Question about RCA Televison & Video
I have a rear projection 2005 rca tv. It turns on with no sound a picture and within 20 sec it turn off. This happened with no warning
Unplug the tv and the same thing happens. Starts up green power light on, with no sound or picture.
    Problem Solver:
  • 32 Answers
It would be of help if we had a model number. This could be a few different problems.
Posted on Nov 26, 2014
Testimonial: "Model number is hd52w59"
Slinteriors
  • 8617 Answers
SOURCE: blue crt assmbly maybe?
its very possible that the blue CRT is horting the set out. Heres how you can test it. Remove the speaker grille and access panel behind the grille and you will see the crts. remove the blue crt circuit board from the end of the blue crt and make sure it isnt touching anything then try powering up the set if it doesnt shut down then you have found the problem and you will need a new crt. or you can switch the blue circuit with the green and try it iwth the blue on green and the green on the blue then if the screen turns green before shutting down you will know that its a problem in the blue drive circuit and not the crt. lety me know if you need further assistance.
Posted on Apr 01, 2008
Slinteriors
  • 8617 Answers
SOURCE: RCA D52W14
That model is famous for bad flybacks that shut the set down and there is no warning they just quit working. If you need further info please let me know.
Posted on May 03, 2008
tvguy171
  • 106 Answers
SOURCE: RCA model: r61wh76 chasis: itc222a
These units have a problem with bad connections on the flyback transformer.. Usually, soldering the transformer will fix this problem. Please take time to rate this response. If I can be of further assistance, let me know
Posted on Dec 09, 2008
Slinteriors
  • 8617 Answers
SOURCE: model d52w19 rca projection tv,will not turn
Thats the eroor for the flyback and CP150 needing replacement you can get the flyback # 259296 and the CP150 at the following link and they give free step by step instructions on how to do the repair.
http://servicemanuals.vstore.ca/
Posted on Mar 06, 2009
redhead7377
  • 51 Answers
SOURCE: RCA P46924 46" Rear Projection Home Theatre Gone Haywire
the button cluster in the front may have a bad tack switch(button) or the buttons may have loose connections. you can take the speaker grill off and look yourself...watch for wires..unplug your tv first:) also if you use spray cleaner that may have seeped into the button cluster too...you may be able to get the cluster as a whole from a local tv repair shop and put it in yourself..save labor charges:)
Posted on May 06, 2009
LG rear projection tv. sound but no picture.
Go to a repair centre, some parts must be fixed/replaced.
Jul 22, 2009 | LG RU-52SZ30 52" Rear Projection...
Mar 21, 2009 | RCA P46924 46" Rear Projection Television
Panasonic PT-53TWD63, TV will not turn on, Red power light blinks
It is most deffinately a convergence chip issue. The die for no reason. They can be bought online for around $10 dollars and anyone with experience with soldering can replace them pretty easily. I have done it.
Feb 03, 2009 | Panasonic PT-53TWD63 53" Rear Projection...
RCA 50in Rear projection TV Turns on and off every 30 seconds-New
if u have only had it a month it should be under warranty get them to repair it
Sep 21, 2008 | Mitsubishi VS-55609 55" Rear Projection...
Hdtv dlp 52 inch loss of picture and loud buzzing noise
Please see http://www.fixya.com/support/t1011937-transformers. It sounds like your flyback transformer is not properly soldered down/is failing.
Sep 06, 2008 | RCA HD52W59 HDTV Projection Television
RCA MM6110 The TV is on but I am not getting a picture.
Have you tried resetting the cable box by unplugging it for 5 sec. and plugging it back in? (power cable)
Aug 27, 2008 | RCA MM61110 61" Rear Projection Television
Rca tv
when it shuts down and you try to turn it on again does the led blink/ If so how many times does it blink? let me know and I will try to help you out with the problem. Also let me know does the picture do anything abnormal just before it shuts down?
Jun 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Volume up then pic gone
Sounds like you have a jammed / shorted out button on the control panel... Try un-plugging the tv, and then unplug the "button panel" on the front of the tv...see if you can turn the tv on with the remote. Sometimes if one of the buttons gets shorted, it will "lock" the processor from doing ANYTHING else, as it thinks you are holding down the defective button. If this works, simply have the defective switch or control panel replaced, or just leave it unplugged and use the remote only! Hope this helps!
Jan 03, 2008 | Mitsubishi WT-46807 46" Rear Projection...
RCA 46" Rear Projection TV - Picture is Blurry and RED
That sounds like the screen and focus controls you are adjusting. It sounds like you have a bad HV Splitter inside the TV. #205064 or #204809 Depending on your model number. http://www.matelectronics.com/acatalog/Mat_Electronics_Replacement_Parts___TV_134.html sells them for about 20 bucks.
Dec 27, 2006 | RCA P46812BL 46" Rear Projection...
Televison & Video Logo
47 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
