Question about Pioneer DJM-600 Silver Professional DJ Mixer with Auto Beat Cou Home Equalizer
I have a DJM 600. CF A does not work when assigned to the channel receiving sound. I can hear sound in the headphones and when CF A is set to any other channel they work playback as THRU. CF B works n
I've tried using all the CF Assign knob options. I've tried changing the crossfader. I've tried swapping deck. I tried using CF B on all channels and playback is normal. Really frustrated. Think previous owner may have modded something and did not say so
marsrover
  • 682 Answers
SOURCE: djm 600
start with connections and try to clean fader with lubricant contact cleaner from radio shack or any electronics store.
Posted on Sep 23, 2008
killer_clown
  • 86 Answers
SOURCE: djm 600 - fader panel not working
i would recommend checking a fuse somthing with such good quality would less liky need a replace ment unless the power cut really damaged it internily
Posted on Oct 15, 2008
djproaudio
  • 515 Answers
SOURCE: Pioneer DJM-600 Bad feedback when i turn up the master volume
It's not your ground wire with the issue, but your RCA cables. Try disconnecting both turntables, and connect 1 at a time, and do the same test, this way you can isolate the problem. Once you've isolated the problem, then you'll need to have the RCA cables replaced on your turntable.
You might also want to check the Cartridges as well. Sometimes a bad cartridge or headshell connection will cause this issue. Worst case scenario, its your tonearm, but that should be test last.
Also, on the rear of your mixer, there is a gain volume pot, make sure this is not maxed out. Keep it about 3/4 of they up. Again, this is on the rear of your mixer where you connect everything.
- OPTiC
http://djproaudio.com
http://djprolab.com
Posted on Dec 18, 2008
djproaudio
  • 515 Answers
SOURCE: New DJM 600 User
Get yourself a manual. It will help you. You can DOWNLOAD A FREE COPY of the PIONEER DJM600 INSTRUCTION MANUAL from HERE.
Now, you have to use the CUE button function on each channel to select what you want to hear when you cue things in the headphones. Last, you control the volume of the master cue in the headphones using the CUE volume of the headphone CUE section.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
  • 256 Answers
SOURCE: When moving the bottom knob on channel 1 and 2 of ...
That sounds like you could have some dust built-up on your sliders. Get yourself some dust repellant spray or silicone spray normally found at you nearest computer store. That will definately sort your problem
Posted on Jun 08, 2010
One of my decks sound louder than the other
I'd say the cartridge is getting tired. Swap the head shells with carts and test. Cheers john. Styluscity
Nov 27, 2012 | Technics SL-1210 Turntable
I have a djm 400 and it has started producing a buzzing sound through the speakers. I can take the same speaker cables from the djm 400 and hook them up to my backup mixer and the buzzing goes away. What...
Does it buzz through cans? (headphones). Try listening on headphones (turn off any amps and speakers) on cue to each channel you use and to the master output. is it stil there? if so it's an all round earthing fault. If it's all good through the cans (sorry...I mean headphones), try it with the amp/s on again. If the buzz is back it souds like the screen on the main audio output connecters has come off inside.
It's a quick fix, but if you have never used a solder iron, take to someone who has.
Jan 07, 2011 | Pioneer DJm 400 Professional DJ Mixer
My vmx1000 mixer the crossfader only cuts out one side the other just contiues to play no matter what side u put it on
I suspect that one element of the crossfader pot (slider) is broken. Possible cause is if something fell on the knob or wear from use.
If one end breaks on one channel, the opposite end side will remain on full while the other channel will behave normally.
Replacement of the dual pot will LIKELY involve removing all panel knobs to remove the circuit board to replace the pot after disassembly of the unit. Not for the casual DIY person.
Nov 17, 2010 | Behringer Pro Mixer VMX1000USB...
The crossfader won't gradually fade from deck to deck.
In the front of the IDJ2 system there should be a switch labeled "CF Slope." Switch it downward and you should be good.
Jun 02, 2010 | Numark iDJ2 - DJ iPOD Mixer Docking...
When moving the bottom knob on channel 1 and 2 of the pioneer djm 600 mixer there is a slight interference sound coming through the speakers. Channel 3 and 4 are fine
May 21, 2010 | Pioneer DJM-600 Silver Professional DJ...
I think my crossfader stop working for some reason. when im on side B i get sound then i slide over to side A and i still get sound from side be,,, all the assign are right also the bass mid and hi kill...
I suspect one end of the crossfader pot has broken from the element. The fader probably costs less than $5.
You likely will have to remove all the knobs and some screws to seperate the board with the fader from the front panel so you can replace the fader.
VERIFY the pot is bad with an ohmmeter before dis-assembling however.
You MAY be in luck. It looks like the cross fader has a connector which MIGHT allow you to remove it or certainly only a small board for replacement, seeing these take abuse.
It appears that the cross fader is a dual 100K type B taper.
Apr 26, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
How do i set the control for the crossfader on the djx700
u should b able to use it so long as you change the mode from stereo to split, then you can just use the panel at the bottom that says "crossfader:" :P
Feb 11, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
I have an Gemini TT01 MKII turntable. The problem I have is that only one speaker audible, with a 2x RCA phono plugs(with ground cable). If I press the mono button on the amp, both speakers are...
The mono button on your amp is simply feeding one channel to both sides, so is no indication that the other channel is working. Here's what to do. With the good channel comming off your deck, swap it over so it's going in the dead channel side on your amp. If the channel does not spring into life, it's not the record deck that is faulty, but your amp. Now your thinking but it works on CD! True, but the record deck socket on the amp has another pre-amp just for that purpose only. You can track this pre-amp down by following the wires from the socket.
If on the other hand the dead channel comes to life when you swap the jacks around, then it's is the deck. The most obvious fault being the cartridge. But some decks also have a pre-amp in them.
Jan 21, 2010 | Philips geminiĀ® TT-01 MKII Turntable
Djm 500 mixer cf missing and does not turn on does it need the cf to turn on?
no and you can use channel fader of each channel to control the channel without cross fading.
Dec 18, 2009 | Pioneer DJM-600 Silver Professional DJ...
46 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
