Maytag washing machine will do evarything but not wash mode, it sounds like grinding and the drum will not move!
Only wash mode it will not move! Everything Elsa works fine!
  • Brad Brown Nov 21, 2014
    Hi rtk_13, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? what model number?
    New Friend:
  • 28 Answers
I 'm pretty sure I've heard this before and that it is the end of the road for the Maytag motor. Sorry it isn't more positive...I've seen you tube videos about this problem before when ~I was looking for a friend. She did actually manage to buy one second hand on ebay to replace her old one. Maybe you tube or ebay can be of help and you could google 'Shipley's' to get a very reasonable and competitive quote for delivery in case the distance is a long way.
Hope that's useful
Posted on Nov 21, 2014
SOURCE: Drum is not moving
It sounds like the drum drive is broken ... could be a belt at the back of the machine or it could be gear driven ... most likley a belt... take off cover on back of machine to see if the belt is broken and replace if necessary. Also could be pump but that is probably the last thing to go wrong pumps rarely ever fail.
Posted on Apr 28, 2007
SOURCE: MAYTAG WASHING MACHINE
The rubber smell is the belt from the motor to the tub. The grinding sound is/was the tension pulley that keeps the belt tight. The bearing on the pulley probably went out and now the belt is burning because of the friction of sliding around the pulley. The belt and the pulley need to be replaced. If you have the room, turn off and disconnect the hoses. Unplug the electrical cord from the wall outlet. Remove the drain hose and any water in the tub. Carefully tip the washer over backwards, DO DROP IT!!! Now you should be able to see the motor, tub, tension pulley, and belt. With a basic 3/8' drive socket set, probably metric, and a couple of screw drivers you should be able to remove the belt and the pulley. Take the belt, pulley, and model numbers to an applicance parts store and buy replacements.
I only suggest this because I hate paying labor. If you are not machanically inclined then you are going to have to pay the labor.
Good Luck
Posted on Dec 19, 2007
SOURCE: My Hotpoint Aquarius WF210 washing machine drum is not rotating
I think the belt has come off or has been damaged.
To open the machine slide out the machine. On the back panel lower 1/3 you will see a plastic panel remove the screws and the panel will come away. Inside you will see the belt. I suspect you will need to reattach the belt of remove it and buy a replacement.
Sin é
Posted on Jun 27, 2009
  • 84 Answers
SOURCE: Grinding sound during agitation cycle on my Maytag Performa
Its probably you stator plate and rotor. But you need special tools for this repair. There a spring that is under 200 pounds of pressure and if you take the screws off that hold the plate its going to fly into you face if your dont use the special tools to depress the spring. Is it more of a clanking kinda of noise? DOes it olnly happen with heavy loads? Try this out. Fill the washer with water only. and get it into a wash cycle with water only. If there is no noise then put in like a load of towels. A heavy load. Now if you hear the noise now then its for sure you stator plate and rotor..hope this helps, but like i said you need those special tools to do this repair or injury can result from the spring part.
Posted on Jul 27, 2009
  • 27 Answers
SOURCE: The washing machine started making a grinding
sounds like a bearing... although it could be the water pump... water pump is an easy fix... bearing is not an easy fix... take the belt off the bottom of the pump (under the machine) and see if it spins freely by turning it w/ your hand... or if it seems really stiff... if it looks good then it's def. your bearing...
Posted on Jan 15, 2010
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Grinding noise and will not adjatate
Sounds like the drum bearings have gone try turning the drum by hand if it still grinds then you will need a bearing kit tricky to dismantle and fix but no impossible .
Nov 09, 2014 | Maytag Washing Machines
Why Is my Maytag washer making a loud grinding noise?
Possible Drum barrings failure. Drum unseated making contact with Housing. switch off. turn drum by hand check it is free of obstruction.
Not a job I would recommend for a DIY enthusiast. unless housing is out of place obstructing drum.
Incidentally. if this is a brand new machine. ensure all the drum transport fixings (if aplicable) were removed, and not fouling the drum.
Aug 25, 2014 | Maytag Washing Machines
My maytag hav2558aww wont turn on wash cycle
Possible that the grinding noise comes from the drum, irregular movement or broken paddles.
You can try and attempt only if equipped with a fundamental understanding of the working .
I shall give you some tips to this click 1..: Washing Machine
2. Replacing bearings
Jan 24, 2013 | Maytag HAV2558 Top Load Washer
We have a Maytag Neptune Washer Model MAH-1, approximately 5 years old. Never had any problems previously. Last wash, noticed a loud grinding sound upon starting the cycle. I stopped the wash, and...
Sounds like the spider arm(s) are broken in your machine. It is the part that supports the wash drum in the machine. It's a major repair job and can be expensive to fix. Get a few estimates before deciding whether it is worth fixing or replacing the washer.
Oct 05, 2010 | Washing Machines
Maytag neptune tl makes grinding sound and stops at 33 minutes in normal mode and at 24 minutes in quick wash mode
Hello djlampl,
With the lowest spin cycle setting I enter spin cycle in Quick Wash around the 21 minute mark. But first question is do you hear the grinding noise with the tumblers rotating during the wash/agitate cycle?
If you start a spin only cycle do you hear the grinding noise?
Does the washer error code out with an error code to the display? Codes such as dC, uC, Lr?, I assume the machine type is a FAV6800AW is that correct?
Any additional info will help in troubleshooting…..Rich
Assuming the machine type is a FAV6800A/FAV9800A here are some handy links;
The Service Manual for reference. Sears Parts Direct for reference.
Nov 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Pav3200washer making grinding noise
The tub is supposed to be locked untill the brake is released. When the machine is in the wash mode the tub is locked or else the clothes would all get knotted up. When the motor reverses the brake is released and the tub can turn freely. Check the pump for bad bearing.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 18, 2009 | Maytag PAV2300 Top Load Washer
Kenmore front loader drum grinding
This can be a symptom of drum bearing wear. A quick check for wear is to see if the inner drum moves up and down relative to the fixed outer drum. It should only move a minute amount. If it moves more than a millimeter or two, it is probably worn bearings. Regarding the bad smell - Make a boil wash (with no clothes and detergents) put in the powder's drawer a cup of bicarbonate of soda. It should clean the machine and remove out the bad smell. Good luck!
Sep 14, 2007 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
