Question about Magnavox Televison & Video
My magnavox ZV457MG9, both the dvd and vcr lights are flashing and nothing is working, not responding to any controls at all, any suggestions? - thanks.
  • 9 Answers
SOURCE: need remote control code
I found that on the back of the 2205 it said that the unit was made by Funai. I looked in the Innovage book and found that the codes for Funai DVD are 231 and 233. 233 worked on mine. Good luck.
Posted on Jan 06, 2008
salsaurbana
  • 56 Answers
SOURCE: HOW DO I CONNECT MAGNAVOX DVD/ VCR TO VIZIO FLAT SCREEN
Is simply. get the audio/vido cables and look on the back of the TV and connect from the audio video outputs from the combo to the audio video inputs on the tv. remember the colors of the terminals and connect them that matches the red, white (audio) and the yellow (video). Using the remote locate the button "input" or "source", and select video 1 or 2, depending where you connected it.
Posted on Nov 19, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: need a code for a magnavox dvd/vcr com for a jumbo universal remo
7-1-1 and 0-7-1-1 are the Magnavox universals.
Posted on Feb 15, 2009
MNfisherman
  • 11896 Answers
SOURCE: hooking a magnavox dvd/vcr to a analog tv
You will need to get new cables.
Posted on May 04, 2009
SOURCE: Need a replacement remote control
Just call Magnavox and get it for $17.95 shipping and all. They are cheaper than any I found on line.
Posted on Jul 09, 2009
How to do a factory reset on Magnavox zv457MG9 DVD/VCR Combo
1) the reset is done automatically when you turn off and again turn on the RST block for the microcontroller put the signal and reset the DVD. the ROM is device where is all information is put it by the factory, no one can be erased.
2) test the power supply voltage is +5vd for digital device -5vd+ 9-12vdc for motor, servomechanis, +15-15 for video.
3)tes the servomechanism is working such motor *** a) search b)track c0 sledge d) CLV see are working moving the OPU optical pick up unit contain the lasser beam for read the TOC.
If you can not do it anything go to the repair shop TV. for fix it.
tight any wires connector , and clean from corrosion, oxide. do not touch any component with your hand ESD, can destroy the component.
God bless you , see the block d.
Jul 15, 2012 | Magnavox ZV457MG9 DVD Recorder VCR
I cannot record digital when I try to set up my Magnavox ZV457MG9 (DVD). The unit will only record in the external L1. I have a Comcast box.
This is normal for the ZV457MG9 units. The Magnavox ZV457MG9 does not have an analog (NTSC) tuner; additionally there is no digital (ATSC or QAM) tuner either. It will only record on line in (L1) which is a composite input (limited to SD). The HDMI port on the recorder is an HDMI out to TV, not an input. The component video jacks are also only outputs.
The manual for the Magnavox ZV457MG9/F7 is available here: http://download.m4c.magnavox.com/files/z/zv427mg9_f7/zv427mg9_f7_dfu_aen.pdf . The unit was manufactured for Magnavox by Funai; thus another link to the manual is http://www.funai-corp.com/6pdf/om/ZV427MG9.pdf .
I wish that I had better news for you.
(If your DVD/VCR recorder had a tuner, it would record off a coaxial (antenna) cable input. Many DVRs can record off the HD connection (HDMI or component); that may be a better option for replacing this Magnavox unit.)
Oct 01, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
I would like to download the manual for this magnavox ZV457MG9 vcr/dvd recorder machine as I can't find mine. Please send me a link I can use to do this. Thanks
I found two:
The entire manual online (also has download link): http://www.manualowl.com/m/Magnavox/ZV457MG9/Manual/191523
The downloadable version: (It SHOULD work) http://download.m4c.magnavox.com/files/z/zv457mg9_f7/zv457mg9_f7_dfu_aen.pdf
This isn't much but it's something: http://download.p4c.philips.com/files/z/zv457mg9_f7/zv457mg9_f7_qsg_aen.pdf
Aug 23, 2011 | Magnavox ZV457MG9 DVD Recorder VCR
Need a manual for magnavox dvd record/vcr zv427mg9
You can download the manual from the manufacturer's web site at
Jun 14, 2011 | Magnavox ZV457MG9 DVD Recorder VCR
Sound goes up and down when recording with VCR tape on Magnavox ZV457MG9. I have tried different tapes and get the same problem. When you play the tape back the volume goes up and down
This is usually caused by poor contact between the tape and heads or the tape fluctuating as it goes through. First try a cleaning tape and see if that improves matters.Then get a friend to show you how to clean the tape path with alcohol and q tips.I assume there is no picture disturbance? There could also be other reasons like the auto level not working properly but start with the basics.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 25, 2011 | Magnavox ZV457MG9 DVD Recorder VCR
Magnavox DVD/VCR Recorder ZV457MG9 How do I finalize my DVD on this player/recorder?
http://www.ehow.com/how_8623235_do-finalize-magnavox-dvd.html is how to finalize a disk on Magnovoz! I have the ZV457MG9 - its model takes with
1) loading disk
2) select the set up button
3) select DVD edit
4) select finalize DVD
Then you finalize the DVD!!!
Jan 31, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Need a code to set my magnavox ZV457MG9 so it will play all regions on dvd/vcr
need hack code so my magnavox zv457mg9 will play dvd s from all region
Dec 02, 2009 | Philips Magnavox DVD/VCR Dual Player
My vcr won't play back
I have a Magnavox zv457mg9 DVD&VCR combo ,and the vcr records for a short period(10minutes) and then cuts off. This happens each time I try to record on the VCR. Any suggestions??
Feb 26, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Televison & Video Logo
177 people viewed this question
Top Magnavox Televison & Video Experts
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
