Control board on ducane furnace blows when turned on
    Problem Solver:
  • 14 Answers
Either high temp switch is bad, check with electric meter for continuity, should be open until it reaches 160 degrees, or control board fan relay is stuck on.
Posted on Nov 26, 2014
2 Suggested Answers
  • 119 Answers
SOURCE: Ducane Furnace; AC condenser runs
The blower motor could be bad or the motor run capacitor may be bad. If you have the proper tools you can test the run capacitor yourself and replace it.
***CAUTION*** Anytimeyou are working on or around electricity you run the risk of shock and ordeath. Please consider consulting an expert before you open an electrical panelor appliance. ***CAUTION*** Capacitorshold a large electrical charge and will discharge upon contact with your skin.This is enough to stop your heart and cause death. If you are not confident ofyour abilities around these devices then please leave any testing or repairs toa professional. The capacitor is inside the unitand you have to remove the cover to see the inside of the electrical compartment.You will need to discharge the capacitor before you start working around it. Todo this take a screwdriver or other long metal tool with an insulated handleand cross both terminals on the capacitor to ground. You then remove both wiresgoing to the capacitor terminals, which on fan motors are typically brownwires. Capacitors are rated in MicroFarads (marked by a µF symbol) and have a voltage rating as well which istypically 370 volts or 440 volts. Youmust have a multimeter that can read micro farads to check a capacitor. You do that by placing one probeon the one terminal and the other probe on the other terminal and it shouldread the number of the rating, for example if your capacitor is rated likethis: 7.5µF then the fan rating should read 7.5µF (seven and a half MicroFarads). If the reading is more than 6% lower than it is supposed to be, thecapacitor is weak and needs replaced. If you read 0 (zero) then the capacitoris bad and needs replaced. Take the old one with your to match up at your localhvac supplier. A typical motor run capacitorrated at 5 µF +-6% at 370 Volts ACshamoke_0.jpg
Posted on Jun 18, 2011
Why does the furnace blow 5 amp fuses?
Its drawing much to high amperage on startup. It may be dirty, unmantained, blocked with something, or a bad run capacitor. Likely, at this stage, it needs replacing. If its belt drive, be sure you have the proper slack and the bearings, if needed, are oiled and not faulty.
Jul 18, 2015 | Emerson Lennox Ducane Armstrong Furnace...
My Ducane furnace lit and ran for about 3-4 minutes and just stopped and blew the fuse. Why.
if the fuse is to run the blower fan then investigate a seized blower motor
Dec 20, 2014 | Ducane Grilling
Furnace not stop blowing
the blower is a rotary flange and has its own power. turn it off or reset the thermostat.
Sep 26, 2013 | Ducane Grilling
My furnace throws heat, come on and off as desired, however the fan will not turn off, even if the thermostat is set to the off position. The only way to turn the furnace off is to turn the main switch...
In the meantime, a hifi shop may be able to fix your existing main board by checking the circuitry. A schematic would be of great help and maybe they can obtain one.
Oct 16, 2009 | Heating & Cooling
My AC unit wont blow the cold air.
if the ac outside is working, but not the furnace, means there is a control problem with the furnace, check wires in the furnace, make sure there is a blower wire plugged into the contact marked cool on the control panel of the furnace
Jul 09, 2009 | Fedders A&B Chassis A1A07W2B Air...
Ducane high efficiency propane furnace, pressure switch problem
A short cycle heat cycle indicat a pressure switch replacement was needed. This did not fix the problem. the problem was in PCV line since the end was filled with slugs and cause the line to backup with water. When this happen the system would stop asking for gas. the water would leak out and it would restart. The problem was fixed by cleaning value at end of PCV. This released the water, two quart of water, that was back up causing problem. Curious if a filter change indicator was providing a clue that was missed?
Jan 28, 2009 | Ducane 436 inch 2 - 2 burner Grill
I have a Ducane fits all 92 my lanlord installed,about 3 months ago.The thermostat is a new digital. The temp is set on 68,and if i go to 72 for example,the furnace starts and runs fine for about 3 to 5...
Sounds like you are not proving flame to me. Could be a variety of things. I think it may be the board...but that is a guess from past history with Ducane
Jan 15, 2009 | Heating & Cooling
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
