Question about Fenix HP11 277 Lumens LED Headlamp Replaces HP10 With Headlight Diffuser Lens
How do i repair my Fenix HP11.
There is a damage in the electrical wire, on the ledlight side
My driver's side electric window & also my electric mirror on same Side I checked fuses & they ok so wot cud it be it's a 2004 ford focus 1.6 chia
By your description, it sounds like a broken or damaged wire to the door, in the wiring harness. Was that car in a body shop for repair in that area, at any time?
May 15, 2017 | Ford Cars & Trucks
What do I do when the dishwasher is stuck on P2?
GENERAL INFO ERROR CODES PROBLEM PARTS SOLUTION E1 NOT ENOUGH WATER INLET VALVE CLEAN OR REPLACE E2 NOT DRAINING DRAIN PUMP KINKED HOSE--ADJUST HOSE TOO HIGH--ADJUST PUMP FAULTY--REPLACE E3 WATER TEMP TOO COOL THERMOSTAT STAT OPEN--REPLACE TIMER CONTACTS OPEN-- REPLACE HEATER OPEN--- REPLACE ABOVE FAULTS CAN ALSO CAUSE TIMER TO STALL(TIMER STOPS TO ALLOW HEATING OF WATER) TIMER WOULD STALL AT THE 2,5,7 AND 10 O'CLOCK POSITION E4 OVERFLOW SWITCH ACTIVATED CHECK FLOAT IS FREE CHECK LEVEL OF D/W SOAP- AMOUNT AND KIND WASHARM STUCK OR SPLIT E5 E6 & E7 TEMP SENSOR THERMOSTAT REPLACE ERROR CODES: DDW497W Problem Solution Error 1 Water supply is turned off Turn water supply on Detached / damaged pipe Replace / readjust pipe Low water pressure Requires min. 0.04Mpa water pressure Defective water fill valve Replace water fill valve Damaged or defective wiring Repair the wiring Defective pressure switch Replace pressure switch Heavy water usage elsewhere in home Use unit when water usage is at a minimum Defective electric control Replace electric control Error 2 Sump or filter is obstructed Clear the sump and filter Damaged/defective drain pump Repair or replace drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 3 Voltage is too low Minimum voltage of 198 V Damaged/ defective thermostat Replace the thermostat Damaged or defective wiring Repair the wiring NTC thermistor damaged/out of position Replace or readjust the thermistor Damaged/ defective heating element Replace the heating element Defective electric control Replace the electric control Error 4 Sump or filter is obstructed Clear the sump and filter Loose or damaged sump pump/drain pump Repair or replace sump pump/drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Loose heater element Tighten heater element mounting nuts Loose spray arm Tighten spray arm Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Defective Microswitch Replace microswitch Float- defective or not in the right position Reajust / replace float Error 5 Damaged/ defective power switch Replace power switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 6 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too low Temperature should be above -20? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 7 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too high Temperature should be below 120? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric contr
Nov 27, 2014 | Danby DDW611WLED
Can you open the switch end of fenix hl21?
the plastic will break and even if you do get access to that, the issue with the corrosion will still cause problems.
Nov 24, 2013 | Fenix Flashlights Black HL21 Fenix HL21...
Back to the drawing board You guys almost got us killed (papajoe480@yahoo.com) I won't hold my breath for your response
in most cases you can here it when the key is turned on you could do a pressure test if you know someone with a tester or a garage does not charge to much to test it
Jan 24, 2013 | Garmin fenix - GPS receiver
I have a Fenix TK15 that doesn' light up. I have changed batteries, still no light
Hi marlyn engaling...
Sounds like you need to replace your bulb, it may be burned out.
Also check the switch and also make sure the spring in the back of the flashlight is touching the battery tightly to make good contact.
Bud
Sep 18, 2012 | Fenix TK15
Fenix hp11 headlight
Hi, I have some experience with this unbekievable good headlight(when it works).
I had a hp10 what started to stop more and more.
After a while it wasn't going on.
5 years warrenty, so i got a new one, the new model.hp11
The main problem is the wire from battery case and the head led.
When there a litte damage inside this wire, light goes of not going on it selfs when it connecting again. After a while it will not work any more.
(if you have a welding station you fix it your self (battery case,can go open by unscrew the wire entrance.)
Chack battery case if the springs are all still connecting the battery.
If you put in one battery false on there is short cut and al sprigs get so hot they will shrink. And stay in that position..fix that your self or ring/ contact the shop you bought it.
There 5 year of garrantie.
wonderfull
Jul 25, 2012 | Fenix Camping, Backpacking & Hiking
2000 lincoln ls ac is blowing hot air on pass side
On the central console is the A/C module. Inside A/C module are driver's side & passenger's side air flaps for mixing hot & cold air and directed air flows towards driver's side & passenger's side according to driver commands. The passenger's side flap for mixing hot & cold air according to driver commands is bad. Flaps are actuated by electrical step by step motors. Could be damaged the flap actuator (motor), the flap mechanism (blocked in "HOT" air position), and / or electrical supply wires. You must access the passenger's side flap for mixing hot & cold air, and see what happens when you command cold air to the driver's side: flap mechanism, flap actuator, supply wires, ... Repair & replace bad pieces and test the A/C system.
Aug 12, 2010 | 2000 Lincoln LS
Fenix HP11 277 Lumens LED Headlamp Replaces HP10 With Headlight Diffuser Lens Logo
119 people viewed this question
Top Fenix Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Fenix Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
