Question about Canon Office Equipment & Supplies
I used the printer cable from my Canon LBP3000 into another computer & now I cant print from the canon
I removed the cable & then re-connected it
  • Canon Master
  • 17,326 Answers
Turn everything off, reconnect it and the start the computer and then they printer.
Posted on Nov 21, 2014
SOURCE: Canon Pixma MP610 not connecting to scan
Had the same problem. Don't think it scans wireless; worked fine when I connected with USB cable.
Posted on Jun 12, 2009
SOURCE: Canon MX328
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
error 5100 :
1. clean **** strip film
2. clean **** strip film sensor (back of head carriage)(use contact cleaner)
3. fix purge unit
Posted on Apr 24, 2010
  • 117 Answers
SOURCE: MP530 all in one printer - bought Staples magenta
What you can do is take the ink cartridges out of the print head and remove the printhead. Hold the print head over a trash can and take some 409 cleaner and spray the little pads inside the print head til you start noticing the colors dripping into the trash can. You will them want to dry off the print head as much as possible and litely wipe off the outside and the bottom of the print head with a paper towel. Then reseat the printhead back into the printer and the inks. You will then want to run a nozzle check from your printer software or from the printer properties. If the inks still are not showing up run one or two cleanings. If the issue still persists then you might have to replace the printhead. If this is the case you can look up part number: QY6-0059-000 online to replace the print head.
Posted on Jul 01, 2010
tagmonkey2k
  • 117 Answers
SOURCE: I have the same Error Number 300 with my Canon
Hi Daniel, I just had a quick look and other people here have posted problems regarding error code 300 on the MX850. Take a look here when you get a minute to see if any of the solutions posted help you out at all. It's a long shot as this link is for Apple users but it might point you in a direction you hadn't yet tried. All the best.
Posted on Sep 30, 2010
Testimonial: "Very helpful, thanks - especially the link to the Apple support forums. Deleting and re-adding the printer in Printer Setup Utility has solved it..."
  • 132 Answers
SOURCE: how to download canon lbp3000
http://driverscollection.com/?H=LBP3000&By=Canon
Posted on Nov 20, 2010
Canon mp258 printer can not fine driver on my computer it only picked up the scander part
Possible causes of failure:
1. Error install driver process
How to install the correct driver canon
- Do not connect the printer to the computer. So, turn on the printer but do not connect the printer to the computer.
- Insert the driver CD and do the install process.
- At the time of the install process, it would appear the request connect the printer to the computer.
- Connect the printer to the computer. The computer will detect the printer, and install process will continue until completed.
- Then, press the START - Printers and Faxes - Right click the Canon MP258 series Printer - select Printing preferences - click Maintenance - Print head alignment - Align print head - OK - etc. Perform print head alignment until completion (approximately 3 times the heat print alignment). Print head alignment, to configure the printer and computer.
- After the print head alignment is completed, the printer is ready to use.
Install the wrong driver canon
- Connect the printer to the computer, then perform install process.
- Solution: disconnect the USB cable from the printer to the computer, then uninstall the drivers and applications that are already installed, then restart the computer.
- Repeat the process to install in the correct way.
2. Drivers don't support the operating system
If you need a Canon MP258 driver download here:
Canon Support and Download
- Follow the link
- Product category = Inkjet Multifunctional Printers
- Product series = PIXMA
- Model = PIXMA MP258
- Document type = Drivers & Software
- Click Find
- Select OS = example : Windows 7
- Download driver printer; MP250 series MP Driver Ver.1.04
- Download driver scanner; MP Navigator EX Ver. 3.04
I hope this information helps. Thank you for using FixYa!
Oct 07, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Mx7600 error code 5c20 Problem
hi..............
Please remove all cartridges and print head. Using a moist cloth clean the golden contacts on Print head as well as printer. DO NOT touch nozzle of cartridge. Dont insert the cartridge yet.
Please do this :
1. Remove the power cable from printer. Remove the USB cable that connects printer to computer (remove it from printer as well as computer's usb port)
2. Press the printer power button and keep pressed for 3 minutes then release
3. Now plug in the power cable and usb cable (connect printer to computer) and power on the printer.
Then plug in the Print head and cartridges.
Now see if its working fine.
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 28, 2011 | Canon MX7600 Office All-In-One Printer
Hi, I have a canon BJC-80 printer& I am using vista. The printer will not print. It has printed twice. But a time delay of about 30 minutes. My laptop is toshiba & I have a usb cable plugged into...
try to remove the cartridge and print it again. Try also to unplug/replug the USB and restart your printer to check if it prints. You may also use another pc to connect the printer and print. Otherwise call Canon to check it for a possible repair...
Jun 05, 2011 | Canon BJC 80 InkJet Printer
My CaNON ip90 PRINTER SAYS "ERROR" WHEN TRYING TO
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Mar 08, 2011 | Canon PIXMA iP90 Mobile Printer
Mp190 geeft E3 code aan gaat om een canon
Jan 12, 2011 | Canon Office Equipment & Supplies
Hello I need a driver type of laser printer Canon LBP3000 size
Hi.
Here driver download page:
LaserShot LBP3000
Select OS on page linked above to download drivers.
Aug 18, 2010 | Canon LASER SHOT LBP-3000 Printer
We have giant company & having CANON LBP 2900.Whenever i am going give print it,s not printed .message shown ready to print but error occuring please help
try checking the printer if it is installed properly, by going to the printers and faxes folder, right click lbp2900 and check its properties, verify if the port used is correct. check printer if it is online and also the usb connection. if everything is ok, try replacing the usb cable. if after replacing the cable and the printer still doesn't print, uninstall it and remove the connection. Restart the computer and begin installation, do not connect the printer unless the system prompt you to do so. Run test print after the installation.
Jun 22, 2010 | Canon LASER SHOT LBP-2900 Printer
Printer driver
canoon lbp3000 printer driver
Jul 09, 2008 | Canon LASER SHOT LBP-3000 Printer
old marine
old marine
