Question about Yamaha 2008 FX Nytro Base
My back end of my snowmobile won't come up unless i pull it up, whats wrong
Took it apart, and hope its my shock
    Top Expert:
  • Yamaha Master
  • 2,044 Answers
I would look at your SHOCK, SPRINGS, HARDWARE. I would break out the PB BLASTER and lube it up and possibly get some HEAT onto some of the parts to get some movement. GREASE, BOUNCE, BOUNCE, BOUNCE... Something in your Suspension is not moving freely...
Posted on Nov 21, 2014
Timing is off bad on the cuckoo part of the clock. It won't stop and runs till the weight hits the ground.
We had the problem with ours when I was a kid. What we did on ours was to turn the hands until the clock cuckoos. Then we removed the hands from the stem and placed them back at the correct time. Hopefully, you can remove the hands from the stem without a problem. Don't force it however. Good luck.
Feb 01, 2013 | Watches
Took washer apart, put it back together and now it won't start
ok... seems that it is trying to fill but wont...first...for all problems after dis-assembly of anything...I always recheck all wire connections...yould be amazed how a wire can be pulled off and you not notice it...next...if they are all tight...next ensure your water supply is turned back on at the faucet....try unplugging the unit from the wall, waiting 5-6 mins and plug it back in..to see if the controls reset..phillip
Jul 04, 2012 | Bosch Nexxt Premium WFMC6400UC Front Load...
I took my desktop apart and put it back together and now it won turn on
Open it back up and check to make sure you didn't accidentally pull one of the cables out.
Jun 30, 2012 | Dell Computers & Internet
Had rear brakes replaced about a month and half, had a thunking noise. took back, said i had tar on tire causing noise. said it would go away, after 3 to 4 weeks got worst, only heard noise when applying...
Hello and welcome to FixYa!
Even if you are missing a lug nut it won't make a noise if the rest are tight. I suspect that the problem will be on the wheel bearing. The wheel bearing can be worn out that's why you hear a noise. I suggest that you go for the wheel bearing replacement to resolve the issue.
Hope this helps and thank you for using FixYa! Have a good one!
Sep 03, 2011 | Dodge Caravan Cars & Trucks
I have a 2002 Tahoe LT with Autoride, when getting tires replaced I noticed one front and one rear shock were leaking, replacement quote was approx $550 each. Does a leaking shock need to be replaced...
Hello, my name is Shaun. I will do my best to help you out with your problem. As far as your shocks needing to be replaced ASAP, i would say it's not an emergency. Worn shocks will result in a pretty bouncy ride, and if let go long enough, could result in irregular tire wear, but your truck won't fall apart if you don't change them today. Ultimately, the spring is what holds your truck in the air, the shock is just there to absorb impact and make your ride a little more comfortable. They also help in cornering, so expect a little bit of over-steer, as your truck will roll more quickly in tight turns. The shocks should be replaced in pairs, as different shocks have different ride qualities. (i.e both fronts, then both backs.) The Monroe shocks are okay, but they don't last quite as long as a higher end shock. At the price they quoted, you could buy a higher-end shock, do the work yourself, and still save a ton of money. And yes, it is basically as simple as unbolting the old shock and replacing it with the new. My advice to you would be to purchase a Haynes manual for your truck when you purchase the shocks. This will give you step-by-step instructions to change the shocks and will also be a valuable asset should other problems arise. Hope this helped you out, and if you have any more in-depth questions, feel free to reply to this answer and i will get back to you. Have a great day!
Jun 13, 2011 | Chevrolet Tahoe Cars & Trucks
Fixing a Polaris Indy 400 snowmobile pull cord - I took it apart and cant get it back together
hello usually on any pull start, you have to wind the spring inside,the cover, on my atv i put the rope on the pulley burn the end of the rope and make a point on the end of the rope. put the pulley back in the case, turn the pulley backwards untill you get a lot of tension on pulley and turn the case up wright where you can see hole where rope comes out, turn pulley untill you see end of rope through hole. fish rope out with a pair of tweezers or a pair of themostats
Feb 06, 2010 | Polaris New Genuine Polaris Snowmobile...
I have a 1992 polaris indy 500 efi snowmobile and I just put a new piston cylinder head on it and got ot to run but however it will run and take off accept when the throttle is wide open it dies and I have...
hi ,i have a small and big project ,just busted a piston in my 500 piolaris indy snowmobile & to it apart & forgot about the presstone and it's all at the bottom of my engine ,where do i go from here &&&& another thing i had to drive awhile with the busted piston so what would be the damge ,what should i do with the whole thing
Jan 17, 2010 | Polaris New Genuine Polaris Snowmobile...
Ok took my whole computer apart and fixed a part that was loose but my ibm t23 turns fan runs and nothing else what can I do?
Well hopefully you wore a static band you may have shock your ram when pulling it out or putting it back in.
Dec 30, 2009 | IBM ThinkPad T30 2366 Notebook
Yamaha 2008 FX Nytro Base Logo
290 people viewed this question
Top Yamaha Winter Sports Experts
Arnie Burke
Arnie Burke
Mike
Are you a Yamaha Winter Sport Expert? Answer questions, earn points and help others
