Question about Hotpoint Washing Machines
Hotpoint washing machine wt960 not working because fo8 code come
On screen fo8 code is come hotpoint washing machine wt960 after all machine is not working why
    Problem Solver:
  • 4 Answers
Hi Hitendra,
F08 is a sticking heater relay. First check that connections on pressure switch are good, Check that heater connections are good.Check the board connections.Check that pump filter is clear.
Hope this helps!
Wayne
Posted on Nov 23, 2014
  • 4 Answers
SOURCE: HOTPOINT F-01 error code
Try http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Posted on Feb 16, 2008
Malcg
  • 32 Answers
SOURCE: hotpoint wt960
Full manual can be downloaded from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/ultima-7kg-lcd-wm-19505771900.pdf
Technical helpline will be able to tell you what F10 means
Posted on Apr 13, 2008
IFIXALL
  • 868 Answers
SOURCE: Hi where is the filter for a hotpoint WT960 washing machine
Its most likely built into the tub and you don't need to access it.Under the agitator is usually the place on the tub they would put a filter
Posted on May 26, 2008
  • 86 Answers
SOURCE: Hotpoint wt960 lcd screen failure
Hi, I have experienced this problem on several hotpoint machines with led display's. There is really only one solution for it! If there are no wires hanging off then the answer is in the board, And you will need to replace it. It is a non servicable part and cost around £40.00+++.
Good luck.....
Posted on Dec 28, 2008
barkencoa
  • 3463 Answers
SOURCE: removal of the filter from a hotpoint wt960
Filter is located inside large black hose at rear of washer, remove lower rear panel and remove hose, and clean plastic filter inside hose.
Please rate my solution.
Thanks.
Posted on Mar 31, 2009
Hotpont washing machine wt960 fo8 code m/c stop
I believe F08 Error code is for a Heater fault
Issue: During a wash cycle the programme pauses part way through.
Nov 20, 2014 | Hotpoint Washing Machines
Code F-02 on hotpoint WT960
Check and clean the filter and drain hose. Make sure the hose isn't kinked.
Apr 22, 2012 | Hotpoint Ultima WF860 Front Load Washer
Fo8
Error code F08 is indicating that the heater relay is not being activated.
F08 error code for Hotpoint washing machine indicates Heater control or NTC (Thermistor) temperature sensor problem.
You need to check all the connections on the module, the pressure switch, and the heater element.
I hope this help to solve it; remember to rate this answer. Nice weekend.
Oct 02, 2010 | Washing Machines
Good luck.....
Dec 24, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wt960
this m,eans the water is not entering the machine it iseither the inlet valve or water off at tap
Dec 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
I have just fitted a new door lock on my washing machine hotpoint wm53p and now it wont work.
How do i replace the door handle on my hotpoint washing machine (wt960)?
Jul 21, 2008 | Hotpoint Washing Machines
Hotpoint Ultima WT960
may be the fuse in the pug, or the internal fuse within the machine..
Apr 18, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
271 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
