Question about Boston Acoustics BA745 Computer Speakers
How do i fix the analoug in on boston acoustics ba735
The analog jack in the back is broken ...and i can seem to find a digital audio out cable and adapter to rca so i will try to fix the analog in instead..how do i repair it..and where do i get the part..
  • Boston Acous... Master
  • 16,387 Answers
You will have the best luck for parts at mouser.com The speakers might be sealed in which case they are hard to open.
Posted on Nov 21, 2014
5 Suggested Answers
  • 23 Answers
SOURCE: Boston Acoustic BA735 wont play on my computer
The cable with 2 rings is stereo, a single ring is mono, you have to make sure that you are using the right cable/speaker combo. The speaker output is usually lime green, hope this helps, more info perhaps?
Posted on Jan 24, 2009
  • 7 Answers
SOURCE: Boston Acoustics Digital BA735 Speakers with no Analog input.
I use one set of BA735 with two computers. Computer A sends digital out and Computer B sends analog. BA735 plays both. I listen to music using digital while the analog from the other computer alerts me to the incoming messages in Pidgin.
I did have to change bios settings on one computer to use the on-board audio.
To enable digital output in XP, click on the speaker icon > Advanced > Select Enable SPDIF. You can leave the PC Spk Mute unchecked if you want the analog output as well. That's all.
I hope you are able to enjoy the rich sound of BA735. It's beautiful. My ears thank a lot for replacing those desktop speakers. BA735 hardly takes up any space . Two small speakers are perched on the hutch and the bass module is somewhere behind the desk, completely invisible.
Posted on Mar 06, 2009
SOURCE: Connecting BA735 digital 3.5mm plug with S/PDIF coax jack
The male mono plug (from the left small speaker) should be connected into the right speaker (small speaker with controls) . After plugging the multi pin cable from the control speaker to the sub-woofer you need to plug in a signal source from your computer (or any other digital signal) into the sub-woofer. This digital input looks like an ordinary RCA plug but carries many channels of audio. That connects to the enabled digital output of your computer. Some computers output digital through a 3.5mm jack others look just like an RCA phono jack. If you are lucky some BA735 sub-woofers have a second input that is a standard 3.5mm stereo jack and it will take analog audio from computer, DVD, MP3 player or the like. I have three sets of these speakers that I love because of their big volume considering such a small size.
Posted on Apr 30, 2009
  • 5 Answers
SOURCE: boston acoustic ba735 speakers not working
They say they push digital, but I dont think its what your speakers neet. They require DIGITAL-OUT on the sound card.
Posted on Oct 08, 2009
How do I hook up a tv to a Sony D311 receiver
The Sony STR-D311 only has analog audio inputs. If your TV has an analog audio output, use the appropriate RCA cable (2 M/M plugs on each end, usually red and white). If your TV has a headphone jack, use a 3.5 mm to RCA adapter. However, if your TV only has digital audio outputs, you will need a digital to analog audio converter, like this: https://www.amazon.com/Digital-Optical-Analog-audio-converter/dp/B004C4WPXA . You will also need the appropriate analog audio and digital audio cables.
The manual for the receiver is on the product support page: https://esupport.sony.com/US/p/model-find.pl?mdl=STRD311 . The direct link to the manual is currently https://docs.sony.com/release//STRD311.PDF .
I hope this helps.
Dec 04, 2016 | Sony Str D311 Receiver
Im having trouble hooking up my sound bar to my monitor E196FPf
As far as I know, the E196FPf monitor does not have speakers or an audio out. Thus you'll need to connect the sound bar to the audio out of your computer or other source. On a laptop, this will be the headphone jack. On desktops, you use the lime-green 3.5 mm jack on the back of the system.
Depending on the sound bar, you might need a Aux (3.5 mm M to 3.5 mm M) cable, a 3.5 mm M to dual RCA (red/white) adapter cable or an analog to digital audio converter with the 3.5mm to RCA cable and appropriate digital audio cable.
Please add a comment with the model of the sound bar and the audio/video source, if you want more information on the best solution for your application.
I hope this helps.
Aug 07, 2016 | Computers & Internet
How do you connect tv audio from vizio wv26l through panasonic saht 680 surround sound?
The SAHT680 only has RCA analog audio inputs. I don't know the WV26l. However, there are a couple of possibilities based on other Vizio models. 1) The audio out is a headphone jack. Use a 3.5 mm M to RCA F/F adapter and then an RCA audio cable to the surround sound system. (You can also use a cable that has the 3.5 mm M and RCA M/M ends or a 3.5 mm F and RCA M/M adapter with a 3.5 mm audio cable.)
2) The audio output is a digital audio out. In that case, you need a digital to analog audio converter. There are a number of models available. One example is here: http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10423&cs_id=1042302&p_id=6884&seq=1&format=2 . You will also need the correct digital audio cable between the TV and the converter and the RCA audio cable between the converter and your SAHT680.
The manual for the SAHT680 is available from Panasonic here: service.us.panasonic.com/OPERMANPDF/SAHT680.pdf . See page 25 for the picture of the audio inputs.
I hope this helps.
(The only other option is to upgrade the main unit of the surround sound system to one with digital audio inputs if your TV only has digital audio out.)
Nov 19, 2012 | Audio Players & Recorders
Hi.How can I connect SHARP HT-SB400 sound bar system to TV SAMSUNG UE40C6000 LED? I have RCA cable supplied by sharp, it's that possible? My SAMSUNG operation system is : T-VAL6DEUC-1016.0
You should be able to connect these but you'll need some extra adapters/converters/cables. The Sharp HT-SB400 has analog audio inputs (http://www.sharp.co.uk/cps/rde/xchg/gb/hs.xsl/-/html/product-details.htm?product=HTSB400&cat=10500 ). The Samsung UE40C6000 LED TV has a digital (optical) output and a headphone jack (http://www.samsung.com/uk/consumer/tv-audio-video/television/led-tv/UE40C6000RKXXU-spec ).
With a RCA (F/F) to 3.5 mm (M) adapter, you may be able to connect the headphone audio out to your sound bar directly. This is an example: http://www.cyberguys.com/product-details/?productid=4730 . I'm not sure if this will automatically disable the TV speakers.
The other option is to get a digital audio to analog audio converter. One of these is http://www.amazon.com/Digital-Audio-Analog-Converter/dp/B0013LWK3A . You'll also need the optical digital cable in addition to the RCA audio cable that you have. With this you'll have to follow the manual for turning on the digital audio output on the TV (under the Sound menu) and turn off the TV speakers.
I hope this helps.
Mar 04, 2012 | Sharp Audio Players & Recorders
I want to connect an iPod to my Marantz SR 5600, what type of cord do I need?
You need a jack-2cinch (differen name is jack to 2 RCA) cable. Jack goes to your iPod's phones output, cinch/RCA to amplifier (connect it to CD or DVD analog section at the back). While playing set volume to 50% to avoid distorted sound. This way you can connect any MP3 player to your amplifier.
May 08, 2011 | Marantz Audio Players & Recorders
I want to play normal tv sound thru the surround sound, but do not know what cables to use? i have an LG 460 tv, and a sanyo dc-ht818, it doesnt seem to have TOSLINK or HDMI inputs, so what can i use?
The Sanyo has stereo analog LINE INPUT jacks. Run two RCA audio cables from the TV to these jacks and select this LINE INPUT FUNCTION on the Sanyo. If the TV has no analog audio output jacks you can even use the headphone output by using a 3.5mm adapter to RCA audio connectors.
Mar 11, 2011 | Audio Players & Recorders
How can I use digital media port adapter TDM-iP50 with an older Sony STR DE 425 receiver's RCA inputs? Is there a conversion cable--dm port to RCA?
The dm port Can't you just pull the audio from the iPod from its analog headphone jack with an adapter? They're common and cheap.
Dec 29, 2010 | Sony STR-DE425 Receiver
How do I conect external radio/speakers to my lg 42lh40-ua
There are many options here. Most HDTVs today have analog audio and digital audio output jacks. You can use RCA audio cables or a 3.5mm connector, whichever your HDTV has to connect the analog stereo output of the TV to any number of devices such as a stereo/amp which has speakers attached. You could also connect an FM transmitter to the TV and send the audio wirelessly to a nearby FM radio, boombox, portable etc. Most HDTVs today have a digital audio output, typically optical, which uses a digital audio cable ($15) to connect to a surround sound receiver. You can also connect the stereo analog output jack on the TV to a 2.4GHz transmitter and receiver speaker combo to get wireless audio outside, in a swimming pool and so forth, all around the house using wireless speakers. These setups usually cost around $150 or so. Look for the jack on the TV labeled AUDIO OUT and see if it is the white and red 2 jack ports or the smaller 3.5mm single jack port. Adapter cables are available at Radio Shack for around $10 should you need them. So you see the options are almost endless.
Aug 17, 2010 | LG 42LH40 LCD TV
I have a Dell computer that runs Windows Vista and I want to hook it up to use my TV as a monitor to watch a webcast. Please advise.
The first step is to inspect both your laptop and TV and identify the connections, easily located on the back of either component. There are five basic types of jacks, or ports involved:
*Composite/phono plug (RCA)
*S-Video
*Video graphics array (VGA)
*Digital video interface (DVI)
*High-definition multimedia interface (HDMI)
*An RCA connector, sometimes called a phono connector, is used for analog audio and video components. Three round, colored sockets are standard — left audio is white, right audio is red, and composite video is yellow. These are standard jacks on older TV’s and laptops. A three-prong cable, readily available at any computer or electronics, is the easiest way to make an RCA laptop to TV connection.
*S-Video, or Super-Video, a more advanced analog video connector, uses a four-prong round plug, like those used in TV cable installations. Separate audio cables are the same as for the RCA connector, left audio/white, and right audio/red. S-Video is commonly found on older TV sets and some laptops.
With S-Video on both TV and laptop, connecting a laptop to a TV is a simple matter of a single S-Video cable. If your laptop has a great sound system, you won’t need audio cables, but for better quality you’ll also want audio cables.
RCA to S-Video cable, a special laptop to TV cable, is available when you have RCA jacks on one device and an S-Video port on the other.
*A VGA connector and cable are used to carry analog video signals plus display and graphics data. The VGA is a 15-pin connector commonly found on laptops and other devices. With this port you need a PC-to-TV Convertor to connect laptop to TV. You simply plug the VGA cable from the source into the convertor, and use an S-Video or RCA cable out to the TV. The converter is USB powered, so there’s no external power adapter to carry around, making this laptop to TV connection entirely portable.
*A DVI port is rectangular with 24 pins arranged in three horizontal rows of eight pins for digital video; separate RCA analog audio cables fit into white and red plugs. DVI ports are found on Macintosh laptops; sometimes they are smaller than normal DVI ports and require an adapter, which usually comes with the laptop.
*The HDMI port, one-half the size of the DVI port, is also rectangular with 19 pins. It provides digital audio in addition to digital video, despite it’s smaller size, for a complete TV to laptop connection. These ports are found on new HDTVs, and sometimes there are two or more. TVs with HDMI ports are the only ones that do not require additional audio cables.
TV’s with a single digital port labeled HDMI/DVI require only one cable when the source is another HDMI component. But when source is a DVI laptop, you need a DVI-to-HDMI cable for the video and a separate pair of RCA analog stereo cables.
NOTE: Whenever ports do not match, you can by adaptors and/or cables to make any connection.
NEED MOre HELP check this link for video :
http://www.online-tech-tips.com/computer-tips/how-to-connect-your-laptoppccomputer-to-your-tv/
Jan 20, 2010 | Computers & Internet
Kenwood Receiver connected to my pc
using the Y adapter method (i am guessing you are using just a single stereo mini-jack cable with a mini-jack to RCA adapter) you are only sending a standard Stereo signal to the receiver. Setting 5.1 in windows is just simulating (if using Stereo) or actually mixing 5.1 if you are using analog 5.1 (3 stereo mini-jack cables going to 3 mini-jack to RCA adapters using a 6 channel DVD input). if you have a surround sound audio card i suggest using the Analog 6 channel input by using 3 stereo cables each with their only adapter.
or, if you have a Digital output (Coaxial or TOSlink [optical]) try using that.
good luck.
Nov 12, 2008 | Kenwood VR-406 Receiver
Boston Acoustics BA745 Computer Speakers Logo
213 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
