Question about Coffee Makers & Espresso Machines
Starbucks Italia the shot is not coming out all the way. Just slow drips
    Filmmaker:
    Uploaded 5 video answers.
  • 14 Answers
I would try to clean it out and see if it come out better
Posted on Nov 21, 2014
  • 40 Answers
SOURCE: Need to find nearest Authorized
Contact Saeco USA Inc. at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
If you are in the Maryland, Washington D. C. and/or Virginia area, I can provide you with the SAECO Service Center there.
Posted on Jul 17, 2008
  • 3 Answers
SOURCE: INSTRUCTION MANUAL
http://www.saecoparts.com/SaecoItaliaEspresso.html
Posted on Nov 29, 2008
  • 1089 Answers
SOURCE: Starbucks Saeco Italia sup021 coffee dispenser stuck problem
Hi
Open the front door. Remove the driptray. On the left back side of the brew group, there is a single screw. Remove the screw. Grab the handle and pull carefully, but firmly. The brew group should come out. There is a piece that remains in the machine. Slide the piece down and to the right and it will come off. Insert the piece into the hole on the backside of the brew group with the clip up. Tighten the screw and move brew group back into position. If your brew group did not come out call a service center.
To return the brew group to the centered position, you first need to drop the funnel. To do this look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. Push the "Press" button and the shark fin moves up and down. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between. these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not just push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First
you must close the door and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, open the door and insert the brew group.
Done
Posted on May 31, 2009
EsWorld
  • 1618 Answers
SOURCE: Saeco Starbucks barista.Espresso drips.
There was an unusual high pressure problem, remove the shower and screw, then the 2 allen wrench screws and check the spring and valve seat, they may have shifted.
Posted on Mar 07, 2010
EsWorld
  • 1618 Answers
SOURCE: Saeco Italia Digital Barista Fully Automatic Coffee Machine: the fill grinder light comes on (Saeco Italia,,not...
The grind might be set too fine.
Posted on May 20, 2010
Starbucks Saeco Italia Digital Barista Fully Automatic Coffee Machine will not prime!
Here is what is said in the manual:
"Direct the steam arm on the drip tray.
Open the steam/hot water knob until a
steady stream of water is dispensed. Close
the knob. Insert the filter holder into the
brew head to pre-heat the filter holder.
The machine is now ready to dispense
coffee."
Apr 26, 2017 | Starbucks Saeco Italia Digital Barista...
Water leaking from steam wand when brewing shots
Try this from another post. It should help.
The steam wand began to seriously leak but a call to Starbucks Customer Service line and I was talked through how to adjust it so that the leaking stopped. It requires taking off the top/back panel of the machine (6 philips screws) then using a small allen key (1.5 mm I believe) to loosen and adjust a plastic oblong donut-shaped thing (a "cam" actually) on the shaft of the steam knob... no more drips.
The key to prevent dripping is to open the steam knob without putting pressure on it when it gets to the full-open stop position. Cranking it too hard when it comes to a stop in the full-open position will slowly move the cam out of position. Then the shaft doesn't fully seat inside the machine anymore and won't fully shut off the water to the steam wand. Then, no matter how hard you crank the knob in the shut-off position it will still drip. The purpose of the cam is to stop the knob from complete unscrewing and it also turns the pump on and off for the steam wand. The cam adjustment is very small but completely solves the dripping problem. Seeing inside the machine made me realize how easy it would be to repair problems as long as I can get the parts from Starbucks or perhaps Saeco.
Dec 21, 2008 | Starbucks Saeco Italia Digital Barista...
Starbucks barista machine steam valve leaks.
Hi Sammy,
I think you have to replace the steam valve and the gasket in it.
Best regards
/Mirran
Nov 07, 2008 | Starbucks Saeco Italia Digital Barista...
Coffee Makers & Espresso Machines Logo
26 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
