Question about Jensen Mcd5110 Marine Radio /am/ Fm/ Cd Receiver W/ Detachable Face
My Jensen MCD 5110 Marine radio acts like the antenna is unplugged. I can't figure out how to remove the radio from it's sleeve to re-plug the antenna jack (if that is the problem)
Removed front face and unscrewed back strap and wire plug.
    Problem Solver:
  • 7 Answers
I don't know much about marine radios. I am a ham radio operator, but they are much the same, if you do not hear any static (with squelch control turned down), then I suspect you are correct about the antenna. It could be the antenna itself, or the coax line to it, or the connection point at the radio or at the antenna. You're stuck without being able to remove it. If you do and find nothing at the radio, you'll need to check the connection at the antenna etc. Good luck.
Posted on Nov 28, 2014
HOW DO I FIND REPLACEMENT FACE PLATE & REMOTE FOR JENSON MODEL #DV2007
Here is where to get a replacement waterproof remote - http://www.jensenmarinedirect.com/jensen-waterproof-wired-remote-control.html With these marine radios the faceplate is usually the first thing to fail from water damage. Not that your is water damaged but because of this finding a used one is impossible on the net. You will have to contact Jensen for to see if they have the faceplate available separately. http://audiovox.com/jensen/ Good luck.
Regards, Tony
Apr 14, 2011 | Jensen Car Audio & Video
Where can i plug my ipod in to my jensen 9410 dvd mp3 receiver
here is what you can use take a rca cable to 3.5 mm cable
thumbnail.aspx?q=410222334008&id=874e2170e5197aa72b7e313258a4fed3 buy a fm modulator
item-3992-5-500.jpg then you can wire up the fm modulator to the jensen radio red power and black ground unplug your antenna from radio plug it into fm modulator and then connect antenna of fm modulator into your jensen radio antenna spot . the connect the rca cables to the fm modulator and then other end into the ear phone piece on ipod . follow the instruction that come with fm modulator you will have to tune your radio to a station like 88.9 or which ever you pick from the select ones fm mod gives you to hear you ipod . http://www.tintingbyfredjohnson.com
Dec 28, 2010 | Jensen VM9510 Car DVD Player
I have a pioneer DEH 525-W car sterio harness and colors do not match to that of the Saturn L2 1999. How do I connect this car sterio?
Just go to Best Buy and buy the Saturn L2 1999 Harness . then it will match. Harness cost like 20 bucks.
1st STEP
Things to get from BEST BUYor RADIO SHACK.
1. Black electrical tape
2. (Optional) for quality connection Solder & Solder gun
3. GM (General Motors) Antenna Adapters
4. GM 1999 Car Harness
5. GM Saturn L2 1999 Car Kit
STEP 2 = Match the colors of the car harness you just bought to the harness of the radio (DONT PLUG IT INTO THE CAR YET CAUSE YOU MAY SHORT OUT THE POWER WIRE TO GROUND) twist the same color wires together and then tape them so it wont be exposed to get shorted out and damage your radio or blow fuses in the car.
STEP 3= plug in the complete harness to the radio and the car and also plug in the Antenna adapter to the small antenna jack of the car that converts it to a larger jack so you can plug it in the back of the new pioneer radio that has a larger antenna hole. Now test the radio it should work unless you had blown your radio fuse in the car already which is easy to replace.
STEP 4 Unplug everything from the radio and install your CAR KIT. Then slide your radio sleeve in the rectangular hole all the way flush and use a flat head screw driver and bend the tabs of the sleeve(Radio Cage) so that the sleeve wont move.
STEP 5 make sure your harness & antenna is sticking out of the sleeve so you dont have to fish it out later when you have finished mounting the car kit to your car. Put your car dash back together and you will see only a rectangular hole with a harness and antenna adapter sticking out only.
STEP 6 plug in the harness and antenna back into the radio and slide it in halfway only and test the radio again making sure everything works. If it does then move it all the way in till it locks into place. last snap in the face trim ring into place to cover the silver cage lining.
THERE YOU ARE FINISHED
Apr 09, 2010 | Car Audio & Video
Standard Horizon HX 471. Antenna is to long to fit in Dive Canister. Can I removed antenna or replace with more flexable antenna?
Yes, as long as it is the right length and impedance, you can use a piece of wire! ... If you can get a smaller "antenna" and it fits, it will work fine. You could try disassembling the "Old" antenna, inside, you will find that a it can then be bent or such, use heat shrink to seal it, when modified.
Feb 26, 2010 | Standard Horizon HX471S (824 Channels)...
Which antennae to use with a Uniden Oceanus radio?
Marine two way radios operate on 156 MGZ. You have to use an antenna desinated for that purpose. Type marine vhf antenna on google search and it will pop-up lots of web sites.good luck
Jul 21, 2009 | Uniden Solara DSC VHF Marine Radio
Can I buy the face only to the jensen marine mcd 5110
Do you still need the face plate for a 5110? I have one with case. if so e-mail me @ r.ruditz@att.net
Nov 29, 2008 | Jensen MSR4050G CD Player
I have a model Jensen MCD 5110 and the face plate keeps flashing and all the stations look like they are searching for a channel..The other problem is the volume won't go past number 12 out of 46 and I can...
the unit is shot there is no hope for it. i have seen this problem many times in boats and never been able to fix the problem. i have had customers send the unit back to jensen and received a new one but check and see if your 1 yr guarantee is still good.
Aug 07, 2008 | Jensen Car Audio & Video
Jensen MSR4050G Sirius Ready marine radio
I had the same problem and there are a couple of reason why you may not be able to get into Sirius Mode.
  1. You have the wrong type of antenna (it must be a Sirius approved antenna)
  2. You may not have installed the tuner (most Sirius ready units need require that you have a tuner hooked up to your unit to get satellite reception. The tuners are specific to your unit, so make sure you but the correct one. This is quite sneaky on Sirius’ part…but good luck).
May 19, 2008 | Jensen MSR4050G CD Player
Jensen Mcd5110 Marine Radio /am/ Fm/ Cd Receiver W/ Detachable Face Logo
90 people viewed this question
Top Jensen Radio Communications Experts
Mike Charette
Tom Chichester
Markku Vuorensivu
Markku Vuorensivu
Level 1 Expert
Are you a Jensen Radio Communication Expert? Answer questions, earn points and help others
