Question about GE Profile 30 In. Stainless Steel Under Cabinet Hood - JV536HSS
The wiring to the rocker switches for the fans and the lights have been disconnected.need to know where to plug each of the six connectors into the two switches
MOVED CONNECTORS AROUND
    Problem Solver:
  • 5 Answers
If you can post a pic of the connectors and and the switches - I can give you some guidance.
Posted on Nov 20, 2014
Brake controller or trailer brakes connections or brake light to run system
The brake switch at the pedal does have six wires, but none go to the multifunction switch (on the steering column). The white wire with tan tracer goes to the combination flasher to be integrated with the turn signals/hazard lights. The combination flasher is under the dash next to the steering column and has a sixteen pin connector (ten of which have wires).
Aug 07, 2017 | Dodge Cars & Trucks
Can you be a bit more specific? Are we talking about a vehicle?
If so, given that different vehicles and different model years will be using different wiring configurations - the more specifics you can provide on what mechanism you are trying to fix the be able we will be to answer your question.
Nov 20, 2014 | Cars & Trucks
I took the front panel off to paint it and I need to know how the 3 wires on the rocker switch go back on.there are 3 wires that go on the rocker switch there is 2 orange/2 blue/1 black
There are a lot of devices with rocker switches, what is it. You say there are three yet you enumerate five wires??? If I don't get back somebody else could.
Jan 24, 2014 | Electrical Supplies
I have an ACE brand dual control fan and light that I need help wiring. From the ceiling fan to the switch, I have a red, white, and black wire. The dual control has a black, yellow and red wire. I have...
The white to your fan will connect to the white in the switch box, The switch itself should have a wire labeled com or common. This is where the Hot in your switch box will attach. The other two wires will be your switch legs to theto the fan. (Red and Black)
http://www.broan.com/common/productDigitalAssethandler.ashx?id=e07a9916-6b3e-4456-b00e-2edfad475df2
May 04, 2017 | Broan-NuTone Broan 68W Dual Rocker Switch
How to replace head gasket on 4 cylander
2.6L Engine
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Drain the cooling system.
  3. Relieve the fuel system pressure.
  4. Remove or disconnect the following:
    • Negative battery cable
    • Hood
    • Accessory drive belts
    • Accelerator cable
    • Positive Crankcase Ventilation (PCV) valve and hose
    • Air intake duct
    • Fuel pressure regulator vacuum line
    • Canister hose
    • Brake booster vacuum line
    • Engine wiring harness connectors at right wheel housing
    • Ground cable connector at the intake manifold, starter and firewall
    • Heated Oxygen (HO2S) sensor connector
    • Alternator wiring connectors
    • Oil pressure switch connector
    • Starter motor harness connectors
    • Ignition coil connector
    • Spark plug wires
    • Distributor
    • Exhaust front pipe
    • Exhaust Gas Recirculation (EGR) gas temperature sensor connector
    • Air pump
    • EGR pipe
    • Heat shield
    • Exhaust manifold
    • Throttle Position (TP) switch connector
    • Cooling fan
    • Water pump pulley
    • Power steering pump
    • Intake manifold
    • Crankshaft pulley
    • Front cover
    • Timing belt. Refer to the Timing Belt unit repair section.
    • Valve cover
    • Rocker arms
    • Camshaft
    • Cylinder head
Cylinder head bolt loosening sequence - 2.6L engine
  1. To install:
  2. NOTE: Refer to Section 1 of this manual for the cylinder head torque sequence illustration. The illustration is located after the Torque Specification Chart.
  3. NOTE: Lubricate the cylinder head bolts with clean engine oil for assembly.
  4. Install the cylinder head with a new gasket. Tighten the bolts in sequence as follows:
  5. Step 1: 58 ft. lbs. (75 Nm)
  6. Step 2: 72 ft. lbs. (98 Nm)
    1. Install or connect the following:
    2. Camshaft
    • Rocker arms
    • Valve cover
    • Timing belt
    • Front cover
    • Crankshaft pulley. Tighten the bolt to 87 ft. lbs. (128 Nm).
    • Intake manifold
    • Water pump pulley
    • Cooling fan
    • TP switch connector
    • Exhaust manifold
    • Heat shield
    • EGR pipe
    • Air pump
    • EGR gas temperature sensor connector
    • Distributor
    • Spark plug wires
    • HO2S sensor connector
    • Canister hose
    • Air intake duct
    • PCV valve and hose
    • Accelerator cable
    • Hood
    1. Fill the cooling system.
    2. Start the engine and check for leaks.
    Feb 05, 2011 | 1997 Isuzu Rodeo
    I have a HB
    The power plug is a convenience for the factory light kit. You can clip the plug off and connect the wires with twist connectors.
    Just hook all the white wires to the same connector and the blue(typically blue for the lights in hampton bay fans).
    Be sure that you leave the switch installed and clip the wires AFTER the switch.
    Jul 13, 2010 | Hampton Bay 24002 Ceiling Fan
    Triple rocker switch to control 3 function bathroom fan/light
    I suggest you cut 3 pigtails out of your black wire (about 5-6" each and strip them so you can put a nut to tie them all together on the main wire, then do the same for your grounds using green 5-6" strips of wire and then connect all 3 switches with the pigtails to their proper locations. This WILL fix your problem.
    Mar 08, 2010 | Leviton 1755 Triple Rocker Switch Decora
    I need a pull chain DIMMER switch for my fan light. Only one set of wires supplies the fan and light. Surely SOMEBODY has a pull chain dimmer ??? Thanks. Bill
    Bought three fans for the bedrooms, all hunters with pull chain dimmers. Less than one year and two of the three dimmers are shot. Can't find a replacement so I bypassed it. Remove light assembly and unplug 9pin connector. Remove black vented dimmer assembly by removing wire nuts and disconnecting the 2wire connector(black and white wires). Cut the 2wire connector off and save it in case you find a part someday. Wire nut black to black(hot) and white to white(neutral). You will disable the pull chain by wire nutting those two wires together.
    Jul 29, 2009 | Hunter Ceiling Fan Light Switch Control
    Not sure how to wire this switch
    Switch will have a commom terminal that the hot wire connects to.
    The other three terminals are for the devices -- light, fan and other device.
    The white wires should be the grounded wire returns for the circuits unless they are identified by color tape to be hot line side of power.
    Be careful of the grounded side of circuit, can shock or kill, treat all wires as being energised. If you are not sure, use a electrical tester,
    or get help.
    Feb 28, 2009 | Leviton 003-1755-W Three Rocker Switches
    GE Profile 30 In. Stainless Steel Under Cabinet Hood - JV536HSS Logo
    101 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Mike Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
