How do you reset the margin on SC-XE6000 when right margin is stuck mid-page width?
Just got used typewriter.
  • 34 Answers
Press and hold margin release key while sliding carriage to the left using the carriage release on the end of the carriage, behind the platen (roller) knob, there is one at each end. Put the carriage where you want it and press margin set to reset margin position.
Posted on Nov 22, 2014
SOURCE: margin release
you need to hit the alt key while hitting the number that corresponds with M rel. This goes for any of those gray options above the number key. Took me a couple of weeks to figure that one out. Good Luck!
Posted on Apr 04, 2008
  • 329 Answers
SOURCE: Swintec 2600 Electric Typewriter
MARGINS: Left margin space or tab to where you want margin set and depress the mar L key. Sometimes the key has to be depressed as you hit the code key. If you want to move carrige to the left, go to margin hit margin release and bk space to where you want. Same with the right margin only use th R margin key. Code key usually keys have second message are in green, yellow or red. Use code key with the small print on the key to activate that function.... Good luck
Posted on Aug 01, 2008
Geno111
  • 183 Answers
SOURCE: cant find margin release
Generally, the way the margins work is, wherever the printhead is positioned, when you hit the right or left margin set, is where the margin is set. To reset the margin you must move the printhead to where you want the margin set, and hit the appropriate mar. set button. to move the printhead past where the margin is set, you must hit the "mar rel" button, and then backspace or space to where you want he printhead positioned. On machines without a "mar rel" button, you just use the "backspace" or "spacebar" to move past the margin. You can't release the margins permenantly, you can only move them, or move past them using the above mentioned processes.
Posted on Oct 24, 2008
Geno111
  • 183 Answers
SOURCE: electric typewriter set the margin
if you still have problem, repost with make and model typewriter, different methods are used with different machines
Posted on Nov 01, 2008
  • 125 Answers
SOURCE: Left and right margins of typewriter on Brother ML 500 Memory
Hi:
First find the margin release key and press it once. Then use the spacebar to move the carrier forward and reset the right margin. Or again use the margin release key by pressing it once and then press and hold the backspace key to move through where the left margin was and reset it at the point where you want it.
Andrew
Posted on Mar 19, 2009
How do I set or change the margins on my Royal Safari typewriter?
If you are following user's manual instructions to reset the margin and can't, maybe your Royal Safari is defective? Insist trying and if still no luck try to ge a typwriter repairman, a species in near extintion by now.
Jul 02, 2015 | Royal Office Equipment & Supplies
Need manual for SC -XE6000 and the right margin is stuck as if locked in the end of a label position about 3/4 across the page. Just purchased at a garage sale.
reset the margin or look for something interfering with the movement try turning it off and manually move the carrier to the left and right it should move with only a slight resistance
Nov 09, 2014 | Office Equipment & Supplies
Left margin stuck at center of page What to do besides reset margins? Can't back up to reset the left margin
You have to push the Mar Rel key then backspace to the new margin and press the Left Mar key
Jun 05, 2014 | IBM Wheelwriter 6 Typewriter
Carrier stops in the middle and moves only when press TAB twice
Hold down the margin release key and turn on, machine will print test till turn off. Resets the TW, depress the left and right margin keys together will reset the margins to 10 and 75.
Feb 02, 2014 | Swintec 8014-s Electric Typewriter W/...
R margin is not in the right place
Not positive about but many electronics you must press and release the mar rel key for it to function.
DickyO
Apr 05, 2010 | Brother EM-530 Typewriter
My typewriter is stuck at the left margin. I
My guess would be that the left and right margins are set at the same place. Try resetting the right margin and see if that's the problem. I used to experience this a lot with kids playing with the typewriter.
Oct 15, 2009 | Brother ML-300 Typewriter
Margin settings
You have to hold the magic margin button down while you move the carriage all the way to the left, then release the margin button. Then repeat for thr right margin. Hold the right magic margin button down while moving the carriage all the way to the right, then release the margin button.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Sep 05, 2009 | Office Equipment & Supplies
Hi:
Andrew
Mar 19, 2009 | Brother ML-500 Typewriter
74 people viewed this question
k24674
jasbo
jasbo
