Question about Indesit Washing Machines
Hi. I have an indesit WD12X. The drum is half filling with water when switched off. Has anyone any ideas what this could be? I have cleaned out the filter, but it has not helped.
  • Indesit Master
  • 16,974 Answers
The valves that are used to fill the machine are worn or are filling with debris. You will have to purchase spares.
Posted on Nov 21, 2014
  • Chris J
    Chris J Nov 21, 2014
    Thanks Brad. What should I be searching for on spares websites?
  • Brad Brown Nov 21, 2014
    If you put the model number in the search bar for a site, you should come up with all the spares for that machine that are sold. Look for the fill or supply or hot and cold water inlet valves.
3 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Hi i have an indesit
Your model of washer dryer is fittted with a self cleaning pump, and may not have a filter fitted.
To check if it has, remove lower plinth at bottom of m/c, and if there is a plastic panel there ,remove that as well.
If there is a filter fitted, you will see it at the bottom right front, it has a round cover, unscrew anti clockwise, remove and clean filter.
Pleas leave a fixya rating if you consider my solution appropiate to your query.
Thankyou.
Posted on Jan 30, 2009
BElectric
  • 1140 Answers
SOURCE: we have an Indesit washer
Immediate thought was the belt but you already checked that. Reading your message, you seem to be indicating the washer goes through the wash cycle and does everything except turn the drum, i.e. it fills and drains and the timer control knob advances as you would expect. This machine has an electro-mechanical timer rather than electronic, so if it advances through the program correctly, I would exclude this from my initial checks, but I'd still come back to it later.
Washing machines aren't that complicated, so if all of the above is true, the obvious assumption would be the drive motor. You've obviously opened up the machine to check the belt, so have you tested the motor with an ohm / multi-meter?
Please confirm the correct operation of the timer and whether you have tested the motor and I will try to assist you further. I check messages regularly, so if you post back here I should reply fairly quickly. Make sure you reply from within this page - don't post a new help request!
Regards,
BElectric
Posted on Nov 27, 2010
My WD 12X machine is not drying the clothes. They get hot but not dry. Is there a filter somewhere that needs to be cleaned?
Presuming that this is an Indesit WD12X.
Yes, there is a filter at the bottom left of the machine (It can be clearly seen in the illistration on Page 14 of the manual, figure 6).
If you don't have a manual, you can download a PDF of it here:
http://www.indesit.co.uk/indesit/_pdf/manuals/19503326500_UK-USA-AUS.pdf
It's highly likely that the water isn't getting evacuated because the filter is blocked and so there is just too much water to dry. Unscrew the filter, clean and replace. I'm amazed to discover that (so far as I can see) The manual never even mentions the filter! Well done Indesit
Jul 19, 2011 | Washing Machines
Indesit wa155 filling too full, also not draining fully
its the pressure switch or more likely the tube or pressure bottle is blocked, which is common.you need to check and clean this not too expensive to fix....
Jun 07, 2010 | Indesit WA 125 Front Load Washer
Too much water going into the machine indesit wil103 water coming out the drawer when the drum turns.
Could try pressure switch/ clean the pipe feeding it check for hole in it causing air leak and pressure drop, make fill valve overfill
Apr 20, 2010 | Indesit W 123 Front Load Washer
I have a 2 year old indesit wd12x been fine
could be the catch has broken you may have to force it open and new complete door is about £25.00
Mar 01, 2010 | Washing Machines
Indesit WIXL85 water level
On a normal wash cycle, you will see very little if any water sloshing around, this is quite normal on todays washers.
You shuold see a lot more on the rinse cycle, as it is a higher fill.
It is usual to more less fill the compartment with powder, unless you are only washing a few items, then half fill it.
Hope this helps.
Dec 19, 2009 | Indesit W 123 Front Load Washer
Indesit wdg985w water licking. is anyone help me how to fix it please?
there is a hole in the drum, mine did the same. I had to weld it and then use a metal filling compund to seal the hole
Dec 15, 2009 | Indesit W 123 Front Load Washer
My Indesit WE165 fills up with water
there is a little hose that runs from the back of the pump
up to a pressure switch that contols water level in drum
I had a problem similar to this and found hose had split making
the drum overfill, replaced hose cured problem
Apr 19, 2009 | Indesit W 123 Front Load Washer
Hi i have an indesit wd12x washing machine that does not drain the water. How do i get to the filter to clean it? Thanks
Thankyou.
Jan 29, 2009 | Indesit W 123 Front Load Washer
My Indeset widl102 washer dryer
sounds like a faulty water valve if not pcb or pressure switch sorry cannot be more precise but thats indesit for you regards jason
Jun 12, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
76 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
