Question about Garden
Hooked to charger cranks fine. why no spark?
Conection is gone. key gone.hooking wires to battery charger.
    Champion:
  • 254 Answers
It may need 12v for ignition. The key switch would provide that. What is IT?
Posted on Nov 22, 2014
LT 1045. Why no start, no crank?
you need to replace your battery with a brand new one. because you old battery can not handle anymore the power it needs to crank your engine.
Sep 03, 2015 | Cub Cadet Garden
What should I try replacing next?
check for spark . if you have spark it should fire or at least try timing may have gone .
Mar 22, 2015 | 2002 GMC Sonoma
Why dont i get a spark? was running fine. i folded handle wrong. now wont start. hadnt used charger to start before.
Don't connect both blgack cables. 1 is the ignition cut-off. Probabilly, one of both cables has a yellow or white striping. This is then the ignition cut-off. You won't have ignition if this cable is grounded.
Check also the cable in the area where the handle folds for damages!
Nov 21, 2014 | Garden
Hooking up a 36 volt charger to three 12 volt batteries in series
first of all do you have 3 or 4 batteries your cranking battery is not to be wired into this 36 volt if you have 4 batteries you have 3 for trolling motor and 1 cranking battery look on your charger see if the banks or numbered 1 2 3 4 .... you got to find what battery is # 1 depends on how they hooked in series if you hook charger on wrong battery most the time a red light comes on telling you wrong battery move wires till green lights come on all batteries.# 4 goes to cranking battery if you only have 3 batteries you don't have 36 volts you have 24 volts and a cranking battery if so # 3 goes to cranking battery
Aug 29, 2013 | Minn Kota Boating
Truck won't start
sounds like the starter. if automatic make sure it is in park. also just because all the other electricle is operating dont mean you dont hhave a bad battery .try a jumpstart for the heck of it .it could also be bad wire conection check youre battery see if corosion is present on the termanals
Mar 21, 2013 | Denso 1996 GMC C1500 Sierra 5.7L...
Changed the circuit board on a Paslode IM350 and now the fan wont work any Ideas welcome
fan motor could have gone bad, spark unit(little black box in handle) could be bad. one of the three top conections could be loose, or hooked up wrong, battery contacts on end of circuit board assembly could be placed a little off( battery not making contact with circuit mold assembly) pinched one of the wires going to the trigger area, or fan area
Sep 26, 2012 | RTO PasLode 900420 Impulse Framing Nailer
Firebird won't start and charge disappeared
When you hooked the battery charger up to the battery how many amps was it putting into the battery?
Dec 08, 2011 | 1988 Pontiac Firebird
I have a93 f 150 when i hook the pos cable to the battery the starter spins but the battery pos sparks ty
tHE STARTER RELAY is shorted and is stuck in the crank mode. The battery cable sparks because of starter load Relay must be replaced ot at least checked for the two small wires being crossed. One of the small wires on the relay should have current only when key is in crank position.
Remove the two small wires and see if it still cranks when battery is hooked up. If so, replace relay. The + cable goes from battery to relay. Ned
Dec 18, 2010 | 1990 Ford F150
2009 Mitsibushi Galant will not start. Will crank but will not turn not turn over.
Check the timing system, check for spark on all spark plugs, check the fuel pressure. If all is good then you might have a bad crankshaft sensor. Its most likely the crank sensor.
Jun 20, 2009 | 2009 Mitsubishi Galant
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
