Question about LG Dryers
Lg tromm gas dryer burning smell shuts off
Burning smell shuts off
  • LG Master
  • 744 Answers
Hello Debi;
My name is Peter. I am a retired field service appliance technician.
You have a dangerous situation.
1.) First, your dryer is shutting down because your dryer is plugged up with lint and there is no air flow. You need to remove the top cover and control panel, the front cover and if your hot air distribution manifold id in the back or front end, remove that and clean. With a dry rag (DO NOT USE LIQUID CLEANERS), wipe the grease and grime off all components.
2.) The burning smell is the lint burning. Fortunately, due to the lack of air, the lint is being extinguished.
So far you are lucky. You have not had a major fire. DO NOT USE THE DRYER UNTIL THE ABOVE TASK HAS BEEN ACCOMPLISHED.
I wish I could provide you with more specific information on your dryer, but you did not provide a model number.
Posted on Nov 21, 2014
  • 6 Answers
SOURCE: LG Gas dryer doesn't dry clothes in one cycle
Have you checked your outside vent while it was running to see if the dryer was venting 100%. If your clothes are hot and humid I would say clean your vent pipe has a blockage and needs to be cleaned out. Also as far as the burning smell you could take the front off (unplug first) the dryer of by removing 4 screws one above and one below the latch and two at the bottom and there are two clips one at the top left and right push in with a puddy knife and lift the top up a couple inches and lift the front up off the bottom holders. Then you will have access to vacuuming the lint that is floating around the burner.
Posted on Dec 28, 2008
cherylogle
SOURCE: lg tromm dryer electric cooling light staying on
I called LG after seeing this light as well and they say it's supposed to stay on and should "blink" at the end of the cycle. I've never remembered this light staying on in all the years of owning this machine but she (LG rep) said it was normal. Otherwise, if you've checked everything and it's not drying clothes, you may need to have your dryer serviced. :(
Posted on Dec 14, 2009
PSITECHNICAL
  • 71 Answers
SOURCE: check filter light wont shut off and setting.lg tromm dryer
You might need to check the exhaust on the rear of the Dryer, or the blower motor iether one has lint inside, restricting the air flow
Posted on Dec 23, 2009
  • 221 Answers
SOURCE: When drying clothes in my gas dryer, you can smell
Hi, from what you describe, it sounds like you may have incomplete combustion, which would leave a residual odor while burning. Check your vent, on the outside where the flap opens and the exhaust leaves the building. Anything blocking that vent may cause an air flow problem. If you have good air flow when the dryer is running, the problem is going to be at the gas valve/burner and may need a professional. In my town, the gas company will come out and check problems like this for no charge, they don't replace parts but are good at troubleshooting. Best of luck.
Posted on Jan 17, 2010
SOURCE: why are the clothes coming out of the dryer
The problem might not be with the dryer, but with the washer. Let me explain. When I first got my LG w/d set, I did a web search, and found that front load washers tend to build up bacteria and mold(which one person said was staining her clothes). The solution was to leave the door of the washer open when not in use. That worked for me for the most part, but the musty smell persisted. I found that the soap tray was getting dirty(from mold/bacteria), and the area inside was even worse. So now I remove the soap tray when not using the washer. Also, some appliance stores have cleaning packs that dissolve in an empty washer load. They are supposed to clean out residue and kill bacteria that cause odor in "HE" washers that may only be noticeable from the dryer. The brand name of the product I have is "Washer Fresh", and they're about $12 for 6 "PowerPacs".
Posted on May 07, 2010
Loud banding noise in my LG Tromm DLE7177
Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
Feb 11, 2013 | LG Tromm Electric Dryer
Gas smell from vent
Something that runs on gas in your house is leaking that out, not necessarily the dryer. Check all your pilot lights to make sure they're either burning or that device's gas is shut off by valve. You don't share buildings with another family, do you? (like a duplex or quad housing)
Oct 19, 2012 | LG DLG3788W Gas Dryer
My LG TROMM DLG2526W dryer is not heating.
Check thermistors. Two in heating chamber and one or two in fan housing. Clean surfaces and check for continuity.
Aug 17, 2017 | LG DLG5932W Gas Dryer
My LG tromm dryer wont heat and i don't know how ignite the pilot
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 02, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
LG TROMM DRYER DLE5977 Burning Smell
It is a POS dryer, we have the same one. My suggestion get another dryer. We vacuumed it all out (don't you have a problem with the lint catcher?) Then it started loud pounding noise, which a lot of people seem to have the same problem, then our sensor went out and we had to dry the clothes 5-10 x's...now crack in stainless steel drum and is chewing up all our expensive clothes!
Feb 21, 2009 | LG DLE5977 Stainless Steel Electric Dryer
Dryers Logo
199 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
