Question about Sportcraft Exercise & Fitness
Sportcraft TX 2.5 will not power up. Fuse is good. Power from wall is OK. Tried removing & replacing key with OFF & MODE switches on, but no luck. anything else I can do?
SOURCE: My sportcraft tx 2.5 treadmill does not have the safety key
any round magnet that will fit in the hole will work.
Posted on Dec 20, 2009
Testimonial: "Thanks a lot..This really helped"
  • 26 Answers
SOURCE: Where can I find a replacement sensor wheel for a
Try Icon Service Group. You can google them and find the web address. They are an excercise equipment warranty provider but will also see you parts.
Posted on Jun 16, 2010
  • 218 Answers
SOURCE: I have a sportcraft tx200 treadmill that will not
Test for voltage going to the treadmill, if there is no power going to the treadmill then check the fuse or breaker in your house. If you already checked the house fuse/breaker then try this.
first thing is check for any loose connections or bad wiring and then follow the steps below to try and determine what is wrong with your treadmill.
* Check the breaker on your treadmill it can be combined with the on/off switch or it can be a separate breaker. Make sure it is not open.
* If that tests ok, check to see if your getting power to the motor controller(electronic board under the hood) this can be done by following the power cord in and testing where they attach, if you are getting 120/240 volts then check the light(s) on the controller If they are not lit then the controller is bad.
* If they are lit you will need to check the dc voltage going to the motor
* Also make sure you have voltage going to the console
if you have 8-12 vdc voltage to the console and the console is dead replace the upper control board.
* If only one or none of these voltages are present then the controller is bad.
* If your treadmill is equipped with a separate power board then you will need to take voltage readings going in and coming out from the board If nothing is present then the power board is bad. If all tests well move on to the controller.
* some motor controllers are equipped with a fuse on it, if this is blown the console will not light as well.
* Hopefully it is just a breaker.
* Make sure you are lubricating your treadmill as well on a regular basis. Too much friction can wear out electronic parts and reduce the life of your treadmill. Use the appropriate lubricant recommended for your specific model and never use an extension cord.
Thank you for the question and please feel free to contact me again with any questions or problems you may have.
Posted on Aug 11, 2010
  • 1212 Answers
SOURCE: location of speed sensor on sportcraft tx 400 treadmills
It is a simple magnet and Hall effect transistor if you have 2 small wires. It usually attaches to the 1/8 inch mini plug. You can test it with an analog meter, the resistance will be stable at rest, and with treadmill in motion, the resistance will change as the magnet passes the hall effect switch. moving the track at slow speed manually will be enough to see the needle move. Speed is calculated off of the rate of those pulses.
Posted on Jan 23, 2012
ercupa190
  • 12223 Answers
SOURCE: How do I turn on my tx 5.0 rc sportcraft treadmill
DEAR SIR:
Go to any Hardware and to buy any small magnet, since the key is smal magnet, Do it by small pennies.
sincerely. God bless you
Posted on Apr 23, 2012
Power Lock Unlock Rocker Switch
Hi E,with key OFF, try spraying a little ELECTRIC CONTACT CLEANER from CRC or Radio Shack into space between switch & panel on driver's side,cycle switch back & forth 10 or 12 times.driver's side switch 'overrides' others ,if cleaner dosen't work,replace it first. Good Luck
Oct 18, 2014 | Cars & Trucks
Hpt790 staying at 94% initilising for too long
Star wheel motor assembly broken. HP part no Q6718-67017.
To confirm: Enter in to diagnostic menu as
Entering the Diagnostics Menu
1. Make sure the printer is switched off with the Power key on the front of the printer and not with the power switch on the back of the printer.
2. Press and hold the Up and OK keys. While holding the Up and OK keys down, press the Power key to turn on the printer, then release it while continuing to hold down the Up and OK keys. Wait until the HP logo appears in the front-panel display, then release all keys.
3. In the Diagnostics menu, select a diagnostic test with the arrow keys and press the OK key to begin the highlighted test.
4. Select scan axis > enter ok
5. Select star wheeler lifter > enter ok
follow the message.. check for the result.. If its OK then start wheel is good.. If any error persists.. you need to replace star wheel unit..
Only professional can do the part replacement, not suggestible to user to replace this part..
For technical guys:
1. Power off the unit, remove power & data(USB/Network) cable.
2. Remove formatter & housing
3. Remove front cover
4. Remove screws(Left cover)
5. Remove left side panel(ch 538-67005)
6. Remove pinch arm leaver
7. Remove left cover
8. Remove spit on
Follow the snaps: 9c6ef43c-a766-4620-8f8c-e3b95b9387cc.jpg fa8b1961-8828-404a-a635-46fd6634e5aa.jpg 400a58ac-8af0-4f57-9033-4d1c73d4f4b2.jpg 586b962e-67e2-4410-9f34-e11f21f4a29f.jpg 10bf5d85-2872-4004-988c-7b833ef0028f.jpg bdf7fe76-381c-401c-a359-e3c9a8d6ede4.jpg eb8f625e-6581-45da-9f74-b1be9311ce26.jpg cf0cabdb-7f73-43de-b9a8-5fffcf345e20.jpg 3915469b-2f28-4183-850d-560afe1edc61.jpg 035896bf-a3cf-4516-969e-cde6edebd47c.jpg
Best of luck....
Mar 20, 2014 | HP Designjet T610 InkJet Printer
Starting Problem
see the video attached. LUBE too the rollers bearing front +back and test the drive belt motor, and replace if necessary.
God bless you
Jul 22, 2013 | Sportcraft Tx2.5 Tx 2.5 Treadmill Motor...
Amp fuse keeps blowing when car is turned off
It sounds like that fuse is supplying power to more than just the amp and is being shorted out in the START mode. Normally I would think the power to the sound system would be cut off by the ignition switch in the START mode. Try to find out what else that fuse supplies power to. You can disconnect suspected trouble areas to see if that helps locate the source of the fault.
Feb 16, 2013 | GMC Cars & Trucks
2007 HHR Has no power, replaced shifter assembly, still no power.
Check all main power feeds to all fuse centers (boxes) ! Do you know what a electrical distribution diagram is ? How to use a DVOM - digital volt ohm meter to test electrical circuits ?
Has no power, replaced shifter assembly ???? No power where ??? And why would you replace shifter assembly ???? What happens when you turn the key to on ? not start ,just on ? Insturment cluster lights up ?
Is the battery good ? Connections an cables ? Your going to need to check power at the battery ,fuse boxes etc.... Confirm there is B+ voltage somewhere !
Your best bet , take it to a qualified repair shop . You have no idea of the complexity of this vehicle ! Everything is contolled by computer ! The ignition switch is a input to the BCM - body control module , by these inputs the BCM will control the vehicle .
The body control module (BCM) has a bussed electrical center integrated into the housing. Body control relays and fuses are installed directly on the BCM, which simplifies wiring and junction blocks on the vehicle. The body control system consists of the BCM and its associated controls. Battery positive voltage is provided to the BCM from IBCM BATT 1 fuse and the IBCM BATT 2 fuse in the underhood fuse block. The module grounds are wired to ground G201, G203 and G305. The BCM is wired to the GMLAN High speed serial data buss, and the GMLAN Low speed serial data buss, as well as discrete input and output terminals to control the functions of the vehicle's body .
Serial Data Gateway
The body control module (BCM) in this vehicle functions as a translator between the High and Low speed GMLAN busses. The 2 communication protocols use the BCM to translate communicated serial data messages between the control modules over the 2 serial data busses.
Power Mode Master
This vehicles body control module (BCM) functions as the power mode master (PMM). Refer to Power Mode Description and Operation for a complete description of power mode functions.
Power to many of this vehicle's circuits are controlled by the module that is designated the power mode master (PMM). This vehicle's PMM is the body control module (BCM). The PMM controls which power mode (Run, Accessory, Crank, Retained Accessory Power, or Off) is active.
Serial Data Power Mode Master
On vehicles that have several control modules connected by serial data circuits, one module is the power mode master (PMM). On this vehicle, the PMM is the body control module (BCM). The PMM receives 3 discrete ignition switch signals to differentiate which power mode will be sent over the Serial Data circuits. The 3-wire Ignition Switch table below illustrates the state of these inputs in correspondence to the ignition switch position:
Relay Controlled Power Mode
The body control module (BCM) uses the discrete ignition switch inputs Off/Run/Crank, Accessory, and ignition 1, to distinguish the correct power mode. The ignition 1 circuit is also routed to the Run/Crank relay for relay controlled power feeds during the appropriate power mode. The BCM, after determining the desired power mode, will activate the appropriate relays for that power mode.
Run/Crank Relay
The run/crank relay control circuit is connected to a constant ground and is switched by the ignition 1 circuit or the body control module (BCM). The BCM, will in lieu of the ignition switch position, activate the Run/Crank relay during a remote start event. The Run/Crank relay supplies a power signal to the following circuits, when the a Run or Crank power mode is selected:
• Automatic transmission shift indicator
• Automatic transmission (A/T)
• Switched power feeds to the BCM
• Electronic brake control module (EBCM)
• Electronic ignition module (spark control)
• Electronic power steering module (EPS)
• Fuel injectors
• Powertrain control module (PCM)
• Park neutral position (PNP) switch
Do yourself a favor an take it to a qualified repair shop !
Jun 03, 2017 | 2007 Chevrolet Chevrolet HHR LT
Tx 2.5 is on 7
To reconfigure the controller to factory setting:
1) Hold both the "Mode" and "Stop" buttons down while removing the magnetic key.
2) While continuing to hold both buttons down, replace the magnetic key. All the lights will light up and "beep".
3) Whille continuing to hold both buttons down, press the + button.
It should now be reconfigured.
I hope this helps
May 28, 2012 | Sportcraft Tx2.5 Tx 2.5 Treadmill Motor...
Dead receiver/amp.No sound no dial lights. Voltage ok at wall outlet, present at back of amp, but not at auxiliary built-in AC outlet on case of amp. All 4 fuses OK. On/Off switch seem OK. What is the...
the power transformer may have blown the primary winding causing no power for the secondary windings witch means that the main power board has no power
Mar 06, 2011 | Onkyo TX-SR501 Receiver
Turn signals and brake lights won't function
GET A GOOD FUSE TESTER, TEST EACH FUSE. THERE ARE 2 FUSEBOXES. ONE UNDER THE HOOD & ONE IN THE DASH. ALL FUSES CAN BE TESTED WHILE STILL IN PLACE. THERE ARE TEST POINTS FACING OUT. TURN ON IGNITION SWITCH FOR THIS TEST. POWER ON 1 SIDE, BAD FUSE POWER ON BOTH SIDES, GOOD FUSE. POWER ON NEITHER SIDE, SPARE FUSE.
IF ALL FUSES RELATED TO THIS PROBLEM TEST OK, CHECK OR REPLACE THE TURN/SIGNAL/HAZARD FLASHER, { LOCATED UNDER DASH, NEAR STEERING COLUMN, PROBABLY SQUARE & BLACK. IF THAT'S OK, IT WILL HAVE TO BE THE TURN SIGNAL/ HAZARD SWITCH. ALSO CALLED COMBINATION SWITCH. REMOVE THE PLASTIC HOUSING AROUND THE STEERING COLUMN UNDER THE STEERING WHEEL. IT LOOKS LIKE THE AIRBAG & A LOT OF SPECIALIZED TOOLS WILL BE NEEDED. YOU MAY HAVE TO EMPLOY A RELIABLE SHOP IF THE COMBINATION SWITCH IS THE PROBLEM
Jan 10, 2011 | 1996 Chevrolet Cavalier
I have a 6200 series hp photosmart printer. It is stuck in the shutting down mode. How do i fix it?
Please try the following solutions and keep your fingure crossed:
1. Conect the printer directly to the wall outlet
2. Power cycle:
Follow the steps below to power cycle your all-in-one:
1. Verify that the unit is switched on. Disconnect the USB/Ethernet cable from the All-in-One and also disconnect power cable from All-in-One and also from wall outlet.
2. Wait 30 seconds.
3. Plug in the power cable to All-in-One and also to wall outlet. and check the functionality.
3. Semi full reset
Reset the All-in-One to the factory default settings by using these instructions:
1) Press Red Eye Removal & Print Photos button simultaneously
2)Enter Special Key Combo is displayed on the screen.
Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
Display should say "Support" and display the FW rev XXXXX.
3) Press Right Arrow button untill "Reset Menu" is displayed. Press OK.
4) Press Right arrow untill "Semifull Reset" is displayed.
5) Press OK.
Jun 10, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Cobra 29ltd classic : no rx / tx
D23 is the reverse protection diode and it shorting is the primary reason your fuse blew. As you posted, power was applied in reverse, hence other components would also fail. Pls check:
1. D22 - 9.1V Zener Diode
2. TR23 (2SC1096) 9 Volts regulator
3. D19 - 5.1 Zener Diode
4. IC4 (TA7222) - Audio Amp
5. TR14 (2SC2029B/10) - Finals
6. TR15 (2SC2028B/20) - Driver
7. Most capacitors over 220uF (like C123, C114 & C112)
Hope that this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 04, 2008 | Radio Communications
Exercise & Fitness Logo
69 people viewed this question
Top Sportcraft Exercise & Fitness Experts
John
Are you a Sportcraft Exercise and Fitnes Expert? Answer questions, earn points and help others
