Question about Air Purifiers
Why is the blower fan in my 1000 turn on and off constantly? Its brand new!!
Nothing tried yet!
    Habit-Forming:
    Filmmaker:
    Uploaded 5 video answers.
  • 42 Answers
I had 2000w blower fan and it was turning on/off just like your fan due to it's overheat protection.
If your fan turns off in short time(like 10 minute); i suggest you to use your warranty and return your fan back to seller.
Posted on Nov 21, 2014
Constant red light
it may need a clean as there is a air flow sensor, if the flow is not right then it will have this on also a faulty sensor will read this aswell.
Mar 24, 2014 | Hoover AH60015 Air Purifier Replacement...
Lasko blower fantype DTB E20739 PM7331
to clean your fan from dust
Jul 02, 2013 | Air Purifiers
BIOZONE 1000 HAS NO POWER
Maybe it also needs a new fuse or power supply?
Mar 01, 2012 | Biozone Standard 1000 Air Purifier
Pure pro fan motor
compressed air , you might try bringing it to a electric motor repair shop or a auto shop and ask real nice if they would be nice enough to give your fan a shot of air. a weed blower will work also but not even close to the job of compressed air. last resort is to take it apart totaly and use soapy water and a scrub brush. do not get the motor wet ! and oil the bearings on the motor with zoom spout oil #D01.. and you can milk your favorite fan out for many,many years .. this way is like cheating death! ... jay the pool pump motor repair guy in longwood fl
Jan 12, 2012 | Montgomery Ward Pure Pro Air Purifier
Evcon Model EB15B Elements glow red for 3 minutes then cycles off. Fan stays off during the cycles. Manual fan switch will turn on the fan. Assistance requested, cls
the fan has to be on while the strips are on. knowing that the fan comes on when you switch it to on at the thermostat but not when your just calling for heat indicates that you have somting wrong with the heating relay or the fan isnt wired properly to the heating relay (posssibly a new motor during the summer) or just a bad relay. when the first stage heat comes on it should also energize the motor the first to come on is also the last to shut off which will make sure the fan runs during the whole heating cycle. until you remedy this you can run the heat just keep the fan switch set to on so its running, this will not hurt anything
Nov 24, 2009 | Air Purifiers
I just washed the electrostatic grid and didnt have it thougholy dryed before inserting it back into the unit. Now I cant get the power light to turn on
As long as you have the cells in the correct direction, the air flow direction you should be O.K. If you have a way of turning on a constant fan that will help dry them. I would shut the power button off to the electric air cleaner and run a constant fan for 24 hours. After that, turn the power on and the constant fan off. Turn up the heat and see if it works.
I have an Oreck air purifier model (air 4000). The power light is on but the fan will not turn unless I put it on high speed and manually push the fan to give it a jump start for it to start running but...
I tried that solution and it did not work due to the worn bushing. I went on line to CSH incorporated and ordered #534 Open Ventilation Fan & Blower Duty motor. The motor is a ball bearing motor rather than bushing, and is an exact replacement for the Fasco motor on the original. The repair is easy and a cheap repair at cost of about $67 dollars for the motor plus shipping. The unit now works great again.
Robert
Oct 30, 2009 | Oreck Console Air Purifier
Alpine XL-15 fan has stopped working
Hello night light,
How you proceed is going to depend on how comfortable you are taking it apart.
Given it's age and purchase condition, warranty isn't an issue. You will either be able to dis-assemble the purifier and try taking the motor apart and reassembling, or you can find a replacement motor (I've seen some on the web, they start at ~$50).
Another possibility is that the fan pot (the rotary switch that the knob turns to adjust the fan speed) may be out. If you have a multi-meter, see if you can get a signal through (when it's all the way open). If not, try replacing that first. Parts are available onthe web, I can't advertise per FixYa's terms of use.
Hope this helps.
Sep 28, 2008 | Alpine Air XL-15 Air Purifier
Fan trouble with Flair
remove the retaining screw from the bottom of the unit and slide the insides out the back. use WD40 with the plastic extension tube, spray into the motor armature/stator and turn with your hand until it is free spinning then reassemble and turn on.
this is an ongoing problem with my unit because the air and all contaminents are pulled directly to the fan.
Apr 04, 2008 | Ecoquest Flair Air Purifier
Air Purifiers Logo
Top Air Purifiers Experts
Are you an Air Purifier Expert? Answer questions, earn points and help others
