a RCA 3 device remote model rcrno3br I need to program a zenith digital converter box to it model number dtt900 it won't work the 51415 codes a bust the search is a bust I need help
You have this backwards; the remote codes control the Zenith box. If your RCA remote is universal and you can't find anything that works using code search, you may have to try a different universal remote.
Nov 14, 2016 | RCA Televison & Video
RCA Guideplus gold gemstar analog or digital
Most of the RCA GuidePlus Gold gemstar TVs worked with analog TV signals (NTSC) only. The Guide+ information was only broadcast in NTSC signals and is no longer being provided. If you can check the date of manufacture of the TV, you can use the size to check if it had an ATSC tuner added if it was made for the US market. 37"+ TVs had to have a digital tuner in second half of 2005. 25" TVs needed to have the ATSC tuner after March, 2006. The next year all TVs had to have a digital tuner.
I hope this helps. Please add a comment with the model number of the TV, if you would like me to confirm the tuner information on your set.
(The RCA F31317 TV with Guide+ was manufactured in 2000 and thus only has a NTSC tuner.)
Dec 26, 2015 | RCA Televison & Video
Is the Rca true flat digital
I'd need the model number to tell if the RCA TV has a digital (ATSC) or analog (NTSC) tuner. The mandate for inclusion of the ATSC tuner depended on the size of the TV and the year of manufacture. Small (<25" diagonal) TVs didn't need to have an ATSC tuner when they were built until 2007. The older TVs could still be sold with a "cable-ready" or similar NTSC only label. (The 32"+ TVs had to have the ATSC tuners in 2005 and the mid-size TVs had to have the digital tuners in 2006.)
For example the 27F530T was manufactured in 2003 and only has a NTSC tuner. However, the 20F424T was manufactured in 2008 and does have an ATSC tuner.
I hope this helps.
Aug 07, 2015 | RCA Televison & Video
I have a digital tuner box for my t.v.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Search the site by type in the brand name to your device, in the "Search this Blog" window, and press Enter.
Nov 21, 2014 | RCA Televison & Video
What are the codes to program a sony bravia tv model KDL32L500 from a rca universal remote?
You don't need codes for the television. You need the codes used by the Universal remote. Search the internet for your RCA universal remote, use it's model number.to find the user manual.
The codes are there.
Oct 30, 2014 | RCA Universal Remote Control
Rca dlp error codes
I will need the model number of your RCA for assistance.Please respond to this same post for further assistance
Apr 02, 2013 | RCA 61" Widescreen Dlptm Hdtv With...
Programming a ATSC DTV tuner on a RCA Universal Remote
Try a code for a "satellite receiver" of the same manufacturer of your DTV tuner. I've heard of a cross-remote complaint with the DirectTV box and the DTVPal box. Note, your DTV tuner may say RCA, but it could be manufactured by a common DTV tuner maker. The system looks very close to a Zinwell. Don't have an RCA model to try the codes out, though.
Dec 27, 2008 | Televison & Video
Need a progam code for rca dta800
I just tried their web site and it worked! They have the codes. www.1800customersupport.com/rca
or here is the direct link: http://www.1800customersupport.com/productdocuments/DTA800B1_Program_Codes.pdf
Hope this helps others who have had the same problem. Mine did not even come with these codes!!!
Jul 07, 2008 | Hitachi 57F510 57" Rear Projection...
RCA Model # F36650 tuner.
if your tuner is already dead replace it.because the original tuner of your TV is very expensive. the solution of your TV is converting tuner, you buy a kit name AUDIO TV CONVERTER . simply conection and and not very expensive. just plug the unit to ac line and connect the cable line to rf of your Television and its OK. im just trying to suggest my solution to you JRANDY phillipines tech
Apr 19, 2008 | RCA F36650 36" TV
Televison & Video Logo
43 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
