Question about Dryers
Is there a way to replace a 3-prong outlet to a 4-prong outlet using only the 3 wires available?
    New Friend:
  • 3 Answers
No. A four-prong outlet is designed to produce 220 vac. The wires behind your outlet will most likely only yield 110 vac. You would need to run a dedicated wire from your fuse box to the outlet. (In other words, time to hire somebody!)
Posted on Nov 21, 2014
5 Suggested Answers
  • 2920 Answers
SOURCE: Is there an adapter for a 4-prong plug to fit a 3-prong 220
they dont sell adapters like that..you have to change the cord and it wont hurt the dryer at all
Posted on Jan 29, 2009
  • 1028 Answers
SOURCE: wiring a 3 prong neptune to a 4 prong new outlet
red and black wires go to outside screws ..white goes to middle screw..lift green ground wire from screw in cabinet back and either tape off or connect to middle screw on connector ..green wire on cord goes in it's place
Posted on Jul 30, 2008
jsrock516
  • 5911 Answers
SOURCE: changing cord from 3 prong to 4 prong on frigidaire dryer
The following link explains how to convert your appliance from a 3-prong to a 4-prong power cord:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
I hope this helps you. Let me know if you still have questions.
Posted on Nov 11, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore series electric dryer need to replace 3 prong w/4 prong
The following link explains how to convert a 3-prong appliance cord to a 4-prong and vice-versa:
If you still have questions, please let me know. I hope this helps you.
Posted on Feb 27, 2009
I have a three prong plug washer/dryer but a 4 prong outlet need an adapter
YOU DONT ADAPT IT, U REPLACE THE RECEPTACLE OR USE THE CORRECT PRONG CORD. THE CORDS ARE NOT THAT EXPENSIVE FROM 20 TO 30 BUCKS AND EVEN CHEAPER ON LINE. IF U HAVE A NEWER HOME IT IS MANDATED BY LAW THAT YOU USE 4 PRONG CORD NOT 3 PRONG UNLESS THE HOME CAME WITH A 3 PRONG OUTLET.
Feb 16, 2014 | Frigidaire Washing Machines
Just moved, the dryer has a 4 prong plug and house has 3. Should it replace plug to dryer to 3 prong or house plug?
Buy a 3 wire cord and install it on the dryer. Hang onto the 4 wire one in case you move again.
Aug 28, 2011 | Whirlpool LER4634J Electric Dryer
I have a four prong clothes dryer plug that needs to go in a three prong outlet - 220v. Any ideas?
It's either you convert the 3-prong outlet to 4-prong or the 4-prong cord to 3-prong. But the latter is easier and more feasible. Unplug the dryer then disconnect the 4-prong cord from the dryer. Note that it has red, black, white, and green/yellow wires but sometimes the red and black wires are both replaced by same color wire, usually gray. The red and black wires are lines L1 and L2 reversibly, meaning they can switch places, while the white and green/yellow wires are the neutral line and ground, respectively.
Get yourself a 3-prong cord and note that it has red , black, and white wires but sometimes, like the 4-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect these 3 wires in the same manner they are connected as 4-prong cord to the terminal block. The wire strapped to the dryer cabinet and connected to the green/yellow wire of the 4-prong cord wire is now left hanging. The last step is to connect this hanging strap wire to the same terminal on the terminal block (center) where the white wire (neutral) is connected and it's done.
It can be observed that converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3. On the other hand, converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4. The link below might enlighten you further on this matter.
Electric Dryer Prong Conversion
Aug 20, 2011 | Maytag Dryers
How do I swap a grounded electrical outlet for an ungrounded outlet in an old house?
While a lot of people have replaced a lot of 2 prong ungrounded outlets with 3 prong outlets, as you probably know, it is an unsafe practice. The National Electric Code (NEC) permitted method is to replace the 2 prong outlet with a 3 prong GFCI outlet such as this:
http://www.homedepot.com/Electrical-Outlets-Plugs-Outlets/h_d1/N-5yc1vZ1xg4Zbp9i/R-202026815/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
For multiple outlets, the usual practice is to install the GFCI outlet at the first outlet in the circuit, then regular 3 prong outlets can be used to replace 2 prong outlets in all the downstream outlet locations as long as the "no equipment ground" stickers that come with the GFCI outlet are used and they are now GFCI protected outlets, per NEC.
Finding the first outlet in the circuit is not always easy. First, determine which outlets are on the circuit, then starting with the outlet closest to the electric panel, disconnect the wires and see if all the other outlets went out. It's kind of trial and error.
Once you have found that first outlet in the circuit, connect the hot wires coming from the electric panel to the LINE terminals of the GFCI and the wires going to the downstream oulets to the LOAD terminals of the GFCI. Full instructions come with the GFCI outlet.
The GFCI receptacles sold today won't work if connected incorrectly, so you will soon know if you did it wrong.
Once the GFCI outlet is installed at the first outlet, all of the downstream 2 prong outlets can be replaced with 3 prong outlets, using the stickers mentioned above to indicate that the outlets are not grounded.
Strange as it sounds, all downstream outlets _must_ be ungrounded when using this method.
Aug 29, 2010 | Hammering
Change a 3 prong plug to 4 prong
Is it an electric dryer or gas dryer? If it's a 120 volt gas dryer, then no, you need to keep it on a 3 prong cord. If it's an electric dryer, then yes it is possible to install a four prong plug onto it. Although it isn't recommended.
The main thing you need to know is which wire is ground. From the machine, it should be the green wire. On the plug, there should be on prong that is slightly longer than the other 3. The ground has to be the first one in the wall receptacle and the last one out. So the slightly longer one is where the green ground wire needs to be wired in. The other two wires are both power so it doesn't really matter which prong you wire those wires at.
Once again I'll remind you that it isn't recommended to convert 3 to 4 prongs like that. Just be careful and make sure you aren't touching any live wires.
Mar 26, 2010 | Dryers
Dryer outlet does not have common wire.
You can replace the 4 prong with a three prog cord found at Lowes etc.
First, disconnect the black wire, one of the "hot" connections, from the left side post by removing the terminal screw. This is one-half of the 240-volt connection.
Next, disconnect the red wire, another of the "hot" connections, from the right side post by removing the terminal screw. This is the other half of the 240-volt connection.
Then, disconnect the white wire from the center connection. It is used for the neutral connection.
Now, disconnect the green wire from the machine case by unscrewing the green screw.
The next step is critical to return your electrical connection to factory condition before installng the 3-prong cord! Locate the white machine wire that is now connected to the neutral (center) screw terminal. Disconnect it from there and install it under the green ground screw.Connect the outer two wires (hot wires) to the outer two screws, obviously, one on each screw.
Now connect the center wire (neutral) to the center post. You'll notice the white machine wire is now the case ground connection, unlike the 4-prong cord connection in which the green wire from the cord makes the ground connection.
Sep 10, 2009 | Dryers
Front loader whirlpool dryer (04') 3-prong cord; 4-prong outlet..
You'll need to get a new 4 prong cable. Connect wires as color coded now and connect the green to the frame.
Jul 16, 2009 | Whirlpool GEW9250P Electric Dryer
Feb 15, 2009 | Kenmore 62802 Electric Dryer
Change fr 3 prongs to 4
They wire in the same except the green wire will go to a ground screw which should be right in the same area with a green color to it. If no ground screw, hook the green together with the white (center) wire. Hope this helps!
Dec 27, 2008 | Frigidaire GLEQ642A Electric Dryer
Dryers Logo
60 people viewed this question
Top Dryers Experts
