Question about Microwave Ovens
There's no power to my sharp LC24LE240E. I've checked the fuse and power outlet and both are fine. Any ideas??
    Prodigy:
    An expert who has answered 500 questions.
  • Microwave Ovens Expert
  • 650 Answers
It may be a thermal fuse. There is a thermal fuse in most modern microwaves that will kill the unit if something gets too hot in the cavity. Sometimes the magnetron thermal protector can shut down the unit. check them both for continuity.
Posted on Nov 22, 2014
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: My Sharp over the range
Itmay be the fuse, which is usually located behind the grille or on thefloor of the oven behind the control panel or between the door switches.
Ifthe fuse is good, it may be an open thermostat or thermal cutout (TCO)/ thermal fuse on or near the magnetron or on top of the cavity / bodyof the oven.
If it goes dead for a while during or after cookingthen comes back on, the magnetron is probably overheating and causingthe magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
Ifit goes dead or blows the breaker (or GFI) when you plug it in or open or closethe door, then there's a problem with a door switch or door switchmount.
If it's intermittent or random, it may be a badconnection, usually on the control board or a loose fuse holder, oreven an intermittent fuse.
While we don't have that exact manual, we do have a similar service manual here which should be close enough to help you or someone you know troubleshoot these basics.
Once you know what's wrong, the best place to order Sharp parts is Tritronics.
Posted on Oct 20, 2008
Sharp Carousel Microwave Mdl 1875 for our RV is dead
>> We also tried plugging our toaster into the microwave plug outlet, and the toaster wouldn't work in that outlet, but worked just fine in a different outlet in the RV.
This means the outlet you plug your microwave into needs to be fixed in addition to fixing the oven. Breaker? Fuse?
>> I understand from another RV forum that microwave ovens for RVs have "special circuitry and cooling features" not found in regular countertop ovens for household use.
Not really in my experience. Any microwave supplied with clean AC power and proper venting space will be fine.
But I'd bet your microwave can be fixed affordably.
The main internal things which can result in this model being dead (no display, no light when you open the door, no beep when you press a pad on the keypad) would be the 20A fuse and the magnetron temperature fuse. There could also be bad connections on the noise filter board.
Also, sometimes a power surge can cause the power to be interrupted to the low voltage transformer on the board, and I regularly repair those boards. I can also write a technical statement to your insurance company or to an RV park as needed.
At my Web site, I have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The relevant service manuals for this model are here and here.
You can order Sharp parts from Sears or Encompass.
Contact me directly if you need more help.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
Mar 08, 2017 | Sharp R1875: Over the Range Convection...
Sharp R-1870F Microwave Won't turn on
Could be just a fuse but probably the diode pack or magnetron.
May 24, 2017 | Sharp R-1870 Convection/Microwave Oven
I have a built-in AEG Microwave code MC166(0E?) My son unfortunately used the microwave as a timer so it was on for 30mins without anything in it. It now won't turn "on"; no light/clock...
What fuse did you change? The fuse on the wiring that leads to the microwave needs to be intact, then the fuse in the Microwave itself needs to be checked. Usually there is a plug where the microwave is plugged in, in the cabinet above the microwave, you can take another small appliance or a power tester to make sure power is available in the outlet where the microwave is plugged in. If the power is on at the outlet then you'll know that it is the microwave itself that has turned itself off for some reason. You can get manuals for these ovens at this website
May 11, 2011 | Microwave Ovens
No power everything was fine then nothing when i got home is there any fuses to check in the microwave
There is a fuse under the cover, as well as a couple of safety thermostats that can cause a dead oven. It may also be that the power transformer for the control circuit board has failed. I've seen several Sharp ovens where the transformer died because of power surges. This would cause no display and no functions even though the oven has power. Also, did you make sure the outlet your oven is plugged into has power? If it's a GFI outlet it may need to be reset, or a circuit breaker in your electric service panel may have tripped.
Hope this helps, and thanks for using Fixya!
Feb 28, 2010 | Sharp R-1850A Convection/Microwave Oven
Microwave just stopped working
  • Internal fuse may have opened
  • Door interlock may have failed
  • Magnetron may have failed
  • Control panel may have failed
Jun 19, 2017 | Sharp R-1492 Microwave Oven
Microwave Ovens Logo
123 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
