Question about Toyota Genuine 1 30 / 40 series Estima tail pair
Vibration Feeling From Engine is Making the Whole Car Vibrate???
I need help finding an issue with my Estima 2000 model ACR30 with 2.4L Petrol 2AZ-FE engine Automatic Front Wheel Drive (2WD). It's got a vibration issue. The engine vibrates back & forward a lot especially when in drive or reverse and it gets worse when I turn on the Air Condition... I have checked & changed most rubbers & bushes and replaced four brand new engine mounts check the all the engine frames, checked the tension belt... Please if you can help me or help me by posting this up on the forum... Thank you Sorry, forgot to mention. I also replaced steering bushes... The vibration happens when I'm in drive and I accelerate the revs around 1100-1400rpm, that's when I feel the vibration and the whole car vibrate... It's very hard to explain. I don't feel the vibration when the car starts doing 20km/h or more in speed, So when I'm driving the car normal don't feel the vibration... It's only when I come to a stop or turning slow turns like a roundabout... I had the car for one year now, since i got it I have done major service on it... I have put brand new spark plugs not long ago and checked the coil packs, This car doesn't come with leads. No Misfire. The car is Automatic Front wheel drive, The rev is normal at 750rpm & about 650rpm with aircon on. I have also put four brand new tires & machined the disc and put original toyota break pads... All four engine mounts done, Steering bushes done, D bushes done, Check all other rubbers & bushes all good... The feeling is driving me crazy, very hard to explain... It does away when i reach 20>kms in speed, Its just when i need to take off, you feel the vibration then it does away when its about to kick into second gear...??? The aircon just makes it increase in vibration... Someone has suggest to get my gearbox check??? Any Ideas, Please Help... Thanks
  • Toyota Master
  • 15,557 Answers
There is a harmonic balancer on the engine. IT is mounted to the crank shaft. That is the problem.
Posted on Nov 21, 2014
  • 12 more comments
  • Sydney Best
    Sydney Best Nov 21, 2014
    Checked the Harmonic Balancer, Looks Good...
  • Brad Brown Nov 21, 2014
    Check the engine vibration by revving it up in park and see if the vibration occurs. The other thing that can cause this would be wheel bearings. You can test this by raising the wheels off the ground and checking the play. Or you can put it in drive. However you need to know that you cannot check a harmonic balancer by sight.
  • Sydney Best
    We checked the wheel hub & bearings when I changed four new tires and break pads...
  • Sydney Best
    With the Harmonic balancer, what's the best way to check it...
  • Sydney Best
    when car is in Part or Neutral. It's fine no vibration. Its only in drive or reverse the car vibrates.
    The harmonic balancer is just replaced without any tests if you believe that it is the problem. If you turn a tight circle to the right and then to the left, does it make any noises.
    This might be a torque converter if it is an automatic.
  • Sydney Best
    Yes, its an automatic front wheel drive...
  • Sydney Best
    Only when I turn Right, I can feel the vibration but not left turns...If i turn right then left turn no noise???
    Check the CV joints.
  • Sydney Best
    Sydney Best Nov 24, 2014
    I got two Transmission Specialist to have a look at the car and both ruled out a gearbox problem... Which is Good News.
  • Sydney Best
    But, One said it's a Harmonic Balancer and the other said it's an engine mount issue (more of the front mount)... ???
  • Sydney Best
    CV Joints were also checked and all good...
  • Brad Brown Nov 28, 2014
    i recall you saying that the wheels made a noise when you turned tight circles. That is a CV joint making that noise. You posted that it makes the shudder in a round about. That is also a tight turning radious.
Need recommended Fluid specs and amounts to change oil for 1996 Toyota Tacoma 4 wheel drive front and rear axles
Hello there,
From this page https://www.worldsbestoil.ca/product-cross-reference.php?year=1996&make=TOYOTA&model=TACOMA&engine=2.7L&vin=1
Extract.......
.Engine, 2WD, with filter - 5.4 quarts [1]
Engine, 4WD, with filter - 5.3 quarts [1]
Cooling System, Initial Fill - 9 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, A340E Initial Fill - 1.7 quarts
Automatic Transmission, A340F Initial Fill - 2.2 quarts
Automatic Transmission, A43D Initial Fill - 2.6 quarts
Automatic Transmission, Total Fill
4 speed A340F - 10.4 quarts
4 speed A340E - 7.7 quarts
4 speed A43D - 6.9 quarts
Manual Transmission, - 5.3 pints
Differential, With ADRD Front - 2.6 pints
Differential, Without ADRD Front - 2.4 pints
Differential, 2WD Without LSD Rear - 6 pints
Differential, 4WD Extra Long Rear - 4.5 pints
Differential, With LSD Rear - 6.4 pints
Differential, Standard Rear - 6 pints
Transfer Case, - 2.2 pints\'
Sep 13, 2014 | 1996 Toyota Tacoma
Is it a mandatory to include metal plate when replacing water pump on toyota rav 4
no year, you are kidding,right?
mandatory, metal plate?
what year, what engine.
see here and see why we dont know.
like 20 engines there.
http://en.wikipedia.org/wiki/Toyota_RAV4
xa30 gen 3
this is why we are clueless, that is ok 90% of posts never say.
2.0 L 1AZ-FE I4 (petrol)
2.0 L 1AZ-FSE I4 (petrol)
2.0 L 3ZR-FAE I4 (petrol)
2.2 L 2AD-FTV I4 (diesel)
2.2 L 2AD-FHV I4 (diesel)
2.4 L 2AZ-FE I4 (petrol)
2.5 L 2AR-FE I4 (petrol)
3.5 L 2GR-FE V6 (petrol)
Jul 07, 2014 | Cars & Trucks
Where is the knock sensor
on the side of the engine,
why do you need to know that.?
they never fail unless hit with a hammer.
the answer is in the FSM (no engine options stated so impossible to answer prefectly)
its at alldata.com, but you need engine size.
here is the engine list just for all (in year span) RAV4
world wide, and you never said what country either.
Feb 05, 2014 | 2010 Toyota RAV4
Check timin cheing luck
cam or spark
tell the tool used, or where you saw such bad timing.
what 03 engine option, there are many engines used.
displacement and cyl . counts.
2.0 L 1CD-FTV I4 (diesel)
2.4 L 2AZ-FE I4 (petrol) are you messing with the cam?
say so.....
Dec 26, 2013 | 2003 Toyota RAV4
Estima 2.4 2AZ-FE ENGINE TIMING
what year? should be computer controlled, just match the lines up and computer does rest.
Jun 09, 2012 | Toyota Camry Cars & Trucks
I need timing marks on 2.2 toyota camry 2000
1. Remove the fan and generator V belt:
tdisline_543.jpg 2. TIMING CHAIN (2az-FE Engine):
Before servicing the vehicle, refer to the Precautions Section.
Drain the engine oil.
Remove or disconnect the following:
Negative battery cable
Hood Right-side front wheel Engine under covers Right-side fender apron seal Front exhaust pipe Engine moving control rod and bracket Right-side engine mounting stay and bracket Accessory drive belt Engine appearance cover Engine wire Alternator Power steering pump, leave the hoses connected Ignition coils Ventilation hoses Cylinder head cover Turn the crankshaft pulley to set the No. 1 cylinder to TDC compression. Align the groove on the pulley with the timing mark -0- on the front cover. Remove the crankshaft pulley as follows:
1. TMC made: Use Special Tool 09213-54015 to hold the pulley to loosen the bolt. Use Special Tool 09950-50013 to remove the bolt and pulley.
2. TMMK made: Use Special Tool 09960-10010 to hold the pulley to remove the bolt. Use Special Tool 09950-40011 to remove the crankshaft pulley
tdisline_544.jpg Fig. Removing the crankshaft pulley-TMC-2.4L (2AZ-FE) engine
Fig. Removing the crankshaft pulley-TMMK-2.4L (2AZ-FE) engine
Crankshaft position sensor Lower oil pan No. 1 chain tensioner Accessory drive belt tensioner
  • Support the engine with a suitable engine lifting device.
  • Remove or disconnect the following:
    Engine mounting insulators Right-side engine mounting bracket Stud bolt for the accessory drive belt tensioner from the block Front cover mounting bolts and nuts Front cover Crankshaft position sensor plate Timing chain tensioner slipper Timing chain vibration damper Timing chain Crankshaft timing sprocket
  • Turn the crankshaft counterclockwise by 90°, and align an adjusting hole of the oil pump driven sprocket with the groove of the oil pump.
  • Fig. Align the adjusting hole of the oil pump drive sprocket with the oil pump groove-2.4L (2AZ-FE) engine
    Fig. Insert a bar to lock the sprocket in position-2.4L (2AZ-FE) engine
    Put a bar in the adjusting hole of the oil pump driven sprocket to temporarily lock the sprocket in position. Remove the nut.
    Remove the bolt, chain tensioner and spring.
    Remove the chain tensioner, oil pump sprocket and No. 2 timing chain.
    To install:
    Set the crankshaft key into the left horizontal position. Turn the cutout of the drive shaft to the top
  • Fig. Align the crankshaft key and drive shaft cutout as shown for installation-2.4L (2AZ-FE) engine
    Align the yellow colored links with the timing marks of the sprocket as shown in the illustration.
  • Insert the sprockets with chain to the crankshaft and oil pump shaft.
  • Temporarily tighten the oil pump driven sprocket with the nut.
  • Insert the damper spring into the adjusting hole, and install the chain tensioner plate with the nut. Tighten to 9 ft. lbs. (12 Nm).
  • Align the adjusting hole of the oil pump driven sprocket with the groove of the oil pump.
  • Put a bar in the adjusting hole of the oil pump driven sprocket to temporarily lock the sprocket in position. Tighten the nut to 22 ft. lbs. (30 Nm).
  • Rotate the crankshaft counterclockwise by 90°, and align the crankshaft key to the top.
  • Install the timing chain vibration damper. Tighten to 80 inch lbs. (9 Nm).
  • Align the timing marks of the camshaft timing sprockets and bearing caps.
  • Using the crankshaft pulley bolt, turn the crankshaft and set the set key on the crankshaft upward.
  • Align the gold or orange colored link with the timing mark of the crankshaft timing sprocket.
  • Using Special Tool 09309-37010, tap in the sprocket.
  • Align the gold or yellow colored links with the timing marks of the camshaft timing gear and camshaft timing sprocket. Install the chain.
  • tdisline_553.jpg Fig. Align the marks of the sprockets and bearing caps to set the No. 1 cylinder at TDC-2.4L (2AZ-FE) engine
    tdisline_554.jpg Fig. Set the crankshaft set key facing upward-2.4L (2AZ-FE) engine
    tdisline_555.jpg Fig. Align the marked link of the timing chain with crankshaft sprocket timing mark-2.4L (2AZ-FE) engine
    tdisline_556.jpg Fig. Tap the crankshaft sprocket in with Special Tool 09309-37010-2.4L (2AZ-FE) engine
    tdisline_557.jpg Fig. Align the marked links of the timing chain with the camshaft sprockets during installation-2.4L (2AZ-FE) engine
    May 21, 2011 | Toyota Camry Cars & Trucks
    Fluid capacities and fluid specs
    2000 TOYOTA TACOMA 2.7L 4-cyl Engine Code 3RZ-FE
    Engine Oil Grade 1......API* All TEMPS......5W-30 Optional ..10W-30
    Engine, 2WD, with filter..........5.5 liters
    Engine, 4WD, with filter..........5.4 liters
    Manual Transmission,......GL-5/ GL-4 All TEMPS......75W-90
    Automatic Transmission,A340E......AF3 / A43D......AF3
    Differential, Front/ Rear W/ ADRD......GL-5 ALL TEMPS......75W-90
    Differential, Front Less ADRD......GL-5 ALL TEMPS......80W-90
    Transfer Case,......GL-4/GL-5 ALL TEMPS......75W-90 Gear oil.
    Capacity:
    Cooling System, Initial Fill..........8.5 liters
    Automatic Transmission, A340E Initial Fill..........1.6 liters
    Automatic Transmission, A340F Initial Fill..........2 liters
    Automatic Transmission, A43D Initial Fill..........2.4 liters
    4 speed A340E..........7.2 liters
    4 speed A340F..........10.1 liters
    4 speed A43D..........6.5 liters
    Manual Transmission, ..........2.5 liters
    Differential, With ADRD Front..........1.2 liters
    Differential, Without ADRD Front..........1.1 liters
    Differential, 2WD V6 Rear..........2.6 liters
    Differential, 4WD Extra Long Rear..........2.5 liters
    Differential, Short WB With LSD Rear..........2.7 liters
    Differential, Short WB Without LS Rear..........2.6 liters
    Transfer Case, Electronic..........1.2 liters
    Transfer Case, STD..........1 liters
    Feb 09, 2010 | 2000 Toyota Tacoma PreRunner
    I cant find toyota estima 2az-fe engine repair manual
    here is the site I think can help you regarding the user manual http://www.autoeducation.com/repair_manuals/Toyota-Previa-Van-2WD.html
    Jun 09, 2009 | 1997 Toyota Previa
    Santa Fe 2003 steering wheel vibrates at 65MPH
    it depends how bad its vibrating yes it does req rebalancing the longer you leave this more components will wear to like track rod ends,uneven tyre wear caused by tracking issues if money is tight at the moment you could try swapping front wheels with rear if you have two trolley jacks & tyres have decent tread hope that sheds some light onto situation.
    Dec 16, 2008 | 2003 Hyundai Santa Fe
    Toyota tarago 2az fe motor
    Rustam.Where is the fuse for radio of 2003 toyota tarago
    Jul 05, 2008 | 2003 Toyota Camry
    Toyota Genuine 1 30 / 40 series Estima tail pair Logo
    650 people viewed this question
    Top Toyota Winter Sports Experts
    Arnie Burke
    Arnie Burke
    Todd Arndt
    Todd Arndt
    Are you a Toyota Winter Sport Expert? Answer questions, earn points and help others
