Question about Philips Televison & Video
Why does my Philips TV randomly turn off and back on?
Called Philips, they said if I unplugged it for several minutes and plugged it back in and it still turned off and on by itself then it had to be a hardware problem. The remote quit working shortly before the problem started also. Changing batteries didn't help.
    Habit-Forming:
    Filmmaker:
    Uploaded 5 video answers.
  • 42 Answers
I think some of the capacitors at Tv power supply are faulty. By doing what Philips suggested, you actualy try to discharge capacitors. This trick could work, if capacitors would be fine. Your tv needs to be checked by service.
Posted on Nov 21, 2014
SOURCE: Panasonic 32" HDTV keeps turning off
Check or have a repair tech check connectors AP1 and AP2. Vibration rattles the power supply board (a crappy design, as the board is almost "floating") and causes the wires in the connectors to break, and may make intermittent contact. Heat may also cause intemittent contact. A very common flaw.
Posted on May 06, 2008
  • 5 Answers
SOURCE: Sharp Aquos turns itself off
How many times per second does the POWER led blink? (dont worry about the OPC).
1x per second (constant, steady blink) = bad inverter/lamps
2x per second = bad power supply
3x per second = bad main board
You can buy the parts online and fix if yourself!!
Posted on Aug 16, 2008
SOURCE: TV turns itself on, keeps changing it's own channel
the problem is with the control panel of your tv...make sure your remote doesnt have any part in this...just remove and the batteries and check if the channels still are changing.....see if the onboard switch for channel changing is stuck ?..if stuck u can use homemade tools to pull it back......if your tv is within your gurantee period...just giv a call to customer care....if not u can take it to a local repair shop...there is nothin that u can urself do to make it right ...sorry....for further info contact at
Posted on Sep 07, 2008
SOURCE: Keeps turning off-Philips 50PF9431D
i got ya dude!   buy a better tv, instead of tryin to save some bucks and getting a cheap *** plasma.
Posted on Oct 29, 2008
jerryg50
  • 1667 Answers
SOURCE: Vizio shuts itself off
There may be some components failing in the power supply or one of the circuit boards that are causing too high a current pull.
I realize that this answer is very vague. Without doing proper diagnostics, it is impossible to guess at something like this.
Out of warranty repairs on these sets can be very expensive. I would suggest that if the set is going to be expensive to service, it would be best to replace it with a known brand name that offers an extended warranty with local service. You will pay more, but you will have dependability and better quality.
Jerry G.
Posted on Jan 02, 2009
Philips 42plf7422 RANDOMLY SWITCHES INPUTS
There is nothing wrong with the TV I assumes. Have you tested it a hard reset? If not do a hard reset and check. Unplug the TV from AC mains wall socket, and re-plug it back after 10 minutes or so. An overnight unplug will be more effective. This must make the TV to a hard reset. If it do not help you, you have to enter its service mode options to make it a factory reset. If you wish to get more details about how to enter the factory mode check this link. http://electronicshelponline.blogspot.com/ Service mode and alignments to many brand TVs, including Philips models, have been discussed in detail there with illustrations. Pull up older posts there, and surf the site with patience.
May 29, 2013 | Philips 42PFL7422D 42 in. LCD TV
Picture keeps going out on Philips TV 47PFL3704D/F7, 2009 model. The sound stays on. It happens very randomly-may be fine for several hours, may happen every few minutes. Also happens when playing video...
I think that the connectors from the backlight inverter board that go to the LCD panel's backlight are a bit loose which explains why it comes back on when tapped. I am positive that unplugging and replugging the inverter cables should do the trick. WOuld like to do it yourself? It requires you to open up the tv ofcourse.
Jul 10, 2011 | Philips 47PFL3704D 47 in. LCD TV
Tv turns on and off randomly and it freezes to black screen
UNIT IN WARRANTY SEND TO SERVICE OR CALL BESTBUY IN HOME SERVICE
Aug 15, 2009 | Element Electronics FLX3711B 37 in. LCD TV
I need help tv plasma phillips
There is a firmware that can be updated via usb from philips. This fw was used to correct the tv powering on with no picture randomly (they called it a maintence session) but it was a problem. The tv would power on on its own and do this..
If that doesnt take care of your problem then the problem is with the main control board. or ssb
Aug 01, 2008 | Philips 42PF9630A 42 in. Plasma Television
Turns off randomly
mine does also does yours click at random times and the screen goes out in small places for a split second?
Apr 02, 2008 | JVC AV-32020 32" TV
50p8341 on-screen menu
05/09/08
I called the Philips help number (1-888-PHILIPS) and the tech had me turn off the tv and then unplug it from the outlet, wait 1 minute, then plug it back into the outlet, then turn the tv back on. It reset the menu memory and it is now back in the middle of the screen where it belongs.
Feb 23, 2008 | Philips 50P8341 50" Rear Projection...
TV randomely turns off
it may just be a static buildup from the dust.
open the tv and blow it out with a air compressor.
if that doest not work then the circuit may be overloading.
remember it stores a charge for days.
Feb 17, 2008 | Philips 30PW9817 30" TV
Philips 51PP9100D/37
try unpluging the set again for 5 minutes, if no help go into the menue and make sure that tha speakers are turned on. also try turning up the volume
Oct 19, 2007 | Philips 43PP9202 43" Rear Projection...
Tv randomly shuts off
Replace power relays on power board...
Bill
Oct 08, 2007 | Philips 55PP9401 55" Rear Projection...
Televison & Video Logo
66 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
