Question about Maytag Refrigerators
Maytag GS2126PADW fridge trips safety switch (earth leakage detector) after about 30 minutes. It's not caused by defrost heater.
Until it trips house safety seem to be working OK. Nothing obviously wrong. The repair guy can't find a fault
  • Maytag Master
  • 17,326 Answers
The house that you live in might be using ADCI instead of GFCI. The newer protection is ARC FAULT DETECTION CIRCUIT INTERRUPTION. It can sense a SPARK and shut down the circuit.
Posted on Nov 21, 2014
Testimonial: "The detector was installed (latest model) a few months ago but the fault only showed up now. Thanks for your assistance."
5 Suggested Answers
  • 1314 Answers
SOURCE: Periodic tripping of earth leakage switch.
your not supposed to run an appliance on a ground fault circuit because most of the components ground to the body og unit do you have it on a gcfi well here in america anyway
Posted on Jan 01, 2008
  • 31 Answers
SOURCE: Fridge keeps tripping electricity
I assume by "earth leakage" you mean it is on a GFI circuit? Some older GFI outlets are sensitive to and do not work well with motors or other inductive loads like your refridgerator compressor. As for the compressor feeling hot, this is usually normal.
If this is a GFI outlet, try replacing it with new unit. If it is a GFI breaker, try replacing that.
Posted on Jan 07, 2009
  • 400 Answers
SOURCE: Westinghouse 410l fridge trips new RCD's in fusebox
Tripping an earth leakage would indicate a break down of insulation in the windings of the compressor, the possibility of a short circuit in the wiring system or the defrost element down to earth. I recommend you have a certified technician check it out before you have a fire. If the Hoover is in good condition there is no reason not to replace it. Rate me please.
Posted on Mar 11, 2009
heatman101
  • 43501 Answers
SOURCE: Freezer working fine, fridge not
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 08, 2010
How do i fix my lg multi flow fridge/freezer that trips the earth leakage all the time
It may be possible the defrost heater is shorting to earth or ground. This would trip the GFI every time the refrigerator went into defrost. It also is possible that water has infiltrated the insulation and causing a leakage current. This would be much harder to fix.
Mar 22, 2015 | LG Refrigerators
My fridge tripe the earth leakage everytime I switch on the fridge.
call ana accredited electrician to check the insulation of the wires and for vermin infestation that is across electrical connections
it could be a faulty capacitor or failed motor as the earth leakage breaker is also a fuse for excessive current draw
Jun 08, 2017 | Whirlpool Refrigerators
Xerox Phaser 8550 tripping RCD on warm up
IF the warranty is still in effect, call for service.
IF no warranty, then check the heaters for the solid inks.
Probably a bad element, or a shorted element.
Unless you are skilled with electrical meters, V-O-M type,
this could be dangerous.
DO NOT ATTEMPT to troubleshoot this with power on.
IF you can use a meter, with the power OFF,
check for continuity and resistance with multi-meter set to Ohms.
BE CAREFUL!
Electricity can KILL!
Jul 27, 2012 | Xerox Phaser® 8500, 8550, 8560, 8560MFP...
My fridge and freezer wont stay cold someone told me its some kind of fluid i was just wondering were i put it in at??
Most modern fridges use one type of freon gas or another. You must have a valid refrigeration license to purchase any type of freon due to the danger of having contact with it (instant frostbite) and leaking into the atmosphere cause depletion of the Earth's ozone layer. You would also need special tools to measure and check the amount gas introduced to the fridge without over or under filling or "charging" as it is often called. This is a job for a licensed pro.
With the above said, it is important to know the refrigerators do not often fail due to loss of refrigerant, but rather due to a faulty component in the defrost circuit. The defrost circuit consists of 4 main parts. They are: 1) defrost heater, 2) defrost terminator or sensor in series with the heater, 3) defrost timer and 4) wiring between the previous 3 parts.
The defrost heater is found in the compartment that houses the coiling coil. The defrost terminator or sensor is clipped or otherwise secured to be kept in physical contact with the cooling coil itself. The defrost timer may be located anywhere the manufacturer decides - a popular spot is in the toe space on the bottom of the fridge. The wiring, well, that is between all the parts. Chances are the wiring is fine - as would be the connectors to the individual components.
The defrost timer interval is about 8 hours. About 20 - 30 minutes in that 8 hour period the defrost switch is operated. This consists of switching power away from the compressor (so it shuts off) and to the defrost heater via defrost terminator. The heater is just a relatively small wattage heater that warms the freezer's freon filled cooling coil to melt any frost or ice build up on the cooling coil fins. It will be powered for up to 20 - 30 minutes by the timer or less - if the defrost terminator senses a rising temperature on the coil. This means that the heater will be on for either 20 - 30 minute OR until the defrost terminator gets warm enough.
If the timer is stuck - and never moves to the 20 - 30 defrost cycle, the frost on the coil will never melt away. If the timer does work, but the heating element has failed, the frost will never melt away. If the defrost terminator has failed open (preventing the power from getting to the heater), the will not work to melt the frost off the coil. If there is a loose, missing or damaged connection between the wiring harness and these components, it won't run as expected either.
To look at this problem yourself, empty the freezer and unplug the fridge. Access the coil by removing any ice maker and the back inside wall of the freezer. if it is iced up, you've probably got a defroster circuit related problem. You can allow it to defrost for the repairman or let it defrost and restock the freezer again. It should start working again for about a month before it frosts over again - depending on how often the freezer door is opened and how humid it is. Do this as often as needed until you can afford a repairman to look at the fridge.
I hope this helps. Please rate this reply - thanks!
Jun 24, 2011 | Refrigerators
Maytag model GS2126PADW is tripping the ELCB. It will run for about one hour before tripping. After tripping, it trips the ELCB every time it is turned on. However if left off for an hour or so it can be...
The ELCB ( Electrical Leakage Circuit Breaker) is designed to detect any leakage of electrical current.
When the current leakage occurs, the ELCB then trips the electricity supply within a fraction of a second of the leakage being detected, before the magnitude of the current reaches a lethal level.
Therefore any possibility of serious injuries due to electric shock to persons who are in contact with the electrical appliance at that particular moment is minimized. Have a licensed Electrician check out your outlet and an Appliance Technician check your refrigerator if outlet proves okay.
Dec 05, 2010 | Maytag Refrigerators
Mar 11, 2009 | Refrigerators
Frdge keeps tripping the earth linkage
have you checked the defrostr heater yet? Take and advance the defrost timer until iits made and then check the heaters.
Feb 01, 2009 | Refrigerators
Suddenly tripped off house
Hi akula, 200 ks to a fridgie, LG appliance, you must be in Australia;) Is it the earth leakage circuit breaker operating. If so, then you have a leakage problem to earth from the heater pad(not quite sure what that is, but this problem will need to be repaired. Am doing some research to see if there is anything that can be done without just getting a new fridge. Back to you soon.
regards
Graeme
Mar 21, 2008 | Refrigerators
Jan 01, 2008 | Refrigerators
Refrigerators Logo
133 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
