Question about ASUS Computers & Internet
<!-- from fixya rte -->My asus has restarting showing at all time - ASUS Computers & Internet
    Scholar:
    New Friend:
  • 100 Answers
Restarting usually is an indication of a faulty power supply.. Either the actual power supply, or bad capacitors on the motherboard. Look at the motherboard at look for bulging, splitting or leaking capacitors. The are little cylinders sticking up all over. The should be cylindrical with flat tops and bottoms. If they are bulging, split or leaking, then you have a bad motherboard. You could just replace the caps, but usually the cost of a replacement board is cheaper, and faster than trying to find replacement caps of good quality.
Posted on Nov 25, 2014
How to enter bios asus on my asus v550c
On systems with Windows 8 pre-installed, you can access the UEFI (BIOS) setup screens from the Windows 8 boot menu:
  1. Press the Windows key + C, or swipe in from the right edge of the screen to open your Charms.
  2. Click Settings.
  3. Click Change PC Settings.
  4. In PC Settings, select General.
  5. Under Advanced startup, click Restart now. The system will restart and show the Windows 8 boot menu.
  6. In the boot menu, select Troubleshoot.
  7. In the Troubleshoot menu, select Advanced options.
  8. In the Advanced options menu, select UEFI Firmware Settings.
  9. Click Restart to restart the system and enter UEFI (BIOS).
How to access BIOS on an ASUS laptop
Dec 06, 2013 | Computers & Internet
Tip
How to get Apple Ipad to charge from usb
To get Ipad to show as charging download Asus AiCharger from web and restart computer after install.Plug in usb from Ipad and should now show charging http://event.asus.com/mb/2010/ai_charger/
on Feb 17, 2011 | Tablets & eReaders
ASUS ENGT240 Graphic card installation failure
try installing the driver first then disable the motherboard display adapter then then shut dowm computer put card in . change montior cord to card  boot up   ( make sure that resoluting in card driver software is right for you before you do alll the above .some time the card defalt at install is to high for montior to handel by card maker wants to show off) it should work .sonetimes windows plug and pray can be flaky hope this helps should work unless you card chipset is not complable with motherboard
Apr 03, 2010 | ASUS NVIDIA Graphic Card
P4C800E Deluxe Motherboard Problem
A bad checksum can be caused by a flat or near flat BIOS battery. Replace the battery and set the date and time.
Also set the BIOS to the default setup, ie go to reload default settings, or remove the BIOS battery for 1/2 hour the insert the battery and set the Date and Time.
Jul 24, 2009 | ASUS P4C800-E Deluxe Motherboard
ASUS M530 not start after restart show blue screen with logo
Your firmware is corrupt pls contact service centre
Mar 21, 2009 | ASUS M530W Pocket PC
Cup fan erro
Firt remove the covering of the cabinet then locate a battery take it out rub it for few seconds.Place it back the way it was.Now if you have another cpu fan port on the mother board then plug your cpufans cable to it.Now restart your computer start pressing F2 ie bios settings.Now check the time and date. restart it again. See if it fixes the problem.
Please rate me> Karatela ;-)
Dec 07, 2007 | ASUS A8N-VM Motherboard
PC Restarts
check for the BIOS battery voltage! it should be 3 volts. if not, replace it!
Nov 16, 2007 | ASUS P5S800-VM Motherboard
Reg-problems facing while operating computer
check bios setup (pres del or f10 at startup) for cpu speed if speed is mentioned less than actual then change to the right value. if cpu speed is ok in bios then speed info might have changed from registry. my computer>hkey_local_machine>hardware>description>system>central processor>hightlight o folder>on the right pane select processor name status> change this to original value.
Oct 15, 2007 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
Computers & Internet Logo
51 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
