Question about Neff Ovens
I have neff double oven ,only had it two weeks and the top oven which i use the most looks filthy- i have had it on self clean at least three times but the floor of oven is burnt on and looks awful. W
Just had it on self clean and a little flash and warm water
    Sergeant:
  • 244 Answers
Self-cleaning ovens are not "squeaky clean" after the cleaning cycle has run. Any spilled food or debris in the oven before it cleans will be left behind as ashes, soot, etc. and you will need to wipe it out with a damp cloth afterwards. If the residue is black and sticky then the cleaning cycle isn't running at a high enough temperature. Please refer to the manufacturer's instructions to make sure the cleaning feature is working and being operated properly.
Posted on Nov 21, 2014
Master_Tech
  • 770 Answers
SOURCE: Easy Off Heavy Duty Oven Cleaner on Self Cleaning Oven
NO..wont hurt it as loong as you got it all out.. but plz remind her that this is a self cleaning oven....Which does not mean you have to clean it yourself !!! it should be fine.. tell her next time to run it thru a self clean cycle for at least 3.5 hours on the timer setting..
Posted on Jan 27, 2008
SOURCE: Dead Whirlpool Double Oven
This happened to us the first time we used the self-cleaning feature. The repairman said we had to replace the whole electronic panel -- but when he put in the new panel it didn't work either. It turned out he just needed to replace the oven shutdown thermal fuse I believe. We finally got up enough courage to try the self-cleaning again and the exact thing happened. The door is locked and the electronic panel is dead again. So when we get it fixed we will never use the self-clean again.
Posted on Dec 05, 2008
jyackle5
  • 8197 Answers
SOURCE: fitting neff double oven cooker purchased from display at mfi
Go to this site here.
http://www.neff.co.uk/ovens.html
You need to register the oven under My Apliance to get the manual
Good Luck
Please rate FixYa!
Posted on Dec 19, 2008
SOURCE: Electrolux Icon Oven won't self clean - "Remove Racks" displayed
I was getting the remove rack error until I finally figured out what it wanted me to remove. When you say you removed the rack supports, do you mean just the sliding parts or the whole side metal rack support? At first I thought they were bolted in, but I read somewhere that they come out, too. Upon further investigation, I found the rack supports just slide into the side walls at 4 points. I had to use a little force to pull them out, but they came out and my oven is self-cleaning as I write this. I just thought I would share in case you or others haven't figured it out yet. Now I will just have to see how hard it is to get them back in...
Posted on Feb 21, 2009
SOURCE: Neff oven B1641
Turn the right hand button onto the ECS symbol. This is the cleaning cycle. Make sure you put some soapy water in the 'well' at the bottom of the oven. The oven is then steam cleaned.
Posted on Mar 08, 2009
Can NEFF oven be connected using a three pin plug on an independent oven circuit
If is a bog standard single oven then yes, if it has a self clean function or a rapid heat up function then generally no as the current draw would be to high for a 13amp to cope with, if you need model specific verification ring number as per linkhttp://www.neffcustomerservice.co.uk/Neff/CustomerService.html
Nov 26, 2011 | Neff Ovens
Heat escaping, uneven baking, longer cooking times
Either the seals need to be replaced, or you may have weak oven door hinges, and the door is not closing properly.
Only solution would be to replace both hinges if this is the case.
Please rate my solution.
Thankyou.
Feb 01, 2010 | Neff U1421 Double circotherm Electric Oven
I am looking to download a manual for a neff oven,
U HAVE TO TYPE IN GOOGLE DOWNLOAD AN INSTRUCTION MANUAL FOR A NEFF OVEN
Sep 29, 2009 | Neff U1721 Double circotherm Electric Oven
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
We have a SMEG self cleaning oven however the glass door is filthy and we are seeking the best approach to clean it without damaging
Purchase 3M stainless cleaner for the stainless parts, do not use spray and wipe or similar as it removes the marking or etching indicators (temp. etc)
You can use oven cleaner on the glass, but try not to let it go on the stainless parts yet again.
Hope this helps?
Jun 21, 2009 | Smeg DO81CSS Electric Double Oven
Neff oven B1641
Feb 27, 2009 | Neff B1641 Single circotherm super...
Neff oven U1661 shows fault code -5-
We have a similar Neff Oven - it is a child proof lock that you have activated. To deactivate - turn the left hand dial that selects the mode of cooking - three times to the left and back (turn it from 12 oclock to 11 oclock and back) in quick succession.
Sep 17, 2008 | Neff U1661 Double circotherm super...
Nef u1461 top oven
hi managed to clean my oven door this week end! yes you undo the two screws nearest the middle - but you will need an alan key to undo the top glass pops off -there is a spring clasp underneath - just ensure that you leave the door flat whilst you taking it apart. hope this helps i now have a nice clean oven door - you will be able to clean all parts once you pop off the glass - hope i was usefull!
Apr 16, 2008 | Neff B1641 Single circotherm super...
Can not remove element
Hi there. Dunno if you solved your problem but I had exactly the same. I did a bit of digging on this website and found the solution which worked. Basically, undo the three bolts holding the fan motor onto the back of the unit. This should allow enough play on the fan from the inside to wiggle (technical term) the bolt free and replace on the new element. Reposition and secure the motor. Hope this helps. Matt
Apr 02, 2008 | Neff U1721 Double circotherm Electric Oven
Ovens Logo
112 people viewed this question
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
